Ana içeriğe geç
Razer Blade 15" (2019) Battery Replacement
Neye ihtiyacın var
  1. Razer Blade 15" (2019) Battery Replacement, Prepare your laptop for disassembly: adım 1, 2 resimden 1. Razer Blade 15" (2019) Battery Replacement, Prepare your laptop for disassembly: adım 1, 2 resimden 2.
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables, fully shut down your laptop, and close the lid.
    FixBot'a Sor
  2. Razer Blade 15" (2019) Battery Replacement, Unfasten the back cover: adım 2, 1 resimden 1.
    • Rotate your laptop so the screen hinge is farthest from you.
    • Use a Torx T5 driver to remove the ten 3.8 mm-long screws securing the back cover.
    FixBot'a Sor
  3. Razer Blade 15" (2019) Battery Replacement, Insert an opening pick: adım 3, 3 resimden 1. Razer Blade 15" (2019) Battery Replacement, Insert an opening pick: adım 3, 3 resimden 2. Razer Blade 15" (2019) Battery Replacement, Insert an opening pick: adım 3, 3 resimden 3.
    • Depending on the age and condition of your laptop, the back cover may come off sooner than this guide instructs. If the cover feels loose, remove it at any time.
    • Apply a suction handle to the right edge of the back cover, between the middle screws and the screws closest to you.
    • Pull up on the suction handle to create a small gap between the back cover and the frame.
    • Insert an opening pick into the gap.
    FixBot'a Sor
  4. Razer Blade 15" (2019) Battery Replacement, Angle the opening pick: adım 4, 3 resimden 1. Razer Blade 15" (2019) Battery Replacement, Angle the opening pick: adım 4, 3 resimden 2. Razer Blade 15" (2019) Battery Replacement, Angle the opening pick: adım 4, 3 resimden 3.
    • Angle your opening pick upward, away from the frame. Keep it angled upward as long as it's between the back cover and the frame.
    • Insert your pick up to 10 mm (0.4 in) deep.
    FixBot'a Sor
  5. Razer Blade 15" (2019) Battery Replacement, Free the bottom right corner: adım 5, 3 resimden 1. Razer Blade 15" (2019) Battery Replacement, Free the bottom right corner: adım 5, 3 resimden 2. Razer Blade 15" (2019) Battery Replacement, Free the bottom right corner: adım 5, 3 resimden 3.
    • Slide your opening pick around the bottom right corner of the back cover to free it from the frame.
    FixBot'a Sor
  6. Razer Blade 15" (2019) Battery Replacement, Free the front edge: adım 6, 3 resimden 1. Razer Blade 15" (2019) Battery Replacement, Free the front edge: adım 6, 3 resimden 2. Razer Blade 15" (2019) Battery Replacement, Free the front edge: adım 6, 3 resimden 3.
    • Slide your opening pick along the front edge and around the front left corner of the back cover to free it from the frame.
    FixBot'a Sor
  7. Razer Blade 15" (2019) Battery Replacement, Remove the back cover: adım 7, 3 resimden 1. Razer Blade 15" (2019) Battery Replacement, Remove the back cover: adım 7, 3 resimden 2. Razer Blade 15" (2019) Battery Replacement, Remove the back cover: adım 7, 3 resimden 3.
    • Remove the back cover.
    • Lay the back cover down on its rubber feet to avoid damaging the gray thermal pads on its underside.
    FixBot'a Sor
  8. Razer Blade 15" (2019) Battery Replacement, Soften the battery cable tape adhesive: adım 8, 2 resimden 1. Razer Blade 15" (2019) Battery Replacement, Soften the battery cable tape adhesive: adım 8, 2 resimden 2.
    • Apply a heated iOpener to the battery cable tape for one minute.
    • You can also use a hair dryer—but be careful, as overheating the battery may damage it or create a fire hazard.
    FixBot'a Sor
  9. Razer Blade 15" (2019) Battery Replacement, Peel up the battery cable tape: adım 9, 3 resimden 1. Razer Blade 15" (2019) Battery Replacement, Peel up the battery cable tape: adım 9, 3 resimden 2. Razer Blade 15" (2019) Battery Replacement, Peel up the battery cable tape: adım 9, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Be careful not to damage the battery with your tool.
    • Use blunt nose tweezers or your fingers to peel the battery cable tape away from the cable.
    FixBot'a Sor
  10. Razer Blade 15" (2019) Battery Replacement, Disconnect the battery: adım 10, 3 resimden 1. Razer Blade 15" (2019) Battery Replacement, Disconnect the battery: adım 10, 3 resimden 2. Razer Blade 15" (2019) Battery Replacement, Disconnect the battery: adım 10, 3 resimden 3.
    • Use the point of a spudger to press on alternating sides of the battery connector and walk it out of its socket.
    FixBot'a Sor
  11. Razer Blade 15" (2019) Battery Replacement, Disconnect the hard drive: adım 11, 2 resimden 1. Razer Blade 15" (2019) Battery Replacement, Disconnect the hard drive: adım 11, 2 resimden 2.
    • Grab the pull tab on the hard drive press connector, just below the right fan.
    • Pull up and disconnect the connector from its socket.
    • During reassembly, align the press connector over its socket and press down until it clicks into place. If it doesn't connect, re-align it and try again.
    FixBot'a Sor
  12. Razer Blade 15" (2019) Battery Replacement, Unfasten the hard drive mounts: adım 12, 2 resimden 1. Razer Blade 15" (2019) Battery Replacement, Unfasten the hard drive mounts: adım 12, 2 resimden 2.
    • Use your Phillips screwdriver to remove the four screws securing the hard drive mounts:
    • Three 3.2 mm screws
    • One 5.2 mm screw
    FixBot'a Sor
  13. Razer Blade 15" (2019) Battery Replacement, Remove the hard drive: adım 13, 2 resimden 1. Razer Blade 15" (2019) Battery Replacement, Remove the hard drive: adım 13, 2 resimden 2.
    • Lift the hard drive straight up to remove it.
    FixBot'a Sor
  14. Razer Blade 15" (2019) Battery Replacement, Remove the hard drive adapter: adım 14, 3 resimden 1. Razer Blade 15" (2019) Battery Replacement, Remove the hard drive adapter: adım 14, 3 resimden 2. Razer Blade 15" (2019) Battery Replacement, Remove the hard drive adapter: adım 14, 3 resimden 3.
    • If your laptop doesn't have a hard drive, you need to remove the adapter to access the battery. If you just removed your hard drive, skip this step.
    • Grab the hard drive adapter on the left edge of the battery.
    • Peel the adapter and its tape from the battery and set it aside.
    FixBot'a Sor
  15. Razer Blade 15" (2019) Battery Replacement, Free the battery cable: adım 15, 3 resimden 1. Razer Blade 15" (2019) Battery Replacement, Free the battery cable: adım 15, 3 resimden 2. Razer Blade 15" (2019) Battery Replacement, Free the battery cable: adım 15, 3 resimden 3.
    • Unclip the battery cable from the top and right tabs of the battery.
    FixBot'a Sor
  16. Razer Blade 15" (2019) Battery Replacement, Unfasten the battery: adım 16, 1 resimden 1.
    • Use your Phillips screwdriver to remove the five 5.2 mm screws securing the battery.
    FixBot'a Sor
  17. Razer Blade 15" (2019) Battery Replacement, Remove the battery: adım 17, 3 resimden 1. Razer Blade 15" (2019) Battery Replacement, Remove the battery: adım 17, 3 resimden 2. Razer Blade 15" (2019) Battery Replacement, Remove the battery: adım 17, 3 resimden 3.
    • Lift the top edge of the battery from its recess in the frame and remove it.
    FixBot'a Sor
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Clay Eickemeyer
103.179 İtibar
476 adet Kılavuz yazıldı
Ekip
Guide Team Guide Team üyesi
Staff
10 Üyeler
17.783 adet Kılavuz yazıldı
1Rehber Yorum
I just completed the battery replacement. The guide was helpful, even though I must say that I do not really agree with the moderate rating, as it really is super easy! I definitely recommend the essential toolkit, as T4 bits can be hard to find and the one that is included is sturdier than the other ones that I have used so far.
Bogos - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 67
Son 30 gün: 323
Her zaman: 15,671
