Ana içeriğe geç
Samsung Galaxy A32 5G Back Cover Replacement
Neye ihtiyacın var
  1. Samsung Galaxy A32 5G Back Cover Replacement, Heat the back cover: adım 1, 1 resimden 1.
    • Prepare an iOpener and apply it to the back cover for at least two minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Samsung Galaxy A32 5G Back Cover Replacement, Insert an opening pick: adım 2, 3 resimden 1. Samsung Galaxy A32 5G Back Cover Replacement, Insert an opening pick: adım 2, 3 resimden 2. Samsung Galaxy A32 5G Back Cover Replacement, Insert an opening pick: adım 2, 3 resimden 3.
    • Secure a suction handle to the bottom edge of the back cover, as close to the edge as possible.
    • If the back cover is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the back cover with the suction handle to create a small gap between the back cover and the frame.
    • In case you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap you created.
    • Slide the opening pick to the bottom right corner to slice the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  3. Samsung Galaxy A32 5G Back Cover Replacement, Slice the adhesive: adım 3, 2 resimden 1. Samsung Galaxy A32 5G Back Cover Replacement, Slice the adhesive: adım 3, 2 resimden 2.
    • Insert a second opening pick at the bottom edge of your phone.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  4. Samsung Galaxy A32 5G Back Cover Replacement, Slice the adhesive: adım 4, 3 resimden 1. Samsung Galaxy A32 5G Back Cover Replacement, Slice the adhesive: adım 4, 3 resimden 2. Samsung Galaxy A32 5G Back Cover Replacement, Slice the adhesive: adım 4, 3 resimden 3.
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener for one to two minutes to reheat it.
    • Insert a third opening pick at the bottom left corner of your phone.
    • Slide the opening pick along the left edge of your phone to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  5. Samsung Galaxy A32 5G Back Cover Replacement: adım 5, 2 resimden 1. Samsung Galaxy A32 5G Back Cover Replacement: adım 5, 2 resimden 2.
    • Insert a fourth opening pick underneath the top left corner of your phone.
    • Slide the opening pick along the top edge to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  6. Samsung Galaxy A32 5G Back Cover Replacement: adım 6, 2 resimden 1. Samsung Galaxy A32 5G Back Cover Replacement: adım 6, 2 resimden 2.
    • Insert a fifth opening pick underneath the top right corner.
    • Slide the opening pick along the right edge of the back cover to slice the remaining adhesive.
  7. Samsung Galaxy A32 5G Back Cover Replacement, Remove the back cover: adım 7, 2 resimden 1. Samsung Galaxy A32 5G Back Cover Replacement, Remove the back cover: adım 7, 2 resimden 2.
    • Remove the back cover.
    • Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • Secure the new back cover with pre-cut adhesive or double-sided adhesive tape. After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
Sonuç
14 farklı kişi bu kılavuzu tamamladı.
Dominik Schnabelrauch
229.657 İtibar
682 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.474 adet Kılavuz yazıldı
5 Yorum
What? Where is the rest of this Manual? There's more to a screen replacement then taking the old screen off? There is also components that still need to be swapped over like the Mother board, the Charge Port, the Cameras etc....
BP 674 - Yanıt
It is only for taking off the BACK. THERE IS ALSO A GUIDE FOR SCREEN REPLACEMENT.
Poli Poli -
I have a question What would cause my bluetooth and my wifi to start randomly stop working after an update from samsung and now i cant goto a further update? or a before update?
Tony Guido - Yanıt
Absolutely useless, just the first step of 20
Family name - Yanıt
Just useless, first step of over 20 steps
Family name - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 11
Son 7 gün: 61
Son 30 gün: 197
Her zaman: 10,016
