Ana içeriğe geç
Samsung Galaxy S20 Plus USB-C Port and Daughterboard Replacement
Neye ihtiyacın var
  1. Samsung Galaxy S20 Plus USB-C Port and Daughterboard Replacement, Heat the bottom edge: adım 1, 1 resimden 1.
    • Unplug and power off your phone before you begin.
    • Heat an iOpener and apply it to the back cover's bottom edge for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Samsung Galaxy S20 Plus USB-C Port and Daughterboard Replacement, Separate the bottom edge adhesive: adım 2, 3 resimden 1. Samsung Galaxy S20 Plus USB-C Port and Daughterboard Replacement, Separate the bottom edge adhesive: adım 2, 3 resimden 2. Samsung Galaxy S20 Plus USB-C Port and Daughterboard Replacement, Separate the bottom edge adhesive: adım 2, 3 resimden 3.
    • Apply a suction cup to the back of the phone, as close to the center of the bottom edge as possible.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken glass.
    • Pull on the suction cup with strong, steady force to create a gap between the back cover and the frame.
    • Insert the point of an opening pick into the gap.
    • Due to tight tolerances, this may take multiple attempts of reheating with the iOpener and separating with the suction cup before you get it right.
    • If you are having trouble creating a gap, apply more heat to the edge and try again.
    • Do not apply excessive force with the pick, or you risk cracking the back cover glass.
  3. Samsung Galaxy S20 Plus USB-C Port and Daughterboard Replacement: adım 3, 3 resimden 1. Samsung Galaxy S20 Plus USB-C Port and Daughterboard Replacement: adım 3, 3 resimden 2. Samsung Galaxy S20 Plus USB-C Port and Daughterboard Replacement: adım 3, 3 resimden 3.
    • Slide the pick back and forth along the bottom edge to slice through the adhesive.
    • Do not attempt to cut the adhesive near the corners of the phone where the glass is curved or you risk cracking the glass panel.
    • Leave your opening pick in the seam to prevent the adhesive from resealing.
  4. Samsung Galaxy S20 Plus USB-C Port and Daughterboard Replacement, Heat the left edge: adım 4, 1 resimden 1.
    • Apply a heated iOpener to the left edge of the back cover for two minutes.
  5. Samsung Galaxy S20 Plus USB-C Port and Daughterboard Replacement, Separate the left edge adhesive: adım 5, 3 resimden 1. Samsung Galaxy S20 Plus USB-C Port and Daughterboard Replacement, Separate the left edge adhesive: adım 5, 3 resimden 2. Samsung Galaxy S20 Plus USB-C Port and Daughterboard Replacement, Separate the left edge adhesive: adım 5, 3 resimden 3.
    • Apply a suction cup to the back of the phone, as close to the center of the left edge as possible.
    • As the glass on this edge is curved, you won't be able to insert this pick very far. As long as the very tip of the pick is underneath the glass's edge, you will be able to proceed.
    • Due to tight tolerances, this may take multiple attempts.
    • You can try also applying a few drops of high concentration (over 90%) isopropyl alcohol into the seam to help loosen the adhesive.
  6. Samsung Galaxy S20 Plus USB-C Port and Daughterboard Replacement: adım 6, 2 resimden 1. Samsung Galaxy S20 Plus USB-C Port and Daughterboard Replacement: adım 6, 2 resimden 2.
    • Once the pick is underneath the glass's edge, tilt it downward and insert it further to fully separate the back cover's adhesive.
  7. Samsung Galaxy S20 Plus USB-C Port and Daughterboard Replacement: adım 7, 3 resimden 1. Samsung Galaxy S20 Plus USB-C Port and Daughterboard Replacement: adım 7, 3 resimden 2. Samsung Galaxy S20 Plus USB-C Port and Daughterboard Replacement: adım 7, 3 resimden 3.
    • Slide the pick all along the left edge of the phone to separate the back cover's adhesive.
    • Take care when sliding across the ridge in the frame surrounding the volume and power buttons—the cutout in the glass may make it more prone to cracking.
    • Leave your pick under the left edge of the glass to prevent the adhesive from resealing.
  8. Samsung Galaxy S20 Plus USB-C Port and Daughterboard Replacement, Heat the right edge: adım 8, 1 resimden 1.
    • Apply a heated iOpener to the right edge of the back cover for two minutes.
  9. Samsung Galaxy S20 Plus USB-C Port and Daughterboard Replacement, Separate the right edge adhesive: adım 9, 3 resimden 1. Samsung Galaxy S20 Plus USB-C Port and Daughterboard Replacement, Separate the right edge adhesive: adım 9, 3 resimden 2. Samsung Galaxy S20 Plus USB-C Port and Daughterboard Replacement, Separate the right edge adhesive: adım 9, 3 resimden 3.
    • Apply a suction cup to the back of the phone, as close to the center of the right edge as possible.
    • Like with the previous edge, you will need to tilt the opening pick downward to fully insert it underneath the back cover.
  10. Samsung Galaxy S20 Plus USB-C Port and Daughterboard Replacement: adım 10, 3 resimden 1. Samsung Galaxy S20 Plus USB-C Port and Daughterboard Replacement: adım 10, 3 resimden 2. Samsung Galaxy S20 Plus USB-C Port and Daughterboard Replacement: adım 10, 3 resimden 3.
    • Slide the pick all along the right edge of the phone to separate the back cover's adhesive.
    • Leave your pick under the right edge of the glass near the top of the device to prevent the adhesive from resealing.
    • As you do this, the back cover may release one or both of the other picks and allow them to fall free. If this occurs, set the pick(s) aside as the bottom edge shouldn't reseal from this point onward.
  11. Samsung Galaxy S20 Plus USB-C Port and Daughterboard Replacement, Heat the top edge: adım 11, 1 resimden 1.
    • Apply a heated iOpener to the top edge of the back cover for two minutes.
  12. Samsung Galaxy S20 Plus USB-C Port and Daughterboard Replacement, Separate the top edge adhesive: adım 12, 3 resimden 1. Samsung Galaxy S20 Plus USB-C Port and Daughterboard Replacement, Separate the top edge adhesive: adım 12, 3 resimden 2. Samsung Galaxy S20 Plus USB-C Port and Daughterboard Replacement, Separate the top edge adhesive: adım 12, 3 resimden 3.
    • The glass near the corners of the back cover is curved and very susceptible to cracking. Be gentle during this step to prevent damaging your back cover.
    • Gradually slide the pick from the right edge of the device around the top right corner.
    • Continue slicing along the top edge all the way around to the left edge to fully separate the back cover adhesive.
    • If the slicing becomes difficult at any point, stop and reapply heat before continuing.
  13. Samsung Galaxy S20 Plus USB-C Port and Daughterboard Replacement, Remove the back cover: adım 13, 2 resimden 1. Samsung Galaxy S20 Plus USB-C Port and Daughterboard Replacement, Remove the back cover: adım 13, 2 resimden 2.
    • Lift the back cover slowly. Use opening picks to slice any remaining adhesive.
    • Remove the back cover.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
    • If you're using Samsung custom-cut adhesives, follow this guide.
    • If you're using double-sided tape, follow this guide.
  14. Samsung Galaxy S20 Plus USB-C Port and Daughterboard Replacement, Unfasten the motherboard bracket: adım 14, 1 resimden 1.
    Bu adımda kullanılan alet:
    Magnetic Project Mat
    $19.95
    Satın Al
    • Use a Phillips #00 screwdriver to remove the six 4 mm-long screws securing the motherboard bracket.
  15. Samsung Galaxy S20 Plus USB-C Port and Daughterboard Replacement, Unclip the motherboard bracket: adım 15, 3 resimden 1. Samsung Galaxy S20 Plus USB-C Port and Daughterboard Replacement, Unclip the motherboard bracket: adım 15, 3 resimden 2. Samsung Galaxy S20 Plus USB-C Port and Daughterboard Replacement, Unclip the motherboard bracket: adım 15, 3 resimden 3.
    • Use a pair of tweezers to gently pull up and unclip the motherboard bracket from the plastic midframe.
    • Do not completely remove the bracket yet, as its still attached to the wireless charging coil.
  16. Samsung Galaxy S20 Plus USB-C Port and Daughterboard Replacement: adım 16, 3 resimden 1. Samsung Galaxy S20 Plus USB-C Port and Daughterboard Replacement: adım 16, 3 resimden 2. Samsung Galaxy S20 Plus USB-C Port and Daughterboard Replacement: adım 16, 3 resimden 3.
    • Gently tilt up the motherboard bracket so the orange battery connector is accessible.
  17. Samsung Galaxy S20 Plus USB-C Port and Daughterboard Replacement, Disconnect the battery: adım 17, 2 resimden 1. Samsung Galaxy S20 Plus USB-C Port and Daughterboard Replacement, Disconnect the battery: adım 17, 2 resimden 2.
    • Use a spudger to pry up and disconnect the battery connector.
    • When you disconnect connectors like these, be careful not to dislodge the small surface-mounted components surrounding the socket.
  18. Samsung Galaxy S20 Plus USB-C Port and Daughterboard Replacement, Disconnect the wireless charging coil: adım 18, 2 resimden 1. Samsung Galaxy S20 Plus USB-C Port and Daughterboard Replacement, Disconnect the wireless charging coil: adım 18, 2 resimden 2.
    • Use a spudger to pry up and disconnect the wireless charging coil connector.
  19. Samsung Galaxy S20 Plus USB-C Port and Daughterboard Replacement, Remove the wireless charging coil: adım 19, 3 resimden 1. Samsung Galaxy S20 Plus USB-C Port and Daughterboard Replacement, Remove the wireless charging coil: adım 19, 3 resimden 2. Samsung Galaxy S20 Plus USB-C Port and Daughterboard Replacement, Remove the wireless charging coil: adım 19, 3 resimden 3.
    • Use a pair of tweezers to gently peel the wireless charging coil away from the device.
    • Remove the wireless charging coil.
    • During reassembly, first reconnect the charging coil and battery connectors and refasten the motherboard bracket screws to properly align everything into place, then firmly press the coil pad down to adhere it.
  20. Samsung Galaxy S20 Plus USB-C Port and Daughterboard Replacement, Unfasten the lower midframe: adım 20, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the five 4 mm-long screws securing the loudspeaker and lower midframe.
  21. Samsung Galaxy S20 Plus USB-C Port and Daughterboard Replacement, Remove the loudspeaker: adım 21, 3 resimden 1. Samsung Galaxy S20 Plus USB-C Port and Daughterboard Replacement, Remove the loudspeaker: adım 21, 3 resimden 2. Samsung Galaxy S20 Plus USB-C Port and Daughterboard Replacement, Remove the loudspeaker: adım 21, 3 resimden 3.
    • Insert the point of a spudger or a pair of tweezers into the notch in the top left corner of the midframe and pry up to release the clips holding it in place.
    • Remove the loudspeaker and lower midframe.
  22. Samsung Galaxy S20 Plus USB-C Port and Daughterboard Replacement, Disconnect the daughterboard: adım 22, 3 resimden 1. Samsung Galaxy S20 Plus USB-C Port and Daughterboard Replacement, Disconnect the daughterboard: adım 22, 3 resimden 2. Samsung Galaxy S20 Plus USB-C Port and Daughterboard Replacement, Disconnect the daughterboard: adım 22, 3 resimden 3.
    • Use a spudger to pry up and disconnect the main and auxiliary flex cables from the daughterboard near the bottom of the device.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  23. Samsung Galaxy S20 Plus USB-C Port and Daughterboard Replacement, Disconnect the main flex cables: adım 23, 3 resimden 1. Samsung Galaxy S20 Plus USB-C Port and Daughterboard Replacement, Disconnect the main flex cables: adım 23, 3 resimden 2. Samsung Galaxy S20 Plus USB-C Port and Daughterboard Replacement, Disconnect the main flex cables: adım 23, 3 resimden 3.
    • Use a spudger to pry up and disconnect the main and auxiliary flex cables from the motherboard.
  24. Samsung Galaxy S20 Plus USB-C Port and Daughterboard Replacement, Remove the main flex cables: adım 24, 2 resimden 1. Samsung Galaxy S20 Plus USB-C Port and Daughterboard Replacement, Remove the main flex cables: adım 24, 2 resimden 2.
    • Gently peel up and remove the main and auxiliary flex cables.
  25. Samsung Galaxy S20 Plus USB-C Port and Daughterboard Replacement, Unfasten the daughterboard: adım 25, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the three 3.4 mm-long screws securing the USB-C port and daughterboard.
  26. Samsung Galaxy S20 Plus USB-C Port and Daughterboard Replacement, Remove the daughterboard: adım 26, 3 resimden 1. Samsung Galaxy S20 Plus USB-C Port and Daughterboard Replacement, Remove the daughterboard: adım 26, 3 resimden 2. Samsung Galaxy S20 Plus USB-C Port and Daughterboard Replacement, Remove the daughterboard: adım 26, 3 resimden 3.
    • Insert the pointed end of a spudger under the left edge of the daughterboard and pry up to release it from its recess.
    • Use a pair of tweezers to pull the daughterboard up and away from the bottom of the device and remove it.
Sonuç
After you've completed the repair, follow this guide to test your repair.
3 farklı kişi bu kılavuzu tamamladı.
Tarun Thiruma
35.352 İtibar
134 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 94
Her zaman: 6,922
