Ana içeriğe geç
Prusa i3 MK3 X-Axis Bearings Replacement
Cade SmithMartin
Cade SmithMartin ve 3 diğer katkıda bulunanlar
En son May 23, 2024 tarihinde güncellendi
25 dakika
Orta
If the X-axis bearings in your PRUSA i3 MK3 are worn and need to be replaced they might make noise and prevent the extruder assembly from moving smoothly. If you need to replace the X-axis bearings in your PRUSA i3 MK3, follow the steps in this guide. Ensure that you do not lose any of the parts or socket head screws that are removed during replacement.
  1. Prusa i3 MK3 X-Axis Bearings Replacement, X-Axis Belt: adım 1, 3 resimden 1. Prusa i3 MK3 X-Axis Bearings Replacement, X-Axis Belt: adım 1, 3 resimden 2. Prusa i3 MK3 X-Axis Bearings Replacement, X-Axis Belt: adım 1, 3 resimden 3.
    • Orient the printer so that the screen is facing to the left.
    • Using the On/Off button, switch the printer into the Off position.
    • Ensure your printer is off by visually inspecting the screen. If the screen is not lit up, your printer is off.
    • Ensure the printer has cooled to room temperature before beginning disassembly.
  2. Prusa i3 MK3 X-Axis Bearings Replacement: adım 2, 3 resimden 1. Prusa i3 MK3 X-Axis Bearings Replacement: adım 2, 3 resimden 2. Prusa i3 MK3 X-Axis Bearings Replacement: adım 2, 3 resimden 3.
    • Orient the printer so that the screen is facing away from you.
    • Remove the five 2.5mm X 10mm socket head screws on the back of the extruder assembly.
    • Remove the back cover and pull it away from the extruder assembly. Do not put too much tension on the wires.
  3. Prusa i3 MK3 X-Axis Bearings Replacement: adım 3, 3 resimden 1. Prusa i3 MK3 X-Axis Bearings Replacement: adım 3, 3 resimden 2. Prusa i3 MK3 X-Axis Bearings Replacement: adım 3, 3 resimden 3.
    • Orient the printer so that the screen is facing you.
    • Loosen the 2.5mm X 18mm tension set screw.
    • Loosen the two 2.5mm X 18mm socket head screws on the right, holding on to the X-axis motor.
    • Slightly loosen the 2.5mm X 18mm pivot screw on the left. This screw will act as a pivot for the X-axis motor.
    • Pivot the motor to release the tension on the belt.
  4. Prusa i3 MK3 X-Axis Bearings Replacement: adım 4, 2 resimden 1. Prusa i3 MK3 X-Axis Bearings Replacement: adım 4, 2 resimden 2.
    • Loosen the 2.5mm X 18mm and 2.5mm X 30mm socket head screws that hold the belt in. You do not need to remove these screws.
    • Remove the belt from the belt grips by pulling the belt towards you.
    • Un-feed the belt from its track. The belt should now be removed.
  5. Prusa i3 MK3 X-Axis Bearings Replacement: adım 5, 1 resimden 1.
    • During reassembly, ensure proper tension on the belt before reattaching the back cover of the extruder assembly.
    • With the extruder assembly positioned in the center of the X-axis rails, press the top of the belt with moderate pressure. The top of the belt should not be able to touch the bottom of the belt.
  6. Prusa i3 MK3 X-Axis Bearings Replacement, X-Axis Carriage: adım 6, 2 resimden 1. Prusa i3 MK3 X-Axis Bearings Replacement, X-Axis Carriage: adım 6, 2 resimden 2.
    • Remove the two 2.5mm X 10mm socket head screws that secure the Z-axis rod and screw bracket. Do this for both brackets.
  7. Prusa i3 MK3 X-Axis Bearings Replacement: adım 7, 2 resimden 1. Prusa i3 MK3 X-Axis Bearings Replacement: adım 7, 2 resimden 2.
    • Lift the X-axis carriage off of the Z-axis rod and screw.
    • The X-axis motor can be removed and placed to the side for easier disassembly.
    • Be careful not to damage any of the wiring.
  8. Prusa i3 MK3 X-Axis Bearings Replacement, X-Axis Bearings: adım 8, 3 resimden 1. Prusa i3 MK3 X-Axis Bearings Replacement, X-Axis Bearings: adım 8, 3 resimden 2. Prusa i3 MK3 X-Axis Bearings Replacement, X-Axis Bearings: adım 8, 3 resimden 3.
    • Place the X-axis carriage on the build plate and orient it so that the front of the extruder assembly is facing you.
    • Hold the X-axis rods and pull the rod mounting bracket off of the right side of the carriage assembly.
    • Carefully slide the extruder assembly to the right off of the X-axis rods.
  9. Prusa i3 MK3 X-Axis Bearings Replacement: adım 9, 2 resimden 1. Prusa i3 MK3 X-Axis Bearings Replacement: adım 9, 2 resimden 2.
    • Place the front of the extruder assembly on the build plate so you can access the back.
    • Locate the X-axis bearings on the back of the extruder assembly.
    • Remove the lower bearing; it is not secured by zip ties.
  10. Prusa i3 MK3 X-Axis Bearings Replacement: adım 10, 3 resimden 1. Prusa i3 MK3 X-Axis Bearings Replacement: adım 10, 3 resimden 2. Prusa i3 MK3 X-Axis Bearings Replacement: adım 10, 3 resimden 3.
    • Use the side cutters to cut the existing zip ties.
    • Pull the zip ties out of the housing and discard.
    • Remove the top two bearings from the extruder assembly.
  11. Prusa i3 MK3 X-Axis Bearings Replacement: adım 11, 3 resimden 1. Prusa i3 MK3 X-Axis Bearings Replacement: adım 11, 3 resimden 2. Prusa i3 MK3 X-Axis Bearings Replacement: adım 11, 3 resimden 3.
    • During reassembly, grease the X-axis bearings with the PRUSA Lubricant Applicator.
    • When reinstalling the X-axis bearings, the balls inside the bearings should form a diagonal "X", not a vertical "+".
  12. Prusa i3 MK3 X-Axis Bearings Replacement: adım 12, 3 resimden 1. Prusa i3 MK3 X-Axis Bearings Replacement: adım 12, 3 resimden 2. Prusa i3 MK3 X-Axis Bearings Replacement: adım 12, 3 resimden 3.
    • During reassembly, slide the zip ties back into the slots of the housing and tighten them to secure the top two bearings.
Sonuç
To reassemble your device, follow these instructions in reverse order. Use steps 10 and 11 for reference.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 16
Her zaman: 160
