Giriş
Use this guide to replace the charging board on your Samsung Galaxy S21 Plus.
This guide was performed on the SM-G996B/DS (international) model. Other models have an additional antenna cable sitting in the edge of the midframe.
If you do not replace the adhesive seals when reassembling, your device will function normally, but will most likely lose its water protection.
You’ll need replacement adhesive to reattach components when reassembling the device.
Neye ihtiyacın var
Prepare an iOpener and apply it to the back cover for at least three minutes to loosen the adhesive underneath.
Secure a suction handle to the bottom edge of the back cover, as close to the edge as possible.
Lift the back cover with the suction handle to create a small gap between the back cover and the frame.
Insert an opening pick into the gap you created.
Slide the opening pick to the bottom left corner to slice the adhesive.
Leave the opening pick in place to prevent the adhesive from resealing.
Insert a second opening pick at the bottom edge of your phone.
Slide the opening pick to the bottom right corner to slice the adhesive.
Leave the opening picks in place to prevent the adhesive from resealing.
Insert a third opening pick at the bottom right corner of your phone.
Slide the opening pick along the right edge of your phone to slice the adhesive.
Leave the opening pick in the top right corner to prevent the adhesive from resealing.
Bu adımda kullanılan alet:Tweezers$4.99
Remove the back cover.
This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
Remove any adhesive chunks with a pair of tweezers or your fingers. Use some high concentration (over 90%) isopropyl alcohol to wipe away any adhesive residue.
If you're using Samsung custom-cut adhesives, follow this guide.
If you're using double-sided tape, follow this guide.
Insert an opening pick underneath the left bottom end of the NFC antenna and charging coil assembly.
Carefully slide the opening pick along the bottom left edge of the assembly to separate it from the battery.
Use a spudger to disconnect the charging coil by prying the connector straight up from its socket.
Use a spudger to disconnect the NFC antenna by prying the connector straight up from its socket.
Use a Phillips screwdriver to remove the five 3.9 mm-long screws securing the NFC antenna and charging coil assembly.
Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
Use a Phillips screwdriver to remove the six 3.9 mm-long screws securing the loudspeaker assembly.
Insert an opening pick into the gap between the top edge of the loudspeaker assembly and the midframe.
Use your opening pick to pry up the loudspeaker assembly by tilting it downwards.
Use a spudger to disconnect the main and interconnect flex cables from the motherboard by prying their upper connectors straight up from their sockets.
Use a spudger to disconnect the interconnect flex cable from the daughterboard by prying its bottom connector straight up from its socket.
Use your fingers or a pair of tweezers to carefully remove the interconnect flex cable.
Insert a SIM card eject tool, a SIM eject bit, or a straightened paper clip into the hole on the SIM tray located at the bottom edge of the phone.
Press directly into the hole to eject the SIM card tray.
Use a Phillips screwdriver to remove the three 3.4 mm-long screws securing the charging board.
Insert the pointed end of a spudger underneath the left edge of the charging board next to the main flex cable connector.
Use your spudger to pry up the charging board.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
After you've completed the repair, follow this guide to test your repair.
