Giriş
Use this guide to remove the headphone jack on your Samsung Galaxy S9+.
You’ll need replacement adhesive to reattach the fingerprint sensor when reassembling the device.
Neye ihtiyacın var
Videoya Genel Bakış
Switch off your phone.
Use an iOpener to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes. You might want to repeat this step several times during the back cover removal.
Start to slide the tip of the opening pick from the bottom left corner along the side of the S9 Plus.
Leave the opening pick in its place after you cut the adhesive half way up the left side of the phone.
Slide the opening pick from the bottom right corner half way up the frame and leave it there.
Use the flat end of a spudger to pry up and disconnect the battery flex cable.
Use the flat end of a spudger to pry up and disconnect the headphone jack flex cable.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Secure the fingerprint sensor with pre-cut adhesive or double-sided adhesive tape during reassembly.
After you've completed the repair, follow this guide to test your repair.
Removal didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
5 farklı kişi bu kılavuzu tamamladı.
