Ana içeriğe geç
Ryobi P202 Bit Storage Clip Replacement
Joseph Eckstein
Joseph Eckstein ve 2 diğer katkıda bulunanlar
En son June 24, 2015 tarihinde güncellendi
10 - 15 dakika
Orta
This guide demonstrates how to replace the bit clip located on the lower front portion of the drill above the battery. This guide requires opening the drill, but does not require removing any of the internal electronic components.
Neye ihtiyacın var
Aletler
  1. Ryobi P202 Bit Storage Clip Replacement, Battery: adım 1, 3 resimden 1. Ryobi P202 Bit Storage Clip Replacement, Battery: adım 1, 3 resimden 2. Ryobi P202 Bit Storage Clip Replacement, Battery: adım 1, 3 resimden 3.
    • The battery can shock you. Only touch plastic, non-conductive components.
    • Detach the battery unit from the drill body by pressing the battery release buttons on both sides of the unit and pulling outwards.
  2. Ryobi P202 Bit Storage Clip Replacement, Right Side Case: adım 2, 2 resimden 1. Ryobi P202 Bit Storage Clip Replacement, Right Side Case: adım 2, 2 resimden 2.
    • Use a Torx T10 screw driver to unscrew all ten 13.5 mm screws from the drill casing to gain access to the interior.
  3. Ryobi P202 Bit Storage Clip Replacement: adım 3, 2 resimden 1. Ryobi P202 Bit Storage Clip Replacement: adım 3, 2 resimden 2.
    • Gently lift the casing from the drill body.
    • Take the casing completely off the drill body to gain access to the interior of the drill.
    • The Ryobi P202 casing has Part #: 200690001
  4. Ryobi P202 Bit Storage Clip Replacement, Bit Storage Clip: adım 4, 2 resimden 1. Ryobi P202 Bit Storage Clip Replacement, Bit Storage Clip: adım 4, 2 resimden 2.
    • Grip the bit-clip and gently lift up to remove it from the case.
    • The bit-clip is Part #: 630206007
Sonuç
Joseph Eckstein
1.596 İtibar
9 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-6, Forte Spring 2015 Cal Poly, Team 17-6, Forte Spring 2015 üyesi
CPSU-FORTE-S15S17G6
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 450
