Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement
Giriş
1. adıma gitA sender that is unresponsive in connection mode may indicate a problem with the wireless connection chip within the device. Replacing a faulty chip can help restore the device's function. This guide will help users replace a faulty wireless module chip indicated by an unresponsive connection between the sender and receiver devices.
Neye ihtiyacın var
Remove the 4 rubber tabs on the bottom side of the receiver.
Unscrew the 10 mm screw holding the wireless audio module.
To install the new wireless audio module chip, follow these instructions in reverse order.
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
This is a very long time later, but where do you get the receiver chip??? Rocket fish doesn't support the product anymore
