Razer Blade 15" (2019) CMOS Battery Replacement
Giriş
1. adıma gitUse this guide to replace the CMOS battery in your Razer Blade 15" (2019).
If your laptop shows a BIOS configuration screen every time it's powered on, the CMOS battery may have died. Replace the CMOS battery to retain certain boot settings on your laptop.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
Unplug all cables, fully shut down your laptop, and close the lid.
Rotate your laptop so the screen hinge is farthest from you.
Use a Torx T5 driver to remove the ten 3.8 mm-long screws securing the back cover.
Apply a suction handle to the right edge of the back cover, between the middle screws and the screws closest to you.
Pull up on the suction handle to create a small gap between the back cover and the frame.
Insert an opening pick into the gap.
Angle your opening pick upward, away from the frame. Keep it angled upward as long as it's between the back cover and the frame.
Insert your pick up to 10 mm (0.4 in) deep.
Slide your opening pick around the bottom right corner of the back cover to free it from the frame.
Slide your opening pick along the front edge and around the front left corner of the back cover to free it from the frame.
Remove the back cover.
Lay the back cover down on its rubber feet to avoid damaging the gray thermal pads on its underside.
Apply a heated iOpener to the battery cable tape for one minute.
Bu adımda kullanılan alet:Tweezers$4.99
Use blunt nose tweezers or your fingers to peel the battery cable tape away from the cable.
Use the point of a spudger to press on alternating sides of the battery connector and walk it out of its socket.
Use the point of your spudger to press on alternating sides of the CMOS battery connector to "walk" it out of its socket and disconnect it.
Slide an opening pick under the CMOS battery.
Use your pick to pry up the CMOS battery from the motherboard and separate the adhesive securing it.
Bu adımda kullanılan alet:Tesa 61395 Tape$6.99
Remove the CMOS battery.
Bir Yorum
This is super helpful, so thank you! Just out of curiosity, what is the point of disconnecting the main battery before removing the CMOS battery?
