Ana içeriğe geç
Samsung Galaxy Note8 Battery Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Note8 Battery Replacement, Back Cover: adım 1, 1 resimden 1.
    • Switch off your phone.
    • Prepare an iOpener for softening the adhesive on the back of the Note8.
    • Apply the iOpener on the back of the Note8 along the side with the power button.
    FixBot'a Sor
    Yorum Ekle
  2. Samsung Galaxy Note8 Battery Replacement: adım 2, 3 resimden 1. Samsung Galaxy Note8 Battery Replacement: adım 2, 3 resimden 2. Samsung Galaxy Note8 Battery Replacement: adım 2, 3 resimden 3.
    • Use a suction handle to lift the back cover and create an opening pick to get in the gap.
    • Since the back cover is also slightly curved at the edges you want to insert the opening pick at a lower angle from underneath.
    • Start at the middle of the side and cut the adhesive while pulling up with the suction handle.
    • Be careful not to lever the opening pick too much to avoid breaking the back cover. Rather pull with the suction handle and use the pick for cutting the adhesive.
    • Move the pick towards the bottom corner and leave it there to keep the adhesive from resealing to the case.
    • Use another pick and move it to the top corner.
    • If it's getting harder to move the pick you might need to reheat the iOpener and apply it to the back cover again.
    FixBot'a Sor
    Yorum Ekle
  3. Samsung Galaxy Note8 Battery Replacement: adım 3, 3 resimden 1. Samsung Galaxy Note8 Battery Replacement: adım 3, 3 resimden 2. Samsung Galaxy Note8 Battery Replacement: adım 3, 3 resimden 3.
    • Again take another opening pick and carefully move it around the corner and along the top edge.
    • Reheat with an iOpener if necessary.
    • Leave the pick at the top right corner to keep the adhesive from resealing.
    FixBot'a Sor
    Yorum Ekle
  4. Samsung Galaxy Note8 Battery Replacement: adım 4, 3 resimden 1. Samsung Galaxy Note8 Battery Replacement: adım 4, 3 resimden 2. Samsung Galaxy Note8 Battery Replacement: adım 4, 3 resimden 3.
    • Rotate the device and start to separate the adhesive at the bottom with another opening pick.
    • Leave the pick at the bottom right corner to keep the adhesive from resealing.
    FixBot'a Sor
    Yorum Ekle
  5. Samsung Galaxy Note8 Battery Replacement: adım 5, 3 resimden 1. Samsung Galaxy Note8 Battery Replacement: adım 5, 3 resimden 2. Samsung Galaxy Note8 Battery Replacement: adım 5, 3 resimden 3.
    • When the adhesive has been separated on all three sides properly you will be able to slowly lift the back cover.
    • Don't force it open. Use an iOpener to again soften the adhesive if the back cover won't come off or starts to bend.
    • Pay attention to the fingerprint sensor connector when flipping the back cover open. You might need to disconnect it as described in the next step.
    FixBot'a Sor
    Yorum Ekle
  6. Samsung Galaxy Note8 Battery Replacement: adım 6, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use a pair of tweezers to disconnect the fingerprint sensor.
    • The connector might already have come off when flipping the back cover open.
    FixBot'a Sor
    Yorum Ekle
  7. Samsung Galaxy Note8 Battery Replacement: adım 7, 1 resimden 1.
    • Remove the back cover.
    • To prepare for the reassembly remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
    FixBot'a Sor
    Yorum Ekle
  8. Samsung Galaxy Note8 Battery Replacement, NFC Antenna and Charging Coil Assembly: adım 8, 1 resimden 1.
    • Remove the ten Phillips #00 screws.
    FixBot'a Sor
    Yorum Ekle
  9. Samsung Galaxy Note8 Battery Replacement: adım 9, 2 resimden 1. Samsung Galaxy Note8 Battery Replacement: adım 9, 2 resimden 2.
    • Use an opening pick at the top edge to get between the NFC antenna and charging coil assembly and the case.
    • Lever the top of the assembly out of the case.
    FixBot'a Sor
    Yorum Ekle
  10. Samsung Galaxy Note8 Battery Replacement: adım 10, 1 resimden 1.
    • Carefully pull up the complete charging coil and NFC antenna assembly.
    • The bottom left part of the assembly is slightly glued down to the frame.
    FixBot'a Sor
    Yorum Ekle
  11. Samsung Galaxy Note8 Battery Replacement, Battery Disconnect: adım 11, 1 resimden 1.
    • Use the flat end of a spudger to disconnect the battery connector.
    FixBot'a Sor
    Yorum Ekle
  12. Samsung Galaxy Note8 Battery Replacement, Battery: adım 12, 1 resimden 1.
    • Prepare an iOpener and apply it to the display for at least two minutes to loosen the adhesive beneath the battery. Reheat and reapply the iOpener as needed.
    • Alternatively or when the battery is blown up, you can apply some isopropyl alcohol under each corner of the battery and allow it to penetrate for several minutes to help weaken the adhesive.
    FixBot'a Sor
    Yorum Ekle
  13. Samsung Galaxy Note8 Battery Replacement: adım 13, 2 resimden 1. Samsung Galaxy Note8 Battery Replacement: adım 13, 2 resimden 2.
    • Use the flat end of a spudger to pry up the battery from the top right corner.
    • You will be prying against the case directly above the mainboard. Pry carefully to avoid damaging any close components.
    • You may need to reheat and reapply the iOpener repeatedly to further soften the adhesive. The adhesive is tough and it may take a few tries to get the spudger started under the battery.
    • Use the spudger to pry up the battery until you can insert an opening pick to prevent the adhesive from resealing.
    • Try your best not to deform the battery during this process. Soft-shell lithium-ion batteries can leak dangerous chemicals, catch fire, or even explode if damaged. Do not use excessive force or pry at the battery with metal tools.
    FixBot'a Sor
    Yorum Ekle
  14. Samsung Galaxy Note8 Battery Replacement: adım 14, 3 resimden 1. Samsung Galaxy Note8 Battery Replacement: adım 14, 3 resimden 2. Samsung Galaxy Note8 Battery Replacement: adım 14, 3 resimden 3.
    • Use the flat end of the spudger to pry up the top left corner of the battery where the flex cable is located.
    • Slide the spudger along the side of the battery to break apart remaining adhesive.
    • When prying keep to the areas marked orange. Avoid the red area in the middle which is the back of the display.
    FixBot'a Sor
    Yorum Ekle
  15. Samsung Galaxy Note8 Battery Replacement: adım 15, 1 resimden 1.
    • Lift the battery out of the case.
    • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
    • Remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
    • Follow this guide to install battery adhesive.
    • Follow this guide to install custom-cut adhesives.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the phone at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place for 5-10 seconds.
To reassemble your device, follow these instructions in reverse order, replacing the adhesive where needed.
If possible, turn on your phone and test your repair before closing and sealing up the phone.
For best results, when your repair is complete, calibrate your newly-installed battery.
77 farklı kişi bu kılavuzu tamamladı.
Tobias Isakeit
134.397 İtibar
189 adet Kılavuz yazıldı
Ekip
10Kılavuz Yorumları
Awesome fix. Do you have anything for the front glass replacements by chance? I want to do both at the same time
Rick Moore - Yanıt Paylaş
For those wondering how to apply the replacement adhesive, there is a video on the iFixit YouTube channel about installing adhesive on Samsung devices. Its a bit generic, but it points you in the right direction.
Christopher Zibbell - Yanıt Paylaş
Hi Christopher,
I’ve edited the last step to include some adhesive guides! Hope that helps!
Arthur Shi - Yanıt Paylaş
Thanks!! Very good detail. I was able to get the back cover off and replace the battery - the phone is working like a champ!
Phil Brooks - Yanıt Paylaş
Would it be possible to augment the mAh? instead of 3300 mAh giving a little bit more power?
William Houli - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 16
Son 7 gün: 98
Son 30 gün: 417
Her zaman: 114,005
