Ana içeriğe geç
Samsung Galaxy Book Pro 360 15" SSD Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Book Pro 360 15" SSD Replacement, Access the rubber feet: adım 1, 2 resimden 1. Samsung Galaxy Book Pro 360 15" SSD Replacement, Access the rubber feet: adım 1, 2 resimden 2.
    • Before you begin, shut down your laptop and unplug it.
    • Close the screen and lay your laptop down with the rear case facing up to access the four rubber feet.
  2. Samsung Galaxy Book Pro 360 15" SSD Replacement, Remove the rubber feet: adım 2, 3 resimden 1. Samsung Galaxy Book Pro 360 15" SSD Replacement, Remove the rubber feet: adım 2, 3 resimden 2. Samsung Galaxy Book Pro 360 15" SSD Replacement, Remove the rubber feet: adım 2, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Insert an opening pick between the rear case and the rubber foot.
    • Pry up with the pick and dislodge the foot from the rear case.
    • Use tweezers or your fingers to remove the rubber foot.
    • Repeat this process on the remaining rubber feet.
    • There are two types of rubber feet for this laptop. During reassembly, make sure the top feet say "M4" and the bottom feet say "M1".
    • To reinstall a rubber foot, align it over the recess and push down until it's secured.
  3. Samsung Galaxy Book Pro 360 15" SSD Replacement, Unfasten the rear case: adım 3, 2 resimden 1. Samsung Galaxy Book Pro 360 15" SSD Replacement, Unfasten the rear case: adım 3, 2 resimden 2.
    Magnetic Project Mat
    $19.95
    • Use a Phillips screwdriver to remove the four 4.5 mm screws securing the rear case.
  4. Samsung Galaxy Book Pro 360 15" SSD Replacement, Insert an opening pick: adım 4, 3 resimden 1. Samsung Galaxy Book Pro 360 15" SSD Replacement, Insert an opening pick: adım 4, 3 resimden 2. Samsung Galaxy Book Pro 360 15" SSD Replacement, Insert an opening pick: adım 4, 3 resimden 3.
    • Apply a suction handle to the middle of the rear case's bottom edge, as close to the edge as possible.
    • Pull up on the handle with a strong, steady force to create a small gap between the rear case and the frame.
    • This may take significant force and multiple tries.
    • Insert an opening pick into the gap you created.
  5. Samsung Galaxy Book Pro 360 15" SSD Replacement, Release the clips: adım 5, 3 resimden 1. Samsung Galaxy Book Pro 360 15" SSD Replacement, Release the clips: adım 5, 3 resimden 2. Samsung Galaxy Book Pro 360 15" SSD Replacement, Release the clips: adım 5, 3 resimden 3.
    • Slide the opening pick along the bottom edge to release the clips securing the rear case.
    • Continue sliding the pick along the perimeter of the laptop until all the clips securing the rear case have been released.
  6. Samsung Galaxy Book Pro 360 15" SSD Replacement, Remove the rear case: adım 6, 3 resimden 1. Samsung Galaxy Book Pro 360 15" SSD Replacement, Remove the rear case: adım 6, 3 resimden 2. Samsung Galaxy Book Pro 360 15" SSD Replacement, Remove the rear case: adım 6, 3 resimden 3.
    • Lift the rear case up and away from the laptop and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
  7. Samsung Galaxy Book Pro 360 15" SSD Replacement, Remove the battery connector's tape: adım 7, 2 resimden 1. Samsung Galaxy Book Pro 360 15" SSD Replacement, Remove the battery connector's tape: adım 7, 2 resimden 2.
    • Use tweezers or your fingers to peel up and remove the tape covering the battery connector.
    • Set the tape aside. You'll reuse it during reassembly.
  8. Samsung Galaxy Book Pro 360 15" SSD Replacement, Disconnect the battery: adım 8, 2 resimden 1. Samsung Galaxy Book Pro 360 15" SSD Replacement, Disconnect the battery: adım 8, 2 resimden 2.
    • Insert the flat end of a spudger under the battery cables, as close to the connector as possible.
    • Gently pry up and disconnect the battery connector from its socket.
  9. Samsung Galaxy Book Pro 360 15" SSD Replacement, Unfasten the SSD: adım 9, 2 resimden 1. Samsung Galaxy Book Pro 360 15" SSD Replacement, Unfasten the SSD: adım 9, 2 resimden 2.
    • Use a Phillips screwdriver to remove the 3.5 mm screw securing the left SSD.
  10. Samsung Galaxy Book Pro 360 15" SSD Replacement, Remove the SSD: adım 10, 2 resimden 1. Samsung Galaxy Book Pro 360 15" SSD Replacement, Remove the SSD: adım 10, 2 resimden 2.
    • Pull the left SSD out of its socket and remove it.
    • Don't pull up at a sharp angle, as this could damage the SSD and its socket.
  11. Samsung Galaxy Book Pro 360 15" SSD Replacement, Remove the right SSD: adım 11, 1 resimden 1.
    • If you have a right SSD installed, repeat the removal procedure on it.
Sonuç
To reassemble your device, follow the instructions in reverse order and perform the opposite actions, e.g., "reattach" instead of "removing." Skip steps that use heating and prying, and pay close attention to the 📌 bullets as you work through the steps.
2 farklı kişi bu kılavuzu tamamladı.
Spencer Day
95.990 İtibar
662 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
119 Üyeler
19.656 adet Kılavuz yazıldı
1Rehber Yorum
Hello! The Galaxy Book3 360 not the Pro version, also has two coolers? Or only one?
Erick Giacomazza - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 32
Son 30 gün: 219
Her zaman: 4,564
