Ana içeriğe geç
Pixel 9 Battery Disconnection
Salt Önkoşul
Bu sadece bir ön koşul kılavuzudur! Bu kılavuz başka bir prosedürün parçasıdır ve tek başına kullanılması amaçlanmamıştır.
Neye ihtiyacın var
  1. Pixel 9 Battery Disconnection, Prepare your Pixel for disassembly: adım 1, 3 resimden 1. Pixel 9 Battery Disconnection, Prepare your Pixel for disassembly: adım 1, 3 resimden 2. Pixel 9 Battery Disconnection, Prepare your Pixel for disassembly: adım 1, 3 resimden 3.
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone.
    • Completely power off your phone.
    • Press the power and volume up buttons at the same time to bring up the shutdown menu.
  2. Pixel 9 Battery Disconnection, Adhesive information: adım 2, 3 resimden 1. Pixel 9 Battery Disconnection, Adhesive information: adım 2, 3 resimden 2. Pixel 9 Battery Disconnection, Adhesive information: adım 2, 3 resimden 3.
    • Adhesive secures the perimeter of the back glass to the frame.
    • When separating the adhesive, don't insert your tool more than 3 mm under the back glass to avoid damaging the internal components.
    • To help, measure and mark 3 mm from the tip of an opening pick with a permanent marker.
    • If your screen or back glass is badly cracked, a suction cup may not perfectly adhere.
    • Lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier. Ensure there's a smooth area near the bottom edge that's large and smooth enough for a suction cup to stick to.
  3. Pixel 9 Battery Disconnection, Apply a suction handle: adım 3, 2 resimden 1. Pixel 9 Battery Disconnection, Apply a suction handle: adım 3, 2 resimden 2.
    • Place a suction handle at the bottom edge of the back glass, as close to the edge as possible.
    • Push down to attach the suction cup.
  4. Pixel 9 Battery Disconnection, Insert an opening pick: adım 4, 3 resimden 1. Pixel 9 Battery Disconnection, Insert an opening pick: adım 4, 3 resimden 2. Pixel 9 Battery Disconnection, Insert an opening pick: adım 4, 3 resimden 3.
    • Pull up on the suction handle with strong, steady force to create a small gap under the back glass.
    • Insert the tip of an opening pick into the gap.
  5. Pixel 9 Battery Disconnection, Separate the back glass adhesive: adım 5, 3 resimden 1. Pixel 9 Battery Disconnection, Separate the back glass adhesive: adım 5, 3 resimden 2. Pixel 9 Battery Disconnection, Separate the back glass adhesive: adım 5, 3 resimden 3.
    • Slide the opening pick back and forth along the bottom edge to separate the adhesive securing it.
    • Remember: don't insert the opening pick deeper than 3 mm.
  6. Pixel 9 Battery Disconnection: adım 6, 3 resimden 1. Pixel 9 Battery Disconnection: adım 6, 3 resimden 2. Pixel 9 Battery Disconnection: adım 6, 3 resimden 3.
    • Slide the opening pick around the perimeter of the phone, slicing the rest of the adhesive.
  7. Pixel 9 Battery Disconnection: adım 7, 3 resimden 1. Pixel 9 Battery Disconnection: adım 7, 3 resimden 2. Pixel 9 Battery Disconnection: adım 7, 3 resimden 3.
    • With most of the adhesive separated, lightly twist the opening pick at the bottom edge to lift the back glass up until you can grip it with your fingers.
    • Use the opening pick to separate any remaining sections of adhesive securing the back glass.
  8. Pixel 9 Battery Disconnection, Remove the back glass: adım 8, 1 resimden 1.
    • Remove the back glass.
    • During reassembly:
    • Now is a good time to test your phone before sealing it up. Power it on and check that it works. Power it back down before you continue reassembly.
    • Follow this guide to apply new adhesive and install your back glass.
  9. Pixel 9 Battery Disconnection, Remove the upper board cover: adım 9, 1 resimden 1.
    Bu adımda kullanılan alet:
    FixMat
    $36.95
    • While the Pixel 9 uses Torx Plus screws, standard Torx bits also work. Make sure to apply constant, downward force to prevent stripping.
    • Use a 3IP Torx Plus driver to remove the single 5.4 mm‑long screw securing the upper board cover.
  10. Pixel 9 Battery Disconnection: adım 10, 2 resimden 1. Pixel 9 Battery Disconnection: adım 10, 2 resimden 2.
    • Use a pair of tweezers to remove the upper board cover.
  11. Pixel 9 Battery Disconnection, Remove the midframe: adım 11, 1 resimden 1.
    • Use a 3IP Torx driver to remove the five screws securing the midframe and wireless charging coil:
    • Four 5.4 mm-long screws
    • One 2.2 mm-long screw
  12. Pixel 9 Battery Disconnection, Peel up the flash cable: adım 12, 2 resimden 1. Pixel 9 Battery Disconnection, Peel up the flash cable: adım 12, 2 resimden 2.
    • Use a pair of tweezers to peel the flash cable off of the metal midframe.
  13. Pixel 9 Battery Disconnection, Remove the midframe: adım 13, 2 resimden 1. Pixel 9 Battery Disconnection, Remove the midframe: adım 13, 2 resimden 2.
    • Remove the midframe, wireless charging coil, and NFC assembly.
  14. Pixel 9 Battery Disconnection, Disconnect the battery: adım 14, 2 resimden 1. Pixel 9 Battery Disconnection, Disconnect the battery: adım 14, 2 resimden 2.
    • Use the tip of a spudger to pry up and disconnect the battery connector.
Bitiş Çizgisi
Carsten Frauenheim
157.391 İtibar
439 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
23.922 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 64
