Ana içeriğe geç
Removing the HP Elitebook 6930p Keyboard
Richdave
Richdave ve başka bir katkıda bulunan
En son June 23, 2022 tarihinde güncellendi
10 dakika
Orta
Topluluk-Katkılı Kılavuz
This guide will show you how to remove the keyboard
Neye ihtiyacın var
Aletler
  1. Removing the HP Elitebook 6930p Keyboard, Battery Removal: adım 1, 3 resimden 1. Removing the HP Elitebook 6930p Keyboard, Battery Removal: adım 1, 3 resimden 2. Removing the HP Elitebook 6930p Keyboard, Battery Removal: adım 1, 3 resimden 3.
    • Flip laptop over and locate the battery release button
    • Push release button to the left to release battery and gently pull battery from the laptop
  2. Removing the HP Elitebook 6930p Keyboard, Keyboard: adım 2, 3 resimden 1. Removing the HP Elitebook 6930p Keyboard, Keyboard: adım 2, 3 resimden 2. Removing the HP Elitebook 6930p Keyboard, Keyboard: adım 2, 3 resimden 3.
    • Loosen the three Phillips 2.5×9.0 captive screws that secure the keyboard to the laptop
    • Turn the laptop so the keyboard is facing up and locate the 4 retention tabs along the back edge of the keyboard
    • Slide the retention clips toward the keyboard to release the keyboard
  3. Removing the HP Elitebook 6930p Keyboard: adım 3, 3 resimden 1. Removing the HP Elitebook 6930p Keyboard: adım 3, 3 resimden 2. Removing the HP Elitebook 6930p Keyboard: adım 3, 3 resimden 3.
    • Use a plastic pry tool to lift the rear edge of the keyboard.
    • Pull the keyboard slightly towards the display to disengage the tabs along the front of the keyboard from the laptop palm rest.
    • Lift the keyboard up to reveal the ribbon connectors
  4. Removing the HP Elitebook 6930p Keyboard: adım 4, 3 resimden 1. Removing the HP Elitebook 6930p Keyboard: adım 4, 3 resimden 2. Removing the HP Elitebook 6930p Keyboard: adım 4, 3 resimden 3.
    • Release the larger ribbon cable by flipping the brown retainer up so it is parallel with the ribbon cable
    • Release the smaller ribbon cable by lifting up the white retainer
    • I found it easier to reinstall both cables with the new keyboard resting on the back edge
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Richdave
32.371 İtibar
30 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
327 Üyeler
1.699 adet Kılavuz yazıldı
2 Yorum
Look easy to remove !! I have a hp elitebook 6930p it need a new keyboard but it hard for me to find one for my elitebook 6930p online they look the same but none of them have the part number i need ! Could i use any hp elitebook 6930p replacement keyboard or were can i find the right keyboard number on the elitebook 6930 i just might be looking at the wrote number ! Need help !!
Daisy - Yanıt
CHICONY
MP-06803U46930 MP-06803US6442
DARFON
9J.N8282.K01 NSK-H4K01
HP COMPAQ
483010-001 90.4V907.S01 9J.N8282.K01 BAHHH3AM2WS0E7
MP-06803U46930 MP-06803US6442 NSK-H4K01 V070530CS1
any of these should work
Keegan -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 31
Her zaman: 10,742
