Roku 3 Remote Control Buttons Replacement
Giriş
1. adıma gitIf your remote control buttons are no longer working effectively, this guide will show you how to replace the buttons on your remote.
Neye ihtiyacın var
Flip the remote over so that the buttons are facing down and the end with the wrist strap is nearest your right hand.
Unscrew one 7 mm Phillips #0 screw from the center of the battery compartment.
4 farklı kişi bu kılavuzu tamamladı.
4Kılavuz Yorumları
Do you have a source for getting replacement buttons? I have volume buttons that don't work and was hoping to fix them/ replace them. Thank you!
Hi Patrick,
I literally just finished successfully fixing my volume-up button.
The replacement part number for the right microswitches is EVQ-P7J01P, available at Digi-Key:
https://www.digikey.com/product-detail/e...
Really inexpensive (around 30 cents each). Pro-tip - to help remove the old switch easily, cut it in half with sharp side-cutters.
Good luck!
Jeff T.
Where can I find a component layout?
Setuproku provides support for all roku related issue. This article help us to understand the Roku remote control.
