Ana içeriğe geç
PowerA Fusion Controller For Xbox One Motherboard Replacement
Neye ihtiyacın var
  1. PowerA Fusion Controller For Xbox One Motherboard Replacement, Vibration Motors: adım 1, 3 resimden 1. PowerA Fusion Controller For Xbox One Motherboard Replacement, Vibration Motors: adım 1, 3 resimden 2. PowerA Fusion Controller For Xbox One Motherboard Replacement, Vibration Motors: adım 1, 3 resimden 3.
    • Remove the nine 9.2mm screws with a JIS #1 screwdriver.
    • Remove the two bottom plastic grip covers.
  2. PowerA Fusion Controller For Xbox One Motherboard Replacement: adım 2, 2 resimden 1. PowerA Fusion Controller For Xbox One Motherboard Replacement: adım 2, 2 resimden 2.
    • Remove the two 9.2mm screws with a JIS #1 screwdriver.
    • Remove the back cover of the controller.
  3. PowerA Fusion Controller For Xbox One Motherboard Replacement: adım 3, 2 resimden 1. PowerA Fusion Controller For Xbox One Motherboard Replacement: adım 3, 2 resimden 2.
    • Take off the glue that is on top of the soldered joints with a sprudger.
    • Desolder the soldered joints of the red and black wires that are connecting the vibration motors to the motherboard.
    • Remove the vibration motors and put them aside.
    • This guide will show how to solder and desolder connections.
  4. PowerA Fusion Controller For Xbox One Motherboard Replacement, Motherboard: adım 4, 3 resimden 1. PowerA Fusion Controller For Xbox One Motherboard Replacement, Motherboard: adım 4, 3 resimden 2. PowerA Fusion Controller For Xbox One Motherboard Replacement, Motherboard: adım 4, 3 resimden 3.
    • Remove the five 9.2mm screws with a JIS #1 screwdriver. Indicated by the red circles.
    • Lift the motherboard and let it hang.
  5. PowerA Fusion Controller For Xbox One Motherboard Replacement: adım 5, 2 resimden 1. PowerA Fusion Controller For Xbox One Motherboard Replacement: adım 5, 2 resimden 2.
    • Remove the four 9.2mm screws that are holding the D-Pad to the controller housing. Indicated by the red circles.
    • Remove the motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Andrea
668 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S14-G4, Boczar Fall 2017 USF Tampa, Team S14-G4, Boczar Fall 2017 üyesi
USFT-BOCZAR-F17S14G4
4 Üyeler
7 adet Kılavuz yazıldı
1Rehber Yorum
Hi I have a powera fusion controler model CPFA115315-02 and I took the controller apart to clean and I forgot how the lb rb button springs go, I look on the internet and couldn't find anything. Any help would be great
Thanks
Nhgamer - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 13
Son 30 gün: 50
Her zaman: 3,593
