Giriş
Follow this guide to replace the screen assembly (including the frame) on a Samsung Galaxy A15.
To reassemble the device, you'll need replacement adhesive for the back cover, vibration motor, and earpiece speaker. You'll also need a replacement battery - the old one shouldn't be reused due to potential creasing or other damage during the removal process.
Neye ihtiyacın var
Unplug all cables and completely power off the phone.
Press and hold the power and volume down buttons at the same time to bring up the shutdown menu.
Heat an iOpener and apply it to the right edge of the back cover for two minutes.
Apply a suction handle to the back cover, as close to the center of the right edge as possible.
Pull up on the suction handle with strong, steady force to create a gap between the cover and the frame.
Insert an opening pick into the gap.
Slide the opening pick along the right edge between the back cover and the frame to slice through the adhesive.
Leave the opening pick in the bottom right corner to keep the adhesive from resealing.
Insert an opening pick along the top edge of the phone and twist it gently to unfasten the camera clips.
Slide the opening pick around the edge of the camera modules to unfasten the remaining camera clips.
Once the adhesive around the edges is loose, insert an opening pick deeper into the bottom edge from the bottom left corner.
Slide the pick deeper into the phone across the bottom edge, slicing the remaining adhesive.
Lift and remove the back cover.
Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat and isopropyl alcohol (90% or greater) if you're having trouble removing the adhesive.
If you're using custom-cut adhesives, follow this guide.
If you're using double-sided tape, follow this guide.
Bu adımda kullanılan alet:iFixit Precision 4 mm Screwdriver Bit$2.99
Insert a SIM card eject tool, bit, or a straightened paperclip into the hole on the SIM tray, located towards the top of the phone on the left edge.
Press in firmly to eject the tray and remove it.
Remove the fifteen 4 mm-long screws connecting the frame to the chassis.
Use the flat end of a spudger to pry up and disconnect the fingerprint button press connector from the motherboard.
Flip the phone over so the screen is facing up.
Insert an opening pick between the screen and the SIM card tray cutout to form a gap between the frame and the phone.
Slide the opening pick down the left edge of the device to unfasten the frame clips.
Use the flat end of a spudger to lift up and disconnect the battery press connector from the motherboard.
Insert the flat end of a spudger under the overhang of the top "OCTA" cable connector.
Pry up the top connector away from the bottom one until they're disconnected.
Pick up the interconnect cable and remove it from the phone.
Peel up the blue battery pull tab until you can grab it with your fingers.
With one hand, fold the two upper and lower tabs out of the way of the battery and firmly hold down the frame.
Pull up on the blue battery pull tab with strong, steady force until the battery is separated from its adhesive in the phone.
Completely peel off the remaining battery adhesive attached to the frame of the phone.
Insert the flat end of a spudger underneath the display ribbon connector and pry it off of the board.
Use a Phillips screwdriver to remove the 3 mm-long screw securing the daughterboard to the phone.
Use a Phillips screwdriver to remove the 3 mm-long screw securing the motherboard to the phone.
Grab the motherboard and daughterboard by their edges and pull them together straight up and out of the phone.
Insert one tip of angled tweezers into the gap beneath the vibration motor closest to the bottom of the phone.
Grab the vibration motor with the tweezers and lift it up and out of the phone.
Insert the tip of angled tweezers into the gap next to the earpiece speaker. Get underneath the earpiece speaker and gently pry it up.
Lift the earpiece speaker out of the phone.
45 farklı kişi bu kılavuzu tamamladı.
4Kılavuz Yorumları
Can someone help me figure out where to purchase the OEM screen for Galaxy a15 5g please?
I seen one on Amazon for $85.
Sold by Pishzeo
I bought it on Temu
Cool 🍎 🇨🇮💪
