Ana içeriğe geç
Razer Wolverine V3 Pro Battery Replacement
Neye ihtiyacın var
    1. Razer Wolverine V3 Pro Battery Replacement, Outer Shell: adım 1, 3 resimden 1. Razer Wolverine V3 Pro Battery Replacement, Outer Shell: adım 1, 3 resimden 2. Razer Wolverine V3 Pro Battery Replacement, Outer Shell: adım 1, 3 resimden 3.
      • Insert the end of a spudger or opening tool in the seam at the top of the controller.
      • Slide it around the edge to release the retaining clips.
      • Use the spudger to separate the front and back plastic outer shell of the controller.
      • Both panels should separate from the front of the bumpers.
      • This takes some patience to ensure the panels don’t crack.
      • Flip the controller so the bottom is facing up.
      • Use the spudger to separate the plastic covering on the hand grips.
      FixBot'a Sor
      Yorum Ekle
    2. Razer Wolverine V3 Pro Battery Replacement: adım 2, 2 resimden 1. Razer Wolverine V3 Pro Battery Replacement: adım 2, 2 resimden 2.
      • Use a JIS #0 screwdriver to remove ten 10 mm screws from the mid-frame.
      • Keep screws organized.
      FixBot'a Sor
      Yorum Ekle
    3. Razer Wolverine V3 Pro Battery Replacement: adım 3, 2 resimden 1. Razer Wolverine V3 Pro Battery Replacement: adım 3, 2 resimden 2.
      • Use your hands to pry the back panel of the controller.
      • You now have access to the back buttons (2 on each side).
      FixBot'a Sor
      Yorum Ekle
    4. Razer Wolverine V3 Pro Battery Replacement: adım 4, 2 resimden 1. Razer Wolverine V3 Pro Battery Replacement: adım 4, 2 resimden 2.
      • Remove the two JIS #0 scews securing the battery.
      FixBot'a Sor
      Yorum Ekle
    5. Razer Wolverine V3 Pro Battery Replacement: adım 5, 2 resimden 1. Razer Wolverine V3 Pro Battery Replacement: adım 5, 2 resimden 2.
      • Lift the actuators out of the way to access the screws beneath.
      • Use a Phillips #0 screwdriver to remove the two 6.9 mm screws under the voice coil actuators.
      FixBot'a Sor
      Yorum Ekle
    6. Razer Wolverine V3 Pro Battery Replacement: adım 6, 1 resimden 1.
      • Remove the face cover from the controller.
      • The buttons may fall out in the process of removing the face cover. Be careful to not to lose them.
      • Now you have access to the internal components of the controller.
      FixBot'a Sor
      Yorum Ekle
    1. Razer Wolverine V3 Pro Battery Replacement, Battery: adım 7, 2 resimden 1. Razer Wolverine V3 Pro Battery Replacement, Battery: adım 7, 2 resimden 2.
      • The battery is the black rectangle shown in this figure.
      • Use a JIS #0 screwdriver to remove six screws.
      • One at each corner [6 mm].
      • One in the middle of the battery [3mm].
      • One right above the battery [4 mm].
      FixBot'a Sor
      Yorum Ekle
    2. Razer Wolverine V3 Pro Battery Replacement: adım 8, 3 resimden 1. Razer Wolverine V3 Pro Battery Replacement: adım 8, 3 resimden 2. Razer Wolverine V3 Pro Battery Replacement: adım 8, 3 resimden 3.
      • Use the spudger to gently disconnect the small circuit board on top of the battery cover.
      • Use the angled tweezers to pull the white JST connectors out of their sockets.
      FixBot'a Sor
      Yorum Ekle
    3. Razer Wolverine V3 Pro Battery Replacement: adım 9, 3 resimden 1. Razer Wolverine V3 Pro Battery Replacement: adım 9, 3 resimden 2. Razer Wolverine V3 Pro Battery Replacement: adım 9, 3 resimden 3.
      • Remove the battery from the controller.
      • The battery is glued to the black cover.
      FixBot'a Sor
      Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
2 farklı kişi bu kılavuzu tamamladı.
Malik Sharif
337 İtibar
3 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 32
Son 30 gün: 100
Her zaman: 218
