Ana içeriğe geç
Samsung Galaxy J6 Display Replacement
Neye ihtiyacın var
  1. Samsung Galaxy J6 Display Replacement, Cut the screen adhesive: adım 1, 3 resimden 1. Samsung Galaxy J6 Display Replacement, Cut the screen adhesive: adım 1, 3 resimden 2. Samsung Galaxy J6 Display Replacement, Cut the screen adhesive: adım 1, 3 resimden 3.
    • I recommend wearing eye protection to avoid any inconvenience with glass fragments.
    • It is very important to heat the display on the side parts where the double-sided adhesive is well with a hairdryer or other so as to make it lose its adhesion and facilitate the operation of inserting the blade to lift it.
    • Insert the blade between the body and the glass and begin to separate the display from the body, I recommend starting from the top paying attention.
    • The flat connection connectors are located at the bottom.
  2. Samsung Galaxy J6 Display Replacement, Lift up the display: adım 2, 2 resimden 1. Samsung Galaxy J6 Display Replacement, Lift up the display: adım 2, 2 resimden 2.
    • Lift the display.
    This photo does not show the original glue strip round the edge of the bezel. When you try to lift the screen the glue strip will be stuck to the glass is some areas and the the bezel in others. The 3 strips shown are not orriginal!
    Adrian Berry - Yanıt
    Display how many price
    Galaxy j6 - Yanıt
  3. Samsung Galaxy J6 Display Replacement, Remove the display: adım 3, 3 resimden 1. Samsung Galaxy J6 Display Replacement, Remove the display: adım 3, 3 resimden 2. Samsung Galaxy J6 Display Replacement, Remove the display: adım 3, 3 resimden 3.
    • Unplug the black plastic plug securing the display connector.
    • Unhook the display connector.
    • Remove the old display and place the new display.
    • Put some glue to attach the new display.
    Double sided tape might work but does not provide the same level of sealing round the edge of the screen. Any wetness round the screen will wick under and get into the electronics. You should use a new properly shaped glue strip.
Sonuç
41 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
it en
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Smilzo
11.294 İtibar
39 adet Kılavuz yazıldı
10 Yorum
f**k this adhesive!!
Thanks for this tutorial :)
NoCheatImPGM - Yanıt
Gli adesivi non aderiscono bene sono d’accordo,puoi provare con altro biadesivo 3M oppure con della colla idonea.
Smilzo -
You mentioned nothing about disconnecting the battery. If the phone accidentally turns on in the middle of a display swap [with no way to turn it off, since there’s no display or digitser connected] you will blow an internal fuse, rendering the phone useless. Complete waste of time! You should have included that the battery be disconnected before attempting this.
Dot - Yanıt
Ciao ti ringrazio per la Puntualizzazione ed il buon consiglio.
io non ho mai avuto problemi nello scollegare i display perché il telefono è precedentemente spento e rimane spento fino a quando non scollego il connettore display.
se per sfortuna si dovesse toccare il tasto power (che comunque richiede una lunga pressione e non un semplice tocco ) si vedrebbe accendere il display o vibrare il telefono o accendersi i led. Quindi prima di scollegare lo spegnerei nuovamente.
non vedo il problema.
scollegare la batteria comporta una procedura analoga a togliere il display e quindi molto tempo in più ed accollarsi i rischi di rompere un componente posteriore per rimuoverlo,perdendo così impermeabilità se non si dispone di adesivo specifico per questa sostituzione.
Smilzo -
Ciao e grazie della guida.
Quale modello di display e su quale sito consigli di comprarlo?
Danilo B. - Yanıt
Ciao Danilo generalmente faccio una ricerca su eBay per rendermi conto del prezzo,se è accettabile proseguo con il pagamento sicuro grazie a PayPal visto che è un mercato sicuro come lo è Amazon, anche se ho verificato che in genere sono un po’ più alti i prezzi di Amazon però sono veloci le consegne tendenzialmente
Smilzo -
Buongiorno, il biadesivo quanto deve essere spesso? 1mm? E come in foto, va messo solo nel punto ribassato dove non c’è la piastra d’acciaio? Grazie
Davide - Yanıt
Ciao,in teoria dovrebbe bastare soltanto sui bordi se il display è originale ovvero piatto,se trovi i compatibili lcd sono più alti anche se costano meno e sono una rogna da farli stare giu. Se metti il biadesivo anche al centro se devi toglierlo per qualche motivo è quasi certo che romperai il pannello. Valuta tu,magari prova a metterlo solo nei bordi e se non ti accontenta poi lo, metti anche dietro al pannello,oppure puoi usare la colla b7000 che ha un’ottima presa. Buona riparazione
Smilzo -
Samsung J6+ battery change
Idris Oped - Yanıt
this tutorial works on j6+
Igor jr - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 57
Son 30 gün: 308
Her zaman: 15,544
