Ana içeriğe geç
Removing the HP Elitebook 6930p Hard Drive
Richdave
Richdave ve 2 diğer katkıda bulunanlar
En son November 15, 2022 tarihinde güncellendi
5 dakika
Çok kolay
Topluluk-Katkılı Kılavuz
This guide shows how to remove the laptop HDD
Neye ihtiyacın var
  1. Removing the HP Elitebook 6930p Hard Drive, Battery Removal: adım 1, 3 resimden 1. Removing the HP Elitebook 6930p Hard Drive, Battery Removal: adım 1, 3 resimden 2. Removing the HP Elitebook 6930p Hard Drive, Battery Removal: adım 1, 3 resimden 3.
    • Flip laptop over and locate the battery release button
    • Push release button to the left to release battery and gently pull battery from the laptop
  2. Removing the HP Elitebook 6930p Hard Drive, Hard Drive: adım 2, 3 resimden 1. Removing the HP Elitebook 6930p Hard Drive, Hard Drive: adım 2, 3 resimden 2. Removing the HP Elitebook 6930p Hard Drive, Hard Drive: adım 2, 3 resimden 3.
    • With the bottom of the laptop facing up and the front toward you locate and loosen the two M2.0×5.0 captive screws holding the hard drive bay cover closed.
    • Lift the left side of the bay cover and swing it up and to the right to remove it.
    • Loosen the M2.5×10.0 captive screw that holds the hard drive in.
    • Grasp the plastic tab and slide the hard drive to the right to disconnect it from the motherboard.
    • Lift the hard drive straight up and out of the laptop.
  3. Removing the HP Elitebook 6930p Hard Drive: adım 3, 2 resimden 1. Removing the HP Elitebook 6930p Hard Drive: adım 3, 2 resimden 2.
    • To remove the hard drive from the bracket remove the two M3.0×4.0 screws from each side of the hard drive.
Sonuç
17 farklı kişi bu kılavuzu tamamladı.
Richdave
32.371 İtibar
30 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
327 Üyeler
1.699 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 28
Her zaman: 9,970
