Ana içeriğe geç
Samsung Galaxy S8 Plus Screen Replacement
Neye ihtiyacın var
  1. Samsung Galaxy S8 Plus Screen Replacement, Back Glass: adım 1, 1 resimden 1.
    • Opening your phone will compromise its waterproof seals. Have replacement adhesive ready before you proceed, or take care to avoid liquid exposure if you reassemble your phone without replacing the adhesive.
    • Prepare an iOpener and heat the back of the phone along its left edge for about two minutes. This will help soften the adhesive securing the back cover.
    • You may need to reheat and reapply the iOpener several times to get the phone warm enough. Follow the iOpener instructions to avoid overheating.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the OLED display and internal battery are both susceptible to heat damage.
  2. Samsung Galaxy S8 Plus Screen Replacement: adım 2, 2 resimden 1. Samsung Galaxy S8 Plus Screen Replacement: adım 2, 2 resimden 2.
    • In the following steps, you'll be cutting through the adhesive securing the back cover.
    • The adhesive is laid out as seen in the first image, which shows the inside of the cover after it has been removed.
    • As seen from outside the phone, you'll be slicing through the adhesive in the areas shown:
    • Thick portions of adhesive
    • Thin areas of adhesive
    • Avoid prying or slicing in this area, to protect the fingerprint sensor flex cable.
  3. Samsung Galaxy S8 Plus Screen Replacement: adım 3, 2 resimden 1. Samsung Galaxy S8 Plus Screen Replacement: adım 3, 2 resimden 2.
    • Secure a suction cup to the back cover, as close to the heated edge as possible.
    • The suction cup will not make a good seal on the curved portion of the glass, so avoid putting it on the very edge.
    • If the phone's back cover is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
    • Lift the back cover's left edge with your suction cup, opening a slight gap between the back cover and the frame.
    • This may require a significant amount of force, but you only need to open a very slight gap with the suction cup to insert your tool.
    • If you have trouble, apply more heat to further soften the adhesive, and try again. The adhesive cools very fast, so you may need to heat it repeatedly.
    • If you're using an iOpener, follow instructions to avoid overheating it, or the gel pack may burst.
  4. Samsung Galaxy S8 Plus Screen Replacement: adım 4, 2 resimden 1. Samsung Galaxy S8 Plus Screen Replacement: adım 4, 2 resimden 2.
    • Insert an opening pick into the gap.
    • The rear glass can break if you use too much force or attempt to pry with metal tools.
    • Optionally, once the pick is inserted, you can add a few drops of isopropyl alcohol into the gap to help weaken the adhesive in the following steps.
    I strongly advise using a modeling knife to cut the adhesive when you get a sufficient gap otherwise you may easily break the corners of the extremely thin back glass on the phone (as I did).
    Michael De Angelis - Yanıt
    There are NO "Opening Picks" in the repair kit!!!!!
    CA Winters - Yanıt
  5. Samsung Galaxy S8 Plus Screen Replacement: adım 5, 3 resimden 1. Samsung Galaxy S8 Plus Screen Replacement: adım 5, 3 resimden 2. Samsung Galaxy S8 Plus Screen Replacement: adım 5, 3 resimden 3.
    • Slide your opening pick along the left edge of the phone to slice through the adhesive securing the back cover.
    • Afterward, it may help to leave the pick in place and grab a second pick as you proceed to the next step. Leaving the pick inserted can help prevent the glue you just separated from re-adhering.
  6. Samsung Galaxy S8 Plus Screen Replacement: adım 6, 2 resimden 1. Samsung Galaxy S8 Plus Screen Replacement: adım 6, 2 resimden 2.
    • Continue slicing through the adhesive along the bottom edge of the phone.
    • Re-heat the back cover as needed to prevent the glue from cooling and hardening.
    • The glued area is larger here, so you'll need to insert your pick farther into the phone to fully separate it.
    • Again, it may help to leave the opening pick in place and grab another one for the following step.
  7. Samsung Galaxy S8 Plus Screen Replacement: adım 7, 3 resimden 1. Samsung Galaxy S8 Plus Screen Replacement: adım 7, 3 resimden 2. Samsung Galaxy S8 Plus Screen Replacement: adım 7, 3 resimden 3.
    • Slice through the remaining adhesive along the top edge and right side.
    • You can damage the fingerprint sensor's flex cable if you insert your pick too far in this step. Work carefully and use the diagram in step 2 for guidance.
  8. Samsung Galaxy S8 Plus Screen Replacement: adım 8, 2 resimden 1. Samsung Galaxy S8 Plus Screen Replacement: adım 8, 2 resimden 2.
    • Don't try to fully remove the back cover yet.
    • Lift the back cover from its left edge and hinge it open slightly.
  9. Samsung Galaxy S8 Plus Screen Replacement: adım 9, 2 resimden 1. Samsung Galaxy S8 Plus Screen Replacement: adım 9, 2 resimden 2.
    • Use the point of a spudger to pry up and disconnect the fingerprint sensor flex cable.
  10. Samsung Galaxy S8 Plus Screen Replacement: adım 10, 3 resimden 1. Samsung Galaxy S8 Plus Screen Replacement: adım 10, 3 resimden 2. Samsung Galaxy S8 Plus Screen Replacement: adım 10, 3 resimden 3.
    • During reassembly, in order to reconnect the fingerprint sensor cable, first angle the back cover into position until the cable connector lines up perfectly over its socket.
    • Then, use the flat end of your spudger to gently snap the connector into place by pressing it straight down.
    • If you have slender hands, you may be able to press the connector into place with your finger. Just be careful not to strain the cable.
    • This takes patience and a bit of practice. Don't rush it or attempt to force the connector into place.
  11. Samsung Galaxy S8 Plus Screen Replacement: adım 11, 1 resimden 1.
    • Remove the back cover.
    • To install a new back cover:
    • Use tweezers to peel away any remaining adhesive from the phone's chassis. Then clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth to prep the surface for the new adhesive.
    • Peel the adhesive backing off of the new rear glass, carefully line up one edge of the glass against the phone chassis, and firmly press the glass onto the phone.
    • To reinstall the back cover, or to install a back cover without pre-installed adhesive, follow this guide.
    • Be sure to turn on your phone and test your repair before installing new adhesive and resealing the phone.
    • If desired, you may reinstall the back cover without replacing the adhesive. Remove any large chunks of adhesive that might prevent the back cover from sitting down flush. After installation, heat the back cover and apply pressure to secure it. It won't be waterproof, but the glue is usually more than strong enough to hold.
    • You may also need to transfer the camera bezel to your new part. If that's the case, follow our camera bezel replacement guide.
  12. Samsung Galaxy S8 Plus Screen Replacement, Disconnecting the Samsung Galaxy S8+ Battery: adım 12, 2 resimden 1. Samsung Galaxy S8 Plus Screen Replacement, Disconnecting the Samsung Galaxy S8+ Battery: adım 12, 2 resimden 2.
    • Remove the eleven 3.7 mm Phillips screws securing the wireless charging coil + antenna assembly.
    • If any screws are difficult to remove even when fully loosened, you can pull them out with tweezers.
  13. Samsung Galaxy S8 Plus Screen Replacement: adım 13, 2 resimden 1. Samsung Galaxy S8 Plus Screen Replacement: adım 13, 2 resimden 2.
    • The wireless charging coil + antenna assembly is also secured with small plastic clips.
    • Use a spudger to gently pry up the plastic in the marked areas to pop the clips free.
    The spudger tool has a pointy end and a flat end, it’s not clear which end should be used. Furthermore, the flat end is too wide to insert into the area shown, so the pointy end would seem obvious, but there is no clear indication whether it should be used to push any tabs in the area referenced, which I couldn’t find any, or if you’re meant to just sort of pry it in there until the area pops up, which is what I had to do. Then use the flat end of the spudger to lift it up gently after releasing, or popping the opposite side up as well.
    Mark Velasco - Yanıt
  14. Samsung Galaxy S8 Plus Screen Replacement: adım 14, 3 resimden 1. Samsung Galaxy S8 Plus Screen Replacement: adım 14, 3 resimden 2. Samsung Galaxy S8 Plus Screen Replacement: adım 14, 3 resimden 3.
    • Remove the wireless charging coil + antenna assembly.
    • To reinstall, first insert the top edge of the assembly into the phone's frame, and then gently press down on the rest of the assembly to snap it into place.
  15. Samsung Galaxy S8 Plus Screen Replacement: adım 15, 2 resimden 1. Samsung Galaxy S8 Plus Screen Replacement: adım 15, 2 resimden 2.
    • Use a spudger to disconnect the battery by prying the connector straight up from its socket.
  16. Samsung Galaxy S8 Plus Screen Replacement, Screen: adım 16, 1 resimden 1.
    • Using a spudger, disconnect the display by carefully prying up its flex cable connector from the socket on the motherboard.
    • Optionally, temporarily press the phone's back cover into place to protect the motherboard and battery from accidental damage in the following steps.
  17. Samsung Galaxy S8 Plus Screen Replacement: adım 17, 1 resimden 1.
    • Heat the bottom edge of the display to soften the adhesive securing it to the phone.
    • The glue securing the display can be significantly stronger than the glue that secures the back cover. If necessary, switch to a hair dryer or heat gun in order to apply enough heat to weaken the adhesive.
  18. Samsung Galaxy S8 Plus Screen Replacement: adım 18, 2 resimden 1. Samsung Galaxy S8 Plus Screen Replacement: adım 18, 2 resimden 2.
    • If possible, press a suction cup into place near the bottom edge of the display.
    • If your display is badly cracked, the suction cup may not stick. Try lifting the display with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
  19. Samsung Galaxy S8 Plus Screen Replacement: adım 19, 3 resimden 1. Samsung Galaxy S8 Plus Screen Replacement: adım 19, 3 resimden 2. Samsung Galaxy S8 Plus Screen Replacement: adım 19, 3 resimden 3.
    • Pull up on the suction cup to lift the display's lower edge, opening a slight gap between the display and the frame.
  20. Samsung Galaxy S8 Plus Screen Replacement: adım 20, 2 resimden 1. Samsung Galaxy S8 Plus Screen Replacement: adım 20, 2 resimden 2.
    • Slide your opening pick along the lower edge of the display to separate the adhesive underneath.
  21. Samsung Galaxy S8 Plus Screen Replacement: adım 21, 2 resimden 1. Samsung Galaxy S8 Plus Screen Replacement: adım 21, 2 resimden 2.
    • Leave the pick in place and grab a second pick as you proceed to the next step. Leaving the pick inserted can help prevent the glue you just separated from re-adhering.
  22. Samsung Galaxy S8 Plus Screen Replacement: adım 22, 1 resimden 1.
    • Reheat the iOpener and apply heat to the left edge of the display for at least two minutes.
  23. Samsung Galaxy S8 Plus Screen Replacement: adım 23, 3 resimden 1. Samsung Galaxy S8 Plus Screen Replacement: adım 23, 3 resimden 2. Samsung Galaxy S8 Plus Screen Replacement: adım 23, 3 resimden 3.
    • Use your opening pick to separate the adhesive under the left side of the display.
  24. Samsung Galaxy S8 Plus Screen Replacement: adım 24, 1 resimden 1.
  25. Samsung Galaxy S8 Plus Screen Replacement: adım 25, 3 resimden 1. Samsung Galaxy S8 Plus Screen Replacement: adım 25, 3 resimden 2. Samsung Galaxy S8 Plus Screen Replacement: adım 25, 3 resimden 3.
  26. Samsung Galaxy S8 Plus Screen Replacement: adım 26, 1 resimden 1.
  27. Samsung Galaxy S8 Plus Screen Replacement: adım 27, 3 resimden 1. Samsung Galaxy S8 Plus Screen Replacement: adım 27, 3 resimden 2. Samsung Galaxy S8 Plus Screen Replacement: adım 27, 3 resimden 3.
    • Gently work your opening pick under the top edge of the display to separate the adhesive underneath.
    • Don't pry too aggressively or you may damage the front-facing sensors and speaker assembly. You can come back to finish separating this section after the rest of the display is loose.
  28. Samsung Galaxy S8 Plus Screen Replacement: adım 28, 3 resimden 1. Samsung Galaxy S8 Plus Screen Replacement: adım 28, 3 resimden 2. Samsung Galaxy S8 Plus Screen Replacement: adım 28, 3 resimden 3.
    • Use your picks as needed to finish separating the adhesive beneath all areas of the display.
    • Remember that the display's flex cable is located just below the midpoint on the right edge, and may interfere with your pick.
    • Use a little extra caution when prying near the top edge so as not to damage the front-facing sensors and earpiece speaker.
  29. Samsung Galaxy S8 Plus Screen Replacement: adım 29, 1 resimden 1.
    • Lift and fully separate the left edge of the display from the frame.
    • The opposite edge will take a bit of a extra care to separate due to the display flex cable.
  30. Samsung Galaxy S8 Plus Screen Replacement: adım 30, 2 resimden 1. Samsung Galaxy S8 Plus Screen Replacement: adım 30, 2 resimden 2.
    • Route the display's flex cable through its hole in the frame in order to fully separate the right edge of the display.
  31. Samsung Galaxy S8 Plus Screen Replacement: adım 31, 2 resimden 1. Samsung Galaxy S8 Plus Screen Replacement: adım 31, 2 resimden 2.
    • Remove the display.
    • Follow this link for a detailed screen adhesive application guide.
    • Before installing a new display, it's very important to remove all traces of the old adhesive from the frame, while taking special care to remove any small glass fragments.
    • After removing all traces of glue and glass from the frame, clean the adhesion areas with 90% (or higher) isopropyl alcohol and a lint-free cloth or coffee filter. Swipe in one direction only, not back and forth.
    • This helps remove any remaining adhesive residue and preps the surface for the new adhesive.
    • If the frame is bent, or if any glue or glass remnants are left behind, the new display will not mount correctly and may be damaged. If necessary, replace the frame.
    • The best way to secure the new screen is with a sheet of custom-cut double-sided tape. Apply the tape to the back of the screen, then carefully feed the display cable through the frame. Align the screen and press it into place.
    في هاتفي ضربه بسيطه على الشاشه كيف اوقف تسريب الحبر الأسود
    Rozan Roz - Yanıt
    يوجد في هاتفي ضربه بسيطه على الشاشه كيف اوقف تسريب الحبر لفتره محدوده
    Rozan Roz - Yanıt
Sonuç
After you've completed the repair, follow this guide to test your repair.
80 farklı kişi bu kılavuzu tamamladı.
iRobot
1 İtibar
636 adet Kılavuz yazıldı
14 Yorum
After replacing LCD my phone showing message that “Battery temperature too low“ and pause charging. There are some video showing install wireless charging module after replacing LCD would solve this issue but for me it still not charging even with wireless charging module on. Any suggestion?
samion 2048 - Yanıt
samion 2048, This is because the device was turned on before attaching the wireless charging coil. The coil houses the ambient temperature sensor.
Brandon Tuey -
once you replace the front screen is the phone still water resistant?
Kaden Guanga - Yanıt
It will be water resistant if you reapply the nescassery adhesives.
Alexander Wiand -
I replaced my display with a another display with mid frame attatched already.all i did was change over my mother board,charging port and such and now if i power the phone on i feel it vibrate and see a blue led light up but that is all it does.screen is black and i can feel the vibration feedback if i touch the screen but nothing shows.going out of my mind trying to figure out what went wrong.
George Collins - Yanıt
i did it, very usefull video. Thank you. Hard Replacement Part
docteur-pc - Yanıt
It’s so good and detailed. Thanks
shammakalubo - Yanıt
I've noticed i can buy the screen by itself for like 10$
The oled is still working, just the glass is broken. Is there a way to just order the glass and take the OLED off the old screen and move over to new Glass?
Kyle - Yanıt
Very good! Thank you for the presentation
Brandon PIERCE - Yanıt
Hi there,
Just wondering if I’m just doing the front glass, do you need to take apart the back of the phone or can I just start at step 17 with the battery still attached?
Many thanks
Charles Daily - Yanıt
Same question as Kyle, if just the glass is broken, can the glass be repaired by itself without all the extra steps?
Thomas Higgins - Yanıt
Unfortunately since the display is curved it would be close to impossible to just remove the glass without damaging the display.
Bryan Amurrio -
I followed the guide to the fine details and my phone is just like a new one now !! Thank you iFixit and the Right to repair movement (y) keep it going.
I took my time with the screen replacement, did it in 3 different time, started with back cover, then internal parts and lastly the screen. I already have an iFixit toolkit which greatly helped to removal of the remaining glue/paste/adhesives.
Guide itself is top notch - detailed with photos and explanation.
The packaging of the screen part from iFixit also is one of a kind <3 optimized and guaranteed for success !
Being myself a PC / laptop builder and repair small / regular electronic - changing a phone's screen was a first - it was a very exciting and fun experience.
Thank you iFixit & author iRobot :D
warduke - Yanıt
Nice service good
Prakashraj Ns67 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 17
Son 7 gün: 124
Son 30 gün: 510
Her zaman: 234,247
