Ana içeriğe geç
Ryobi P411 Motor Replacement
Neye ihtiyacın var
  1. Ryobi P411 Motor Replacement, Pad Assembly: adım 1, 3 resimden 1. Ryobi P411 Motor Replacement, Pad Assembly: adım 1, 3 resimden 2. Ryobi P411 Motor Replacement, Pad Assembly: adım 1, 3 resimden 3.
    • Remove the sanding pad to expose the screws at the bottom of the sander.
    FixBot'a Sor
    Yorum Ekle
  2. Ryobi P411 Motor Replacement: adım 2, 3 resimden 1. Ryobi P411 Motor Replacement: adım 2, 3 resimden 2. Ryobi P411 Motor Replacement: adım 2, 3 resimden 3.
    • Remove the four M5 x 8.9mm screws with a T6 Torx screwdriver.
    • Remove the pad assembly.
    FixBot'a Sor
    Yorum Ekle
  3. Ryobi P411 Motor Replacement, Switch Trigger: adım 3, 3 resimden 1. Ryobi P411 Motor Replacement, Switch Trigger: adım 3, 3 resimden 2. Ryobi P411 Motor Replacement, Switch Trigger: adım 3, 3 resimden 3.
    • Push the switch trigger gently from the back to pull it out from the open face of the sander.
    FixBot'a Sor
    Yorum Ekle
  4. Ryobi P411 Motor Replacement, Switch: adım 4, 3 resimden 1. Ryobi P411 Motor Replacement, Switch: adım 4, 3 resimden 2. Ryobi P411 Motor Replacement, Switch: adım 4, 3 resimden 3.
    • Remove the switch from its housing.
    • Take care not to strain the connected cables.
    FixBot'a Sor
    Yorum Ekle
  5. Ryobi P411 Motor Replacement: adım 5, 3 resimden 1. Ryobi P411 Motor Replacement: adım 5, 3 resimden 2. Ryobi P411 Motor Replacement: adım 5, 3 resimden 3.
    • Use a soldering iron to desolder the two switch connections.
    • If you're unfamiliar with soldering, review this guide.
    FixBot'a Sor
    Yorum Ekle
  6. Ryobi P411 Motor Replacement, Fan and Bearing Cap: adım 6, 3 resimden 1. Ryobi P411 Motor Replacement, Fan and Bearing Cap: adım 6, 3 resimden 2. Ryobi P411 Motor Replacement, Fan and Bearing Cap: adım 6, 3 resimden 3.
    • Remove the rubber brake from the bottom of the sander.
    FixBot'a Sor
    Yorum Ekle
  7. Ryobi P411 Motor Replacement: adım 7, 3 resimden 1. Ryobi P411 Motor Replacement: adım 7, 3 resimden 2. Ryobi P411 Motor Replacement: adım 7, 3 resimden 3.
    • Use a T20 Torx screwdriver to loosen the 15.8 mm screw at the bottom of the sander.
    • Remove the screw and washer.
    FixBot'a Sor
    Yorum Ekle
  8. Ryobi P411 Motor Replacement: adım 8, 3 resimden 1. Ryobi P411 Motor Replacement: adım 8, 3 resimden 2. Ryobi P411 Motor Replacement: adım 8, 3 resimden 3.
    • Remove the fan and bearing cap.
    FixBot'a Sor
    Yorum Ekle
  9. Ryobi P411 Motor Replacement, Motor: adım 9, 3 resimden 1. Ryobi P411 Motor Replacement, Motor: adım 9, 3 resimden 2. Ryobi P411 Motor Replacement, Motor: adım 9, 3 resimden 3.
    • Desolder the motor connections from the switch and power supply.
    • Remove the motor from its housing.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Paula Meier
769 İtibar
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 27
Her zaman: 275
