Ana içeriğe geç
Samsung Galaxy Book Pro 360 15" Daughterboard Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Book Pro 360 15" Daughterboard Replacement, Access the rubber feet: adım 1, 2 resimden 1. Samsung Galaxy Book Pro 360 15" Daughterboard Replacement, Access the rubber feet: adım 1, 2 resimden 2.
    • Before you begin, shut down your laptop and unplug it.
    • Close the screen and lay your laptop down with the rear case facing up to access the four rubber feet.
  2. Samsung Galaxy Book Pro 360 15" Daughterboard Replacement, Remove the rubber feet: adım 2, 3 resimden 1. Samsung Galaxy Book Pro 360 15" Daughterboard Replacement, Remove the rubber feet: adım 2, 3 resimden 2. Samsung Galaxy Book Pro 360 15" Daughterboard Replacement, Remove the rubber feet: adım 2, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Insert an opening pick between the rear case and the rubber foot.
    • Pry up with the pick and dislodge the foot from the rear case.
    • Use tweezers or your fingers to remove the rubber foot.
    • Repeat this process on the remaining rubber feet.
    • There are two types of rubber feet for this laptop. During reassembly, make sure the top feet say "M4" and the bottom feet say "M1".
    • To reinstall a rubber foot, align it over the recess and push down until it's secured.
  3. Samsung Galaxy Book Pro 360 15" Daughterboard Replacement, Unfasten the rear case: adım 3, 2 resimden 1. Samsung Galaxy Book Pro 360 15" Daughterboard Replacement, Unfasten the rear case: adım 3, 2 resimden 2.
    Magnetic Project Mat
    $19.95
    Satın Al
    • Use a Phillips screwdriver to remove the four 4.5 mm screws securing the rear case.
    • If you're reassembling with the Samsung Self-Repair kit, be sure to replace the screws with new ones labeled #3313.
  4. Samsung Galaxy Book Pro 360 15" Daughterboard Replacement, Insert an opening pick: adım 4, 3 resimden 1. Samsung Galaxy Book Pro 360 15" Daughterboard Replacement, Insert an opening pick: adım 4, 3 resimden 2. Samsung Galaxy Book Pro 360 15" Daughterboard Replacement, Insert an opening pick: adım 4, 3 resimden 3.
    • Apply a suction handle to the middle of the rear case's bottom edge, as close to the edge as possible.
    • Pull up on the handle with a strong, steady force to create a small gap between the rear case and the frame.
    • This may take significant force and multiple tries.
    • Insert an opening pick into the gap you created.
  5. Samsung Galaxy Book Pro 360 15" Daughterboard Replacement, Release the clips: adım 5, 3 resimden 1. Samsung Galaxy Book Pro 360 15" Daughterboard Replacement, Release the clips: adım 5, 3 resimden 2. Samsung Galaxy Book Pro 360 15" Daughterboard Replacement, Release the clips: adım 5, 3 resimden 3.
    • Slide the opening pick along the bottom edge to release the clips securing the rear case.
    • Continue sliding the pick along the perimeter of the laptop until all the clips securing the rear case have been released.
  6. Samsung Galaxy Book Pro 360 15" Daughterboard Replacement, Remove the rear case: adım 6, 3 resimden 1. Samsung Galaxy Book Pro 360 15" Daughterboard Replacement, Remove the rear case: adım 6, 3 resimden 2. Samsung Galaxy Book Pro 360 15" Daughterboard Replacement, Remove the rear case: adım 6, 3 resimden 3.
    • Lift the rear case up and away from the laptop and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
  7. Samsung Galaxy Book Pro 360 15" Daughterboard Replacement, Remove the battery connector's tape: adım 7, 2 resimden 1. Samsung Galaxy Book Pro 360 15" Daughterboard Replacement, Remove the battery connector's tape: adım 7, 2 resimden 2.
    Satın Al
    • Use tweezers or your fingers to peel up and remove the tape covering the battery connector.
    • Set the tape aside. You'll reuse it during reassembly.
  8. Samsung Galaxy Book Pro 360 15" Daughterboard Replacement, Disconnect the battery: adım 8, 2 resimden 1. Samsung Galaxy Book Pro 360 15" Daughterboard Replacement, Disconnect the battery: adım 8, 2 resimden 2.
    • Insert the flat end of a spudger under the battery cables, as close to the connector as possible.
    • Gently pry up and disconnect the battery connector from its socket.
  9. Samsung Galaxy Book Pro 360 15" Daughterboard Replacement, Disconnect the fan cable's ZIF connector: adım 9, 3 resimden 1. Samsung Galaxy Book Pro 360 15" Daughterboard Replacement, Disconnect the fan cable's ZIF connector: adım 9, 3 resimden 2. Samsung Galaxy Book Pro 360 15" Daughterboard Replacement, Disconnect the fan cable's ZIF connector: adım 9, 3 resimden 3.
    • Use the pointed end up a spudger to pry up the locking flap on the left fan cable's ZIF connector.
    • During reassembly, make sure that all seven cables are connected to the daughterboard.
  10. Samsung Galaxy Book Pro 360 15" Daughterboard Replacement, Disconnect the fan cable: adım 10, 2 resimden 1. Samsung Galaxy Book Pro 360 15" Daughterboard Replacement, Disconnect the fan cable: adım 10, 2 resimden 2.
    Satın Al
    • Grip the left fan cable's pull tab with tweezers and gently pull the cable out of its socket.
  11. Samsung Galaxy Book Pro 360 15" Daughterboard Replacement, Disconnect the interconnect cable: adım 11, 3 resimden 1. Samsung Galaxy Book Pro 360 15" Daughterboard Replacement, Disconnect the interconnect cable: adım 11, 3 resimden 2. Samsung Galaxy Book Pro 360 15" Daughterboard Replacement, Disconnect the interconnect cable: adım 11, 3 resimden 3.
    • Use the flat end of spudger to pry up and disconnect both of the interconnect cable's press connectors from the daughterboard.
    • To re-attach press connectors like these, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  12. Samsung Galaxy Book Pro 360 15" Daughterboard Replacement, Disconnect the speaker: adım 12, 2 resimden 1. Samsung Galaxy Book Pro 360 15" Daughterboard Replacement, Disconnect the speaker: adım 12, 2 resimden 2.
    • Use the pointed end of a spudger to pry up and disconnect the bottom left speaker's connector from the daughterboard.
  13. Samsung Galaxy Book Pro 360 15" Daughterboard Replacement: adım 13, 3 resimden 1. Samsung Galaxy Book Pro 360 15" Daughterboard Replacement: adım 13, 3 resimden 2. Samsung Galaxy Book Pro 360 15" Daughterboard Replacement: adım 13, 3 resimden 3.
    • Insert the pointed end of a spudger under the black antenna cable and slide it as close to the connector as possible.
    • Gently lift straight up to disconnect the antenna.
    • The connector is very delicate and can easily break if a quick or strong force is applied.
    • Repeat the disconnection procedure on the white antenna cable.
    • To reattach coaxial connectors like these, align the connector over its socket and press down with the flat end of a spudger. The connector should snap into place. This can be tricky and may take a few tries.
  14. Samsung Galaxy Book Pro 360 15" Daughterboard Replacement: adım 14, 3 resimden 1. Samsung Galaxy Book Pro 360 15" Daughterboard Replacement: adım 14, 3 resimden 2. Samsung Galaxy Book Pro 360 15" Daughterboard Replacement: adım 14, 3 resimden 3.
    • Use tweezers or your fingers to lift the black and white antenna cables out of their clips on the daughterboard.
  15. Samsung Galaxy Book Pro 360 15" Daughterboard Replacement: adım 15, 2 resimden 1. Samsung Galaxy Book Pro 360 15" Daughterboard Replacement: adım 15, 2 resimden 2.
    • Use the pointed end of a spudger to pry up the locking flap on the backlight cable's connector.
  16. Samsung Galaxy Book Pro 360 15" Daughterboard Replacement: adım 16, 2 resimden 1. Samsung Galaxy Book Pro 360 15" Daughterboard Replacement: adım 16, 2 resimden 2.
    • Grip the backlight cable's pull tab with tweezers and gently pull the cable out of its socket.
  17. Samsung Galaxy Book Pro 360 15" Daughterboard Replacement: adım 17, 3 resimden 1. Samsung Galaxy Book Pro 360 15" Daughterboard Replacement: adım 17, 3 resimden 2. Samsung Galaxy Book Pro 360 15" Daughterboard Replacement: adım 17, 3 resimden 3.
    • Use a spudger to pry up the locking flap on the left display cable's ZIF connector.
  18. Samsung Galaxy Book Pro 360 15" Daughterboard Replacement: adım 18, 2 resimden 1. Samsung Galaxy Book Pro 360 15" Daughterboard Replacement: adım 18, 2 resimden 2.
    • Grip the left display cable's pull tab with tweezers or your fingers and gently pull the cable out of its socket.
  19. Samsung Galaxy Book Pro 360 15" Daughterboard Replacement: adım 19, 2 resimden 1. Samsung Galaxy Book Pro 360 15" Daughterboard Replacement: adım 19, 2 resimden 2.
    • Use the pointed end of a spudger to pry up and disconnect the fingerprint sensor's press connector.
  20. Samsung Galaxy Book Pro 360 15" Daughterboard Replacement: adım 20, 2 resimden 1. Samsung Galaxy Book Pro 360 15" Daughterboard Replacement: adım 20, 2 resimden 2.
    • Use a Phillips screwdriver to remove the five 3.5 mm screws securing the daughterboard.
  21. Samsung Galaxy Book Pro 360 15" Daughterboard Replacement, Remove the daughterboard: adım 21, 3 resimden 1. Samsung Galaxy Book Pro 360 15" Daughterboard Replacement, Remove the daughterboard: adım 21, 3 resimden 2. Samsung Galaxy Book Pro 360 15" Daughterboard Replacement, Remove the daughterboard: adım 21, 3 resimden 3.
    • Lift the right side of the daughterboard up and pull towards the center of the laptop to remove it.
    • During reassembly:
    • Move all cables that connect to the daughterboard (display, fingerprint, interconnect, speaker, backlight, and antennas) out of the way so they don't get stuck under the daughterboard when it's reinserted.
    • Reinsert the daughterboard at a downward angle to position the headphone jack, USB-C port, and memory slot back into their recesses.
    • Before securing the daughterboard, make sure the alignment pins on the frame are in their cutouts on the daughterboard.
Sonuç
To reassemble your device, follow the instructions in reverse order and perform the opposite actions, e.g., "reattach" instead of "removing." Skip steps that use heating and prying, and pay close attention to the 📌 bullets as you work through the steps.
Spencer Day
55.303 İtibar
408 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
137 Üyeler
17.457 adet Kılavuz yazıldı
Bir Yorum
Do you know where to buy the daughter board for this model and the board for the 13 inch model?
Norman - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 32
Her zaman: 567
