Giriş
Use this guide to remove or replace the rear cover on your Samsung Galaxy Note20 Ultra.
For your safety, discharge the battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Neye ihtiyacın var
Heat an iOpener and apply it to the left side of the rear cover for one minute.
Apply a suction cup to the heated edge of the rear cover, as close to the edge as possible.
Pull up on the suction cup with strong, steady force to create a gap between the rear cover and the frame.
Insert an opening pick into the gap.
Slide the opening pick along the left edge towards the bottom left corner to cut through the adhesive.
Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
Repeat the process of heating and cutting the adhesive along the three remaining sides of the rear cover.
As you proceed, leave an opening pick in each corner to prevent the adhesive from re-sealing.
Slide an opening pick back and forth around the entire perimeter of the phone to release any missed adhesive. Reheat any stubborn adhesive.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Samsung Galaxy Note20 Ultra Answers community for help.
7 farklı kişi bu kılavuzu tamamladı.
6 Yorum
Clean the rim of the phone off and when you get the new backplate use adhesive it came with if it did not come with adhesive. use Double-Sided High Strength Polyester Tape 300LSE (3MM x 25M) (3M Model # 9475LEB) or something similar to it(don't use liquid glue, you will mess stuff up)
everything went great and everything works well. it only rattles a little. like something small is loose. I don't know if that's bad now?
I had to remove a small part from the old back and put it on the new one.
So to do this in reverse you use the picks again do you heat it Last to get the adhesive to adhere????? The Title is very misleading it says replacement as far as any manuals I have seen (IE cam replacement, Head replacement (Automotive) the instructions do not stop once it is removed they have a Butt load of specific steps to reinstall the item, like Torque specs, Timing alignment )Not this to Reassemble do the steps in reverse order as this states . It should be called Removal only. Is there special glue used? What about the camera cover thing does it get attached to the rear Glass/Cover or is it attached to something internally?? No mention of that at all Very crappy Instructions to be honest
