Ana içeriğe geç
RetroMini Miyoo Mini Plus Battery Replacement
Neye ihtiyacın var
  1. RetroMini Miyoo Mini Plus Battery Replacement, Battery: adım 1, 2 resimden 1. RetroMini Miyoo Mini Plus Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Lay the device face down on a flat surface.
    • You may want to lay the device on a towel or other soft surface to avoid scratching the screen.
  2. RetroMini Miyoo Mini Plus Battery Replacement: adım 2, 2 resimden 1. RetroMini Miyoo Mini Plus Battery Replacement: adım 2, 2 resimden 2.
    • Use your fingernail to push in the battery compartment tab.
    • Lift the cover up to expose the battery.
  3. RetroMini Miyoo Mini Plus Battery Replacement: adım 3, 1 resimden 1.
    • Use an opening tool to gently lift the the battery from its compartment.
    • Gently pull the battery out and set the battery next to the system, with care not to strain the attached wire.
  4. RetroMini Miyoo Mini Plus Battery Replacement: adım 4, 2 resimden 1. RetroMini Miyoo Mini Plus Battery Replacement: adım 4, 2 resimden 2.
    • Pinch the white battery connector and pull it directly out of its socket.
    • Completely remove the battery.
  5. RetroMini Miyoo Mini Plus Battery Replacement: adım 5, 2 resimden 1. RetroMini Miyoo Mini Plus Battery Replacement: adım 5, 2 resimden 2.
    • When you have the new battery, put the new battery wire into the connecter.
    • Place the battery back into the empty space with the wire at the bottom of the battery.
Sonuç
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Steam Deck answers community for help.
Bir başkası bu kılavuzu tamamladı.
Kaden
578 İtibar
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 40
Son 30 gün: 164
Her zaman: 628
