Ana içeriğe geç
ProtoCentre 999 Thermistor Replacement
abhishek j
abhishek j ve 3 diğer katkıda bulunanlar
En son February 8, 2023 tarihinde güncellendi
Tahmin yok
Orta
Gramer Polisi
Daha Fazla Görsel Gerekli
Topluluk-Katkılı Kılavuz
Daha iyi giriş
Neye ihtiyacın var
Aletler
    • Check the nozzle and bed temperature after power on the machine. Both temperature should be in between 30 to 40 degree before preheat. It is the room temperature.
    • If the temperature showing is below or too much above the room temperature, that means that any problem in heater or thermistor.
    • Remove the thermistor connection from the printer board of the nozzle.Remove the wire connector of the thermistor.
    • Take a multimeter and connect in the thermistors two leg by putting the multimeter knob into resistance value.
    • If the thermistor is showing a value of above 60 ohm means, it is working. Else you have to change the thermistor and connect it back in the same way. And go to next step.
    • Take the connecting wire of thermistor with connector at one end.
    • Take the multimeter, connect the prob of multimeter on the two ends of the wire and also go for continuity test option in the multimeter.
    • If it is having continuity, the multimeter will produce a beep sound, else we can understand the wire has to be changed.
    • After checking these things , reconnect the thermistor connection.
    • Now go to prepare
    • click preheat
    • Go to main menu, you can see the temperature is increasing or not.
    • If it is incresing, it means the nozzle is working.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
abhishek j
1.193 İtibar
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 181
