Ana içeriğe geç
Redmi Note 9 Pro Loudspeaker Replacement
Neye ihtiyacın var
  1. Redmi Note 9 Pro Loudspeaker Replacement, Heat the rear glass: adım 1, 1 resimden 1.
    • Prepare an iOpener and apply it to the rear glass for at least two minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    FixBot'a Sor
    Yorum Ekle
  2. Redmi Note 9 Pro Loudspeaker Replacement, Insert an opening pick: adım 2, 3 resimden 1. Redmi Note 9 Pro Loudspeaker Replacement, Insert an opening pick: adım 2, 3 resimden 2. Redmi Note 9 Pro Loudspeaker Replacement, Insert an opening pick: adım 2, 3 resimden 3.
    • Secure a suction handle to the bottom edge of the rear glass, as close to the edge as possible.
    • If the rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the rear glass with the suction handle to create a small gap between the back cover and the frame.
    • In case you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap you created.
    • Slide the opening pick to the bottom right corner to slice the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
    FixBot'a Sor
    Yorum Ekle
  3. Redmi Note 9 Pro Loudspeaker Replacement, Slice the adhesive: adım 3, 2 resimden 1. Redmi Note 9 Pro Loudspeaker Replacement, Slice the adhesive: adım 3, 2 resimden 2.
    • Insert a second opening pick at the bottom edge of your phone.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
    FixBot'a Sor
    Yorum Ekle
  4. Redmi Note 9 Pro Loudspeaker Replacement, Slice the adhesive: adım 4, 3 resimden 1. Redmi Note 9 Pro Loudspeaker Replacement, Slice the adhesive: adım 4, 3 resimden 2. Redmi Note 9 Pro Loudspeaker Replacement, Slice the adhesive: adım 4, 3 resimden 3.
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener for one to two minutes to reheat it.
    • Insert a third opening pick at the bottom left corner of your phone.
    • Slide the opening pick along the left edge of your phone to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
    FixBot'a Sor
    Yorum Ekle
  5. Redmi Note 9 Pro Loudspeaker Replacement: adım 5, 2 resimden 1. Redmi Note 9 Pro Loudspeaker Replacement: adım 5, 2 resimden 2.
    • Insert a fourth opening pick underneath the top left corner of your phone.
    • Slide the opening pick along the top edge to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
    FixBot'a Sor
    Yorum Ekle
  6. Redmi Note 9 Pro Loudspeaker Replacement: adım 6, 2 resimden 1. Redmi Note 9 Pro Loudspeaker Replacement: adım 6, 2 resimden 2.
    • Insert a fifth opening pick underneath the top right corner.
    • Slide the opening pick along the right edge of the rear glass to slice the remaining adhesive.
    FixBot'a Sor
    Yorum Ekle
  7. Redmi Note 9 Pro Loudspeaker Replacement, Remove the rear glass: adım 7, 2 resimden 1. Redmi Note 9 Pro Loudspeaker Replacement, Remove the rear glass: adım 7, 2 resimden 2.
    • Remove the rear glass.
    • Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • Secure the new rear glass with pre-cut adhesive or double-sided adhesive tape. After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
    FixBot'a Sor
    Yorum Ekle
  8. Redmi Note 9 Pro Loudspeaker Replacement, Unfasten the motherboard cover screws: adım 8, 1 resimden 1.
    • Use a Phillips screwdriver to remove the eleven 3.9 mm-long screws securing the motherboard cover.
    FixBot'a Sor
    Yorum Ekle
  9. Redmi Note 9 Pro Loudspeaker Replacement, Pry up the motherboard cover: adım 9, 2 resimden 1. Redmi Note 9 Pro Loudspeaker Replacement, Pry up the motherboard cover: adım 9, 2 resimden 2.
    • Insert the tip of an opening pick underneath the left edge of the motherboard cover.
    • Flip the opening pick sideways to pry up the motherboard cover.
    FixBot'a Sor
    Yorum Ekle
  10. Redmi Note 9 Pro Loudspeaker Replacement, Remove the motherboard cover: adım 10, 2 resimden 1. Redmi Note 9 Pro Loudspeaker Replacement, Remove the motherboard cover: adım 10, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use a pair of tweezers or your fingers to remove the motherboard cover.
    FixBot'a Sor
    Yorum Ekle
  11. Redmi Note 9 Pro Loudspeaker Replacement, Disconnect the battery cable: adım 11, 2 resimden 1. Redmi Note 9 Pro Loudspeaker Replacement, Disconnect the battery cable: adım 11, 2 resimden 2.
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
    FixBot'a Sor
    Yorum Ekle
  12. Redmi Note 9 Pro Loudspeaker Replacement, Unfasten the loudspeaker assembly screws: adım 12, 1 resimden 1.
    • Use a Phillips screwdriver to remove the seven 3.9 mm-long screws securing the loudspeaker assembly.
    FixBot'a Sor
    Yorum Ekle
  13. Redmi Note 9 Pro Loudspeaker Replacement, Pry up the loudspeaker assembly: adım 13, 2 resimden 1. Redmi Note 9 Pro Loudspeaker Replacement, Pry up the loudspeaker assembly: adım 13, 2 resimden 2.
    • Insert an opening pick into the gap between the top edge of the loudspeaker assembly and the battery.
    • Use your opening pick to pry up the loudspeaker assembly.
    FixBot'a Sor
    Yorum Ekle
  14. Redmi Note 9 Pro Loudspeaker Replacement, Remove the loudspeaker assembly: adım 14, 2 resimden 1. Redmi Note 9 Pro Loudspeaker Replacement, Remove the loudspeaker assembly: adım 14, 2 resimden 2.
    • Remove the loudspeaker assembly.
    • During reassembly apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    FixBot'a Sor
    Yorum Ekle
Sonuç
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
6 farklı kişi bu kılavuzu tamamladı.
Dominik Schnabelrauch
260.405 İtibar
682 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
122 Üyeler
26.617 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 23
Son 30 gün: 153
Her zaman: 5,977
