Ana içeriğe geç
RIDGID R84015 X2 Disassembly
Brian
Brian ve 6 diğer katkıda bulunanlar
En son April 29, 2020 tarihinde güncellendi
5 dakika
Orta
Follow these steps to disassemble the plastic casing of the RIDGID R84015 X2 power drill.
Neye ihtiyacın var
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. RIDGID R84015 X2 Disassembly, RIDGID R84015 X2 Case Removal: adım 1, 2 resimden 1. RIDGID R84015 X2 Disassembly, RIDGID R84015 X2 Case Removal: adım 1, 2 resimden 2.
    • Remove the backplate.
    • Using a Torx T20 screwdriver, remove the four screws attaching the back plate.
  2. RIDGID R84015 X2 Disassembly: adım 2, 1 resimden 1.
    • Remove the drill handle.
    • Using the Phillips #2 screwdriver, remove the five screws attaching the drill handle to the body.
  3. RIDGID R84015 X2 Disassembly: adım 3, 2 resimden 1. RIDGID R84015 X2 Disassembly: adım 3, 2 resimden 2.
    • Remove the gear casing from the body.
    • Using the Philips #2 screwdriver, remove the four screws attaching the gear casing to the body.
  4. RIDGID R84015 X2 Disassembly, RIDGID R84015 X2 Disassembly: adım 4, 1 resimden 1.
    • With your drill taken apart, move your attention to the trigger and forward reverse switch.
  5. RIDGID R84015 X2 Disassembly: adım 5, 1 resimden 1.
    • Check to see that the forward reverse switch isn't broken.
    • NOTE: small tab on trigger fits into groove on forward reverse switch
  6. RIDGID R84015 X2 Disassembly: adım 6, 1 resimden 1.
    • With the battery attached, check that the wires work when the trigger is pulled.
    • Put multimeter wires here.
    • If wires work and drill doesn't, the problem is with the motor.
  7. RIDGID R84015 X2 Disassembly: adım 7, 1 resimden 1.
    • Make sure plastic is not broken and switch is not stuck.
Bitiş Çizgisi
2 farklı kişi bu kılavuzu tamamladı.
Brian
100 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 15-48, Garner Spring 2010 Cal Poly, Team 15-48, Garner Spring 2010 üyesi
CPSU-GARNER-S10S15G48
6 Üyeler
10 adet Kılavuz yazıldı
Bir Yorum
I was able to diagnose and fix my problem with my black and decker following your instructions. TY
boxingchaos2011 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 18
Her zaman: 13,778
