Ana içeriğe geç
Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement
JMason
JMason ve 2 diğer katkıda bulunanlar
En son March 7, 2024 tarihinde güncellendi
30 - 50 dakika
Zor
After extensive use or a large period of time, the Razer Deathadder Essential’s (Model Number: RZ01-0254) mouse buttons may begin to double-click. Double-clicking is when the user only gives one input but receives 2 outputs.
In this guide, I will show you how to replace the buttons so that they will be brand new!
Before getting started, if you are unfamiliar with how to solder and desolder components from a motherboard, please read this guide.
Neye ihtiyacın var
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement, Mouse Buttons: adım 1, 2 resimden 1. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement, Mouse Buttons: adım 1, 2 resimden 2.
    • Use a spudger or opening tool to remove the top skates from the mouse.
    • Poke a hole in the middle of the bar code to expose the 3 screws holding the mouse together.
  2. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: adım 2, 1 resimden 1.
    • Use a Phillips #1 screwdriver to remove the three 9 mm screws that are holding the mouse together.
  3. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: adım 3, 3 resimden 1. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: adım 3, 3 resimden 2. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: adım 3, 3 resimden 3.
    • Open the mouse, and use the Phillips #1 screwdriver remove the two 11 mm screws that are located on the left side of the motherboard.
    • Also, remove the single 4 mm screw next to the mouse wheel using the Phillips #1 screwdriver.
    • After you remove all three screws the motherboard should be free.
  4. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: adım 4, 2 resimden 1. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: adım 4, 2 resimden 2.
    • This is the component that we will be replacing and its 3 contact points.
  5. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    Desoldering Pump
    $3.99
    • Using your soldering iron and desoldering pump, desolder the 3 contact points that attach to each button as marked.
    • Be careful when using a soldering iron, as it can burn you if not used correctly.
  6. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: adım 6, 3 resimden 1. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: adım 6, 3 resimden 2. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: adım 6, 3 resimden 3.
    • Remove the button that you just desoldered.
    • Then solder the new button back into place. Repeat for both buttons.
  7. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: adım 7, 3 resimden 1. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: adım 7, 3 resimden 2. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: adım 7, 3 resimden 3.
    • Return the motherboard to its original position, and replace the two 11 mm screws and the single 4 mm screw using a Phillips #1 screwdriver.
  8. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: adım 8, 1 resimden 1.
    • Close up the mouse, and replace the three 9 mm using a Phillips #1 screwdriver.
  9. Razer Deathadder Essential RZ01-0254 Mouse Buttons Replacement: adım 9, 1 resimden 1.
    • Finally, replace the skates and you are finished.
Bitiş Çizgisi
5 farklı kişi bu kılavuzu tamamladı.
2Kılavuz Yorumları
you helped me a lot
Gustavo Melo Santos - Yanıt
My scroll wheel was totally messed up, when I would scroll in down, it would randomly scroll up for for a split second, and vice versa. This guide was super helpful in figuring out how to take apart the mouse and clean out the scroll wheel sensor, which turned out to have a ton of cat hair wrapped around the axle.
Chris Etler - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 54
Son 30 gün: 257
Her zaman: 9,858
