Ana içeriğe geç
Samsung Galaxy S22 Ultra Back Cover Replacement
Neye ihtiyacın var
  1. Samsung Galaxy S22 Ultra Back Cover Replacement, Heat the right edge: adım 1, 1 resimden 1.
    • Let your phone's battery drain to below 25% before starting this repair. A charged lithium-ion battery may catch fire if damaged.
    • Heat an iOpener and apply it to the right edge of the back cover for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are susceptible to heat damage.
  2. Samsung Galaxy S22 Ultra Back Cover Replacement, Adhesive information: adım 2, 2 resimden 1. Samsung Galaxy S22 Ultra Back Cover Replacement, Adhesive information: adım 2, 2 resimden 2.
    • While you wait for the adhesive to soften, note the following:
    • There's adhesive securing the back cover around the perimeter of the frame.
    • The adhesive is strongest in the bottom right and top left corners.
  3. Samsung Galaxy S22 Ultra Back Cover Replacement, Insert an opening pick: adım 3, 3 resimden 1. Samsung Galaxy S22 Ultra Back Cover Replacement, Insert an opening pick: adım 3, 3 resimden 2. Samsung Galaxy S22 Ultra Back Cover Replacement, Insert an opening pick: adım 3, 3 resimden 3.
    • Apply a suction handle to the back cover, as close to the center of the right edge as possible.
    • Pull up on the suction handle with strong, steady force to create a gap between the cover and the frame.
    • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap.
  4. Samsung Galaxy S22 Ultra Back Cover Replacement, Slice the right adhesive: adım 4, 3 resimden 1. Samsung Galaxy S22 Ultra Back Cover Replacement, Slice the right adhesive: adım 4, 3 resimden 2. Samsung Galaxy S22 Ultra Back Cover Replacement, Slice the right adhesive: adım 4, 3 resimden 3.
    • Slide the pick back and forth along the right edge to slice through the adhesive.
    • Leave the pick inserted near the bottom of the right edge to prevent the adhesive from resealing.
  5. Samsung Galaxy S22 Ultra Back Cover Replacement, Heat the bottom edge: adım 5, 1 resimden 1.
    • Apply a heated iOpener to the bottom edge of the back cover for two minutes.
  6. Samsung Galaxy S22 Ultra Back Cover Replacement, Separate the corner adhesive: adım 6, 3 resimden 1. Samsung Galaxy S22 Ultra Back Cover Replacement, Separate the corner adhesive: adım 6, 3 resimden 2. Samsung Galaxy S22 Ultra Back Cover Replacement, Separate the corner adhesive: adım 6, 3 resimden 3.
    • Insert a second opening pick at the bottom right corner.
    • Angle the pick upward to match the curved edge and rotate it around the bottom right corner.
    • Be careful while slicing around the corners, as the glass is very fragile here. Work slowly to avoid cracking the glass.
  7. Samsung Galaxy S22 Ultra Back Cover Replacement, Slice the bottom adhesive: adım 7, 2 resimden 1. Samsung Galaxy S22 Ultra Back Cover Replacement, Slice the bottom adhesive: adım 7, 2 resimden 2.
    • Slide your opening pick to the bottom left corner to slice the adhesive.
    • Leave the pick in the bottom left corner to prevent the adhesive from resealing.
  8. Samsung Galaxy S22 Ultra Back Cover Replacement, Heat the left edge: adım 8, 1 resimden 1.
    • Apply a heated iOpener to the left edge of the back cover for two minutes.
  9. Samsung Galaxy S22 Ultra Back Cover Replacement, Separate the corner adhesive: adım 9, 3 resimden 1. Samsung Galaxy S22 Ultra Back Cover Replacement, Separate the corner adhesive: adım 9, 3 resimden 2. Samsung Galaxy S22 Ultra Back Cover Replacement, Separate the corner adhesive: adım 9, 3 resimden 3.
    • Insert a third opening pick at the bottom left corner.
    • Angle the pick upward to match the curved edge and rotate it around the bottom left corner.
  10. Samsung Galaxy S22 Ultra Back Cover Replacement, Slice the left adhesive: adım 10, 3 resimden 1. Samsung Galaxy S22 Ultra Back Cover Replacement, Slice the left adhesive: adım 10, 3 resimden 2. Samsung Galaxy S22 Ultra Back Cover Replacement, Slice the left adhesive: adım 10, 3 resimden 3.
    • Slide your opening pick along the left edge to slice the adhesive, stopping when you reach the power button.
    • Only insert the pick up to 5 mm, as you may damage the antenna flex cable or the power button cable.
    • Leave the pick in the left edge to prevent the adhesive from resealing.
  11. Samsung Galaxy S22 Ultra Back Cover Replacement, Heat the top edge: adım 11, 1 resimden 1.
    • Heat an iOpener and apply it to the top edge of the back cover for two minutes.
  12. Samsung Galaxy S22 Ultra Back Cover Replacement, Separate the corner adhesive: adım 12, 3 resimden 1. Samsung Galaxy S22 Ultra Back Cover Replacement, Separate the corner adhesive: adım 12, 3 resimden 2. Samsung Galaxy S22 Ultra Back Cover Replacement, Separate the corner adhesive: adım 12, 3 resimden 3.
    • Insert an opening pick in the gap at the top right edge.
    • Angle the pick upward to match the curved edge and rotate it around the top right corner.
  13. Samsung Galaxy S22 Ultra Back Cover Replacement, Slice the top adhesive: adım 13, 2 resimden 1. Samsung Galaxy S22 Ultra Back Cover Replacement, Slice the top adhesive: adım 13, 2 resimden 2.
    • Slide the pick to the top left corner to slice the adhesive.
    • Only insert the pick up to 4 mm, as you may damage the cameras or sensors.
    • Leave the pick in to prevent the adhesive from resealing.
  14. Samsung Galaxy S22 Ultra Back Cover Replacement, Separate the corner adhesive: adım 14, 2 resimden 1. Samsung Galaxy S22 Ultra Back Cover Replacement, Separate the corner adhesive: adım 14, 2 resimden 2.
    • Only insert the pick up to 4 mm, as you may damage the cameras.
    • Insert an opening pick in the gap at the top left edge.
    • Angle the pick upward to match the curved edge and rotate it around the top left corner.
  15. Samsung Galaxy S22 Ultra Back Cover Replacement, Slice the remaining adhesive: adım 15, 2 resimden 1. Samsung Galaxy S22 Ultra Back Cover Replacement, Slice the remaining adhesive: adım 15, 2 resimden 2.
    • Slide the pick toward the bottom camera to slice through the remaining adhesive, stopping before you reach the power button.
  16. Samsung Galaxy S22 Ultra Back Cover Replacement, Remove the back cover: adım 16, 3 resimden 1. Samsung Galaxy S22 Ultra Back Cover Replacement, Remove the back cover: adım 16, 3 resimden 2. Samsung Galaxy S22 Ultra Back Cover Replacement, Remove the back cover: adım 16, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Grab and remove the back cover.
    • If your cover is still sticking to the frame, slide an opening pick around the perimeter until the cover completely separates.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
    • If you're using custom-cut adhesives, follow this guide.
    • If you're using double-sided tape, follow this guide.
Sonuç
Compare your new replacement part to the original part—be sure to transfer remaining components and remove adhesive backings from the new part before installing.
8 farklı kişi bu kılavuzu tamamladı.
Clay Eickemeyer
81.100 İtibar
455 adet Kılavuz yazıldı
Ekip
Guide Team Guide Team üyesi
Staff
9 Üyeler
11.348 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 55
Son 7 gün: 215
Son 30 gün: 783
Her zaman: 36,925
