Ana içeriğe geç
PlayStation 5 Slim Fan Replacement
Neye ihtiyacın var
  1. PlayStation 5 Slim Fan Replacement, Prepare your PlayStation for disassembly: adım 1, 3 resimden 1. PlayStation 5 Slim Fan Replacement, Prepare your PlayStation for disassembly: adım 1, 3 resimden 2. PlayStation 5 Slim Fan Replacement, Prepare your PlayStation for disassembly: adım 1, 3 resimden 3.
    • Before starting your repair:
    • Shut down your console.
    • Unplug all cables and accessories.
    • Remove any stands supporting your device.
  2. PlayStation 5 Slim Fan Replacement, Lay your PlayStation down: adım 2, 1 resimden 1.
    • Lay your PlayStation on its side so the right side covers are facing up.
  3. PlayStation 5 Slim Fan Replacement, Remove the fan and SSD cover: adım 3, 3 resimden 1. PlayStation 5 Slim Fan Replacement, Remove the fan and SSD cover: adım 3, 3 resimden 2. PlayStation 5 Slim Fan Replacement, Remove the fan and SSD cover: adım 3, 3 resimden 3.
    • The upper cover is secured with hooks along the back edge and clips along the front edge.
    • Firmly pull up the front edge of the cover to release the clips.
    • You'll hear distinct "pops" as the clips disengage.
    • Remove the cover.
    • To reinstall the cover, place the hooks into their cutouts along the rear edge and firmly press the front edge of the cover into place to re‑engage the two clips.
  4. PlayStation 5 Slim Fan Replacement, Remove the fan cables cover: adım 4, 3 resimden 1. PlayStation 5 Slim Fan Replacement, Remove the fan cables cover: adım 4, 3 resimden 2. PlayStation 5 Slim Fan Replacement, Remove the fan cables cover: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    Tesa 61395 Tape
    $5.99
    Satın Al
    • A piece of plastic covers the fan cables connector.
    • Use your fingers to remove the plastic cover.
    • During reassembly, press the piece of plastic back into place to secure it with the leftover adhesive. If it isn't sticking, use strips of double-sided tape to secure it.
  5. PlayStation 5 Slim Fan Replacement, Free the fan cables: adım 5, 2 resimden 1. PlayStation 5 Slim Fan Replacement, Free the fan cables: adım 5, 2 resimden 2.
    • Gently pull the fan cables out from under their plastic clip on the frame.
  6. PlayStation 5 Slim Fan Replacement, Disconnect the fan: adım 6, 3 resimden 1. PlayStation 5 Slim Fan Replacement, Disconnect the fan: adım 6, 3 resimden 2. PlayStation 5 Slim Fan Replacement, Disconnect the fan: adım 6, 3 resimden 3.
    • Firmly grip the fan cables white connector head and pull it straight up and out of its socket.
    • If you're having trouble, grip the cables just above the connector head, and gently pull.
    • During reassembly, align the connector over its socket and push down on the edges with the flat end of a spudger until it slides fully into its socket.
  7. PlayStation 5 Slim Fan Replacement, Remove the fan screws: adım 7, 2 resimden 1. PlayStation 5 Slim Fan Replacement, Remove the fan screws: adım 7, 2 resimden 2.
    FixMat
    $36.95
    Satın Al
    • Use a T8 Torx Security screwdriver to remove the four screws securing the fan:
    • One 11.6 mm‑long screw
    • One 31.2 mm‑long screw
    • Two 21.3 mm‑long screws
  8. PlayStation 5 Slim Fan Replacement, Remove the fan: adım 8, 2 resimden 1. PlayStation 5 Slim Fan Replacement, Remove the fan: adım 8, 2 resimden 2.
    • Use your fingers to grab the fan by its vents, and lift it straight up to remove it.
    • Lift the fan straight up and remove it.
    • If you're using this guide to clean your fan, use compressed air and a clean cloth to remove any dust or dirt.
    • During reassembly, insert the fan so its cables are near their connector.
Sonuç
Spencer Day
61.610 İtibar
445 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
140 Üyeler
18.077 adet Kılavuz yazıldı
Bir Yorum
Cooling Fan Replacement For Sony PS5 Slim 19 Blades check kasynparts
gameparts - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 28
Son 7 gün: 221
Son 30 gün: 896
Her zaman: 4,425
