Giriş
This guide will demonstrate how to change the battery of a Philips Norelco MultiGroom 3100. Tear down/reassembly requires a plastic spudger and soldering equipment.
Neye ihtiyacın var
Insert the spudger into the bottom of the gray bezel and begin to gently pry it off.
15 farklı kişi bu kılavuzu tamamladı.
10Kılavuz Yorumları
Capitalize Battery in the Title
Go ahead and upload the picture of the device.
Be sure to submit to iFixit for their comments when done.
Also include prerequisite guides
For the Multigroom QG3380 (which I bought at Costco in Canada), there are some differences. Don’t remove the power button – not needed. Pry off the silver frame – very hard not to break some clips. It uses two 750 mAh AAA NiMH batteries (Suppo HSY-AAA0). I’ve ordered 900 mAh batteries with clips to replace these.
Where did you order the replacement batteries ?
I had mine from Japan, QG3380 too many clips broke off and indeed don’t remove the power button on that one.
