Giriş
This guide will illustrate how to remove the motherboard.
Neye ihtiyacın var
Remove the two 5mm screws from the bottom of the device using a Phillips #000 screwdriver.
Desolder the wire connected from the speaker to the motherboard.
Pry the speaker from the casing with a plastic opening tool.
Use the spudger to lift up the black tab on all three ZIF connectors.
Use tweezers to remove the ribbon cables from the zift connectors.
6 farklı kişi bu kılavuzu tamamladı.
