Ana içeriğe geç
Samsung Galaxy Book Pro 360 15" Front Case Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Book Pro 360 15" Front Case Replacement, Access the rubber feet: adım 1, 2 resimden 1. Samsung Galaxy Book Pro 360 15" Front Case Replacement, Access the rubber feet: adım 1, 2 resimden 2.
    • Before you begin, shut down your laptop and unplug it.
    • Close the screen and lay your laptop down with the rear case facing up to access the four rubber feet.
  2. Samsung Galaxy Book Pro 360 15" Front Case Replacement, Remove the rubber feet: adım 2, 3 resimden 1. Samsung Galaxy Book Pro 360 15" Front Case Replacement, Remove the rubber feet: adım 2, 3 resimden 2. Samsung Galaxy Book Pro 360 15" Front Case Replacement, Remove the rubber feet: adım 2, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Insert an opening pick between the rear case and the rubber foot.
    • Pry up with the pick and dislodge the foot from the rear case.
    • Use tweezers or your fingers to remove the rubber foot.
    • Repeat this process on the remaining rubber feet.
    • There are two types of rubber feet for this laptop. During reassembly, make sure the top feet say "M4" and the bottom feet say "M1".
    • To reinstall a rubber foot, align it over the recess and push down until it's secured.
  3. Samsung Galaxy Book Pro 360 15" Front Case Replacement, Unfasten the rear case: adım 3, 2 resimden 1. Samsung Galaxy Book Pro 360 15" Front Case Replacement, Unfasten the rear case: adım 3, 2 resimden 2.
    Magnetic Project Mat
    $19.95
    • Use a Phillips screwdriver to remove the four 4.5 mm screws securing the rear case.
  4. Samsung Galaxy Book Pro 360 15" Front Case Replacement, Insert an opening pick: adım 4, 3 resimden 1. Samsung Galaxy Book Pro 360 15" Front Case Replacement, Insert an opening pick: adım 4, 3 resimden 2. Samsung Galaxy Book Pro 360 15" Front Case Replacement, Insert an opening pick: adım 4, 3 resimden 3.
    • Apply a suction handle to the middle of the rear case's bottom edge, as close to the edge as possible.
    • Pull up on the handle with a strong, steady force to create a small gap between the rear case and the frame.
    • This may take significant force and multiple tries.
    • Insert an opening pick into the gap you created.
  5. Samsung Galaxy Book Pro 360 15" Front Case Replacement, Release the clips: adım 5, 3 resimden 1. Samsung Galaxy Book Pro 360 15" Front Case Replacement, Release the clips: adım 5, 3 resimden 2. Samsung Galaxy Book Pro 360 15" Front Case Replacement, Release the clips: adım 5, 3 resimden 3.
    • Slide the opening pick along the bottom edge to release the clips securing the rear case.
    • Continue sliding the pick along the perimeter of the laptop until all the clips securing the rear case have been released.
  6. Samsung Galaxy Book Pro 360 15" Front Case Replacement, Remove the rear case: adım 6, 3 resimden 1. Samsung Galaxy Book Pro 360 15" Front Case Replacement, Remove the rear case: adım 6, 3 resimden 2. Samsung Galaxy Book Pro 360 15" Front Case Replacement, Remove the rear case: adım 6, 3 resimden 3.
    • Lift the rear case up and away from the laptop and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
  7. Samsung Galaxy Book Pro 360 15" Front Case Replacement, Remove the battery connector's tape: adım 7, 2 resimden 1. Samsung Galaxy Book Pro 360 15" Front Case Replacement, Remove the battery connector's tape: adım 7, 2 resimden 2.
    • Use tweezers or your fingers to peel up and remove the tape covering the battery connector.
    • Set the tape aside. You'll reuse it during reassembly.
  8. Samsung Galaxy Book Pro 360 15" Front Case Replacement, Disconnect the battery: adım 8, 2 resimden 1. Samsung Galaxy Book Pro 360 15" Front Case Replacement, Disconnect the battery: adım 8, 2 resimden 2.
    • Insert the flat end of a spudger under the battery cables, as close to the connector as possible.
    • Gently pry up and disconnect the battery connector from its socket.
  9. Samsung Galaxy Book Pro 360 15" Front Case Replacement, Unfasten the battery: adım 9, 2 resimden 1. Samsung Galaxy Book Pro 360 15" Front Case Replacement, Unfasten the battery: adım 9, 2 resimden 2.
    • Use a Phillips screwdriver to remove the four 4.5 mm screws securing the battery.
    • Take care not to puncture the battery with your screwdriver—a punctured battery may leak dangerous chemicals or cause a fire.
  10. Samsung Galaxy Book Pro 360 15" Front Case Replacement, Remove the battery: adım 10, 3 resimden 1. Samsung Galaxy Book Pro 360 15" Front Case Replacement, Remove the battery: adım 10, 3 resimden 2. Samsung Galaxy Book Pro 360 15" Front Case Replacement, Remove the battery: adım 10, 3 resimden 3.
    • Lift the battery straight out of its recess and remove it.
  11. Samsung Galaxy Book Pro 360 15" Front Case Replacement, Disconnect the fan cable's ZIF connector: adım 11, 3 resimden 1. Samsung Galaxy Book Pro 360 15" Front Case Replacement, Disconnect the fan cable's ZIF connector: adım 11, 3 resimden 2. Samsung Galaxy Book Pro 360 15" Front Case Replacement, Disconnect the fan cable's ZIF connector: adım 11, 3 resimden 3.
    • Use the pointed end up a spudger to pry up the locking flap on the left fan cable's ZIF connector.
    • During reassembly, make sure that all seven cables are connected to the daughterboard.
  12. Samsung Galaxy Book Pro 360 15" Front Case Replacement, Disconnect the fan cable: adım 12, 2 resimden 1. Samsung Galaxy Book Pro 360 15" Front Case Replacement, Disconnect the fan cable: adım 12, 2 resimden 2.
    • Grip the left fan cable's pull tab with tweezers and gently pull the cable out of its socket.
  13. Samsung Galaxy Book Pro 360 15" Front Case Replacement, Disconnect the interconnect cable: adım 13, 3 resimden 1. Samsung Galaxy Book Pro 360 15" Front Case Replacement, Disconnect the interconnect cable: adım 13, 3 resimden 2. Samsung Galaxy Book Pro 360 15" Front Case Replacement, Disconnect the interconnect cable: adım 13, 3 resimden 3.
    • Use the flat end of spudger to pry up and disconnect both of the interconnect cable's press connectors from the daughterboard.
    • To re-attach press connectors like these, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  14. Samsung Galaxy Book Pro 360 15" Front Case Replacement, Disconnect the speaker: adım 14, 2 resimden 1. Samsung Galaxy Book Pro 360 15" Front Case Replacement, Disconnect the speaker: adım 14, 2 resimden 2.
    • Use the pointed end of a spudger to pry up and disconnect the bottom left speaker's connector from the daughterboard.
  15. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 15, 3 resimden 1. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 15, 3 resimden 2. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 15, 3 resimden 3.
    • Insert the pointed end of a spudger under the black antenna cable and slide it as close to the connector as possible.
    • Gently lift straight up to disconnect the antenna.
    • The connector is very delicate and can easily break if a quick or strong force is applied.
    • Repeat the disconnection procedure on the white antenna cable.
    • To reattach coaxial connectors like these, align the connector over its socket and press down with the flat end of a spudger. The connector should snap into place. This can be tricky and may take a few tries.
  16. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 16, 3 resimden 1. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 16, 3 resimden 2. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 16, 3 resimden 3.
    • Use tweezers or your fingers to lift the black and white antenna cables out of their clips on the daughterboard.
  17. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 17, 2 resimden 1. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 17, 2 resimden 2.
    • Use the pointed end of a spudger to pry up the locking flap on the backlight cable's connector.
  18. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 18, 2 resimden 1. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 18, 2 resimden 2.
    • Grip the backlight cable's pull tab with tweezers and gently pull the cable out of its socket.
  19. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 19, 3 resimden 1. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 19, 3 resimden 2. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 19, 3 resimden 3.
    • Use a spudger to pry up the locking flap on the left display cable's ZIF connector.
  20. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 20, 2 resimden 1. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 20, 2 resimden 2.
    • Grip the left display cable's pull tab with tweezers or your fingers and gently pull the cable out of its socket.
  21. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 21, 2 resimden 1. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 21, 2 resimden 2.
    • Use the pointed end of a spudger to pry up and disconnect the fingerprint sensor's press connector.
  22. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 22, 2 resimden 1. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 22, 2 resimden 2.
    • Use a Phillips screwdriver to remove the five 3.5 mm screws securing the daughterboard.
  23. Samsung Galaxy Book Pro 360 15" Front Case Replacement, Remove the daughterboard: adım 23, 3 resimden 1. Samsung Galaxy Book Pro 360 15" Front Case Replacement, Remove the daughterboard: adım 23, 3 resimden 2. Samsung Galaxy Book Pro 360 15" Front Case Replacement, Remove the daughterboard: adım 23, 3 resimden 3.
    • Lift the right side of the daughterboard up and pull towards the center of the laptop to remove it.
    • During reassembly:
    • Move all cables that connect to the daughterboard (display, fingerprint, interconnect, speaker, backlight, and antennas) out of the way so they don't get stuck under the daughterboard when it's reinserted.
    • Reinsert the daughterboard at a downward angle to position the headphone jack, USB-C port, and memory slot back into their recesses.
    • Before securing the daughterboard, make sure the alignment pins on the frame are in their cutouts on the daughterboard.
  24. Samsung Galaxy Book Pro 360 15" Front Case Replacement, Unfasten the fingerprint sensor bracket: adım 24, 2 resimden 1. Samsung Galaxy Book Pro 360 15" Front Case Replacement, Unfasten the fingerprint sensor bracket: adım 24, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the three 2.5 mm screws securing the fingerprint sensor bracket on the top left corner of the laptop.
  25. Samsung Galaxy Book Pro 360 15" Front Case Replacement, Remove the fingerprint sensor bracket: adım 25, 2 resimden 1. Samsung Galaxy Book Pro 360 15" Front Case Replacement, Remove the fingerprint sensor bracket: adım 25, 2 resimden 2.
    • Use tweezers or your fingers to remove the fingerprint sensor bracket.
  26. Samsung Galaxy Book Pro 360 15" Front Case Replacement, Remove the fingerprint sensor: adım 26, 2 resimden 1. Samsung Galaxy Book Pro 360 15" Front Case Replacement, Remove the fingerprint sensor: adım 26, 2 resimden 2.
    • Use tweezers or your fingers to remove the fingerprint sensor.
  27. Samsung Galaxy Book Pro 360 15" Front Case Replacement, Front Case: adım 27, 3 resimden 1. Samsung Galaxy Book Pro 360 15" Front Case Replacement, Front Case: adım 27, 3 resimden 2. Samsung Galaxy Book Pro 360 15" Front Case Replacement, Front Case: adım 27, 3 resimden 3.
    • Use the pointed end of a spudger to pry up the locking flap on the right fan cable's ZIF connector.
  28. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 28, 2 resimden 1. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 28, 2 resimden 2.
    • Grip the right fan cable's pull tab with tweezers and gently pull the cable out of its socket.
  29. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 29, 2 resimden 1. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 29, 2 resimden 2.
    • Remove the six 3.5 mm screws securing the fans.
  30. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 30, 2 resimden 1. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 30, 2 resimden 2.
    • Lift both fans straight up and remove them.
  31. Samsung Galaxy Book Pro 360 15" Front Case Replacement, Disconnect the speaker cable: adım 31, 3 resimden 1. Samsung Galaxy Book Pro 360 15" Front Case Replacement, Disconnect the speaker cable: adım 31, 3 resimden 2. Samsung Galaxy Book Pro 360 15" Front Case Replacement, Disconnect the speaker cable: adım 31, 3 resimden 3.
    • Use the pointed end of a spudger to pry up and disconnect the bottom right speaker's connector from the motherboard.
    • During reassembly, make sure you've connected these five cables to the motherboard.
  32. Samsung Galaxy Book Pro 360 15" Front Case Replacement, Disconnect the keyboard cable's ZIF connector: adım 32, 2 resimden 1. Samsung Galaxy Book Pro 360 15" Front Case Replacement, Disconnect the keyboard cable's ZIF connector: adım 32, 2 resimden 2.
    • Use the flat end of a spudger to pry up the locking flap on the keyboard cable's ZIF connector.
  33. Samsung Galaxy Book Pro 360 15" Front Case Replacement, Disconnect the keyboard cable: adım 33, 2 resimden 1. Samsung Galaxy Book Pro 360 15" Front Case Replacement, Disconnect the keyboard cable: adım 33, 2 resimden 2.
    • Grip the keyboard cable's pull tab with tweezers or your fingers and gently pull the cable out of its socket.
  34. Samsung Galaxy Book Pro 360 15" Front Case Replacement, Disconnect the touchpad's ZIF connector: adım 34, 3 resimden 1. Samsung Galaxy Book Pro 360 15" Front Case Replacement, Disconnect the touchpad's ZIF connector: adım 34, 3 resimden 2. Samsung Galaxy Book Pro 360 15" Front Case Replacement, Disconnect the touchpad's ZIF connector: adım 34, 3 resimden 3.
    • Use the flat end of a spudger to pry up the locking flap on the touchpad's ZIF connector on the motherboard.
  35. Samsung Galaxy Book Pro 360 15" Front Case Replacement, Disconnect the touchpad cable: adım 35, 2 resimden 1. Samsung Galaxy Book Pro 360 15" Front Case Replacement, Disconnect the touchpad cable: adım 35, 2 resimden 2.
    • Grip the touchpad cable's pull tab with tweezers and gently pull the cable out of its socket on the motherboard.
  36. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 36, 3 resimden 1. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 36, 3 resimden 2. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 36, 3 resimden 3.
    • Use your fingers or a spudger to peel up the tape covering the ZIF connector on the touchpad.
    • Remove the tape.
  37. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 37, 2 resimden 1. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 37, 2 resimden 2.
    • Use the pointed end up a spudger to pry up the locking flap on the ZIF connector.
  38. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 38, 2 resimden 1. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 38, 2 resimden 2.
    • Grip the touchpad cable's pull tab with tweezers and gently pull the cable out of its socket on the touchpad.
    • Remove the touchpad cable.
    • Set the cable aside. You'll reuse it during reassembly.
  39. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 39, 3 resimden 1. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 39, 3 resimden 2. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 39, 3 resimden 3.
    • Use the flat end of spudger to pry up the locking flap on the right display cable's ZIF connector.
  40. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 40, 2 resimden 1. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 40, 2 resimden 2.
    • Grip the right display cable's pull tab with tweezers or your fingers and gently pull the cable out of its socket.
  41. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 41, 3 resimden 1. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 41, 3 resimden 2. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 41, 3 resimden 3.
    • Gently pull the white antenna cable out of the three clips securing it to the motherboard.
  42. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 42, 3 resimden 1. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 42, 3 resimden 2. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 42, 3 resimden 3.
    • Use the flat end of a spudger to pry up and disconnect both of the interconnect cable's press connectors from the motherboard.
  43. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 43, 1 resimden 1.
    • Remove the interconnect cable.
  44. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 44, 2 resimden 1. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 44, 2 resimden 2.
    • Slowly pull the right display cable out of its recess.
    • A small clip secures the cable.
    • Repeat the process on the left display cable.
    • During reassembly, make sure the display cables are secured under their clips.
  45. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 45, 2 resimden 1. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 45, 2 resimden 2.
    • Use a Phillips screwdriver to remove the 11 3.5 mm screws securing the motherboard.
  46. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 46, 3 resimden 1. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 46, 3 resimden 2. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 46, 3 resimden 3.
    • Lift the motherboard straight up and remove it.
    • Before securing the motherboard during reassembly:
    • Move all cables that connect to the motherboard (display, keyboard, speaker, and antenna) out of the way so they don't get stuck under the motherboard when it's reinserted.
    • Make sure the alignment pins on the frame are in their cutouts on the motherboard.
    • Push down on right edge of the motherboard to ensure the USB-C and thunderbolt ports are in their recesses.
  47. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 47, 2 resimden 1. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 47, 2 resimden 2.
    • Use a Phillips screwdriver to remove the 3.5 mm screw securing the right antenna.
  48. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 48, 2 resimden 1. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 48, 2 resimden 2.
    • Use a Phillips screwdriver to remove the 3.5 mm screw securing the left antenna.
  49. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 49, 3 resimden 1. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 49, 3 resimden 2. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 49, 3 resimden 3.
    • Insert a pick between the left antenna and the bottom left speaker.
    • Pry up with the pick to dislodge the antenna.
    • Remove the antenna from its recess.
    • During reassembly, make sure to insert the top of the antennas under their brackets before laying them in their recesses.
  50. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 50, 1 resimden 1.
    • Repeat the removal procedure on the right antenna.
  51. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 51, 3 resimden 1. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 51, 3 resimden 2. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 51, 3 resimden 3.
    • Insert an opening pick between the bottom left speaker's left edge and the frame.
    • Pry up with the opening pick to dislodge the speaker from its recess.
    • Remove the speaker.
  52. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 52, 1 resimden 1.
    • Repeat the removal process on the bottom right speaker.
  53. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 53, 1 resimden 1.
    • Open the laptop until it's completely flat and lay it down with the display and keyboard facing down.
    • Before laying the laptop down, make sure you have a clean surface that is clear of items that could damage the display.
  54. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 54, 2 resimden 1. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 54, 2 resimden 2.
    • Use a Phillips screwdriver to remove the three 3.5 mm screws securing the left screen hinge.
    • During reassembly, install the screws from right to left.
  55. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 55, 2 resimden 1. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 55, 2 resimden 2.
    • Use a Phillips screwdriver to remove the three 3.5 mm screws securing the right screen hinge.
    • During reassembly, install the screws from left to right.
  56. Samsung Galaxy Book Pro 360 15" Front Case Replacement, Remove the display: adım 56, 2 resimden 1. Samsung Galaxy Book Pro 360 15" Front Case Replacement, Remove the display: adım 56, 2 resimden 2.
    • Lift the screen away from the laptop and remove it.
  57. Samsung Galaxy Book Pro 360 15" Front Case Replacement: adım 57, 1 resimden 1.
    • You're left with the front case.
Sonuç
To reassemble your device, follow the instructions in reverse order.
Spencer Day
94.949 İtibar
662 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.453 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 12
Son 30 gün: 23
Her zaman: 1,638
