Giriş
Over time, lithium-ion batteries inevitably degrade, dramatically reducing their lifespan. The higher operating temperatures in gaming laptops speeds up their degradation; if you've been using your Razer Blade RZ09-0130 2015 for more than a couple years, and the battery life is either very short, or it can't even run while unplugged, it's definitely time for a replacement.
Before beginning these guide, make sure that the system is shut down, unplugged, and that there is no static build up on your person.
If you find your battery is swollen, take extreme caution in removal, and dispose of your battery through the proper channels.
Neye ihtiyacın var
Use a Torx T5 screwdriver to remove the ten 3 mm screws along the edge of the back panel.
