Giriş
Here is how to replace the rechargeable battery in the Phillips SoniCare FlexCare. This is a difficult repair, be careful. If you see a swollen battery, follow the instructions here: What to do with a swollen battery.
Neye ihtiyacın var
Push the flat edge of a metal or nylon spudger between the seal and the toothbrush body and pry it open. Do this all around the edge until the seal is partially sticking out.
Have a look to an alternative opening procedure.
Using a small flathead screwdriver, release the two black locking tabs holding the internals in place
Slide the internals out of the toothbrush casing
Desolder the battery from the circuit board. Here is a guide on how to desolder. Remove the old battery and replace it. Using the same guide, solder the battery in place.
The soldering points are shown in red.
40 farklı kişi bu kılavuzu tamamladı.
37 Yorum
I'm going to try it. Now, to find a battery source.
The battery is a 14500 li-ion with soldered pins.
I bought this one without pin and will try to solder them:
http://www.ebay.de/itm/371716530024
Here, you can buy the version with pins:
mamuc -
Prying open the bottom of the brush like that can damage the plastic. There's a damage-free technique detailed on this guide:
