Ana içeriğe geç
Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement, Heat the bottom edge: adım 1, 1 resimden 1.
    • Completely power off your device before you begin.
    • Apply a heated iOpener to the bottom edge of the device to loosen the adhesive underneath.
    • The display adhesive of the Galaxy Tab S7+ is extremely strong, and it's likely you need to reheat and reapply the iOpener several times before starting the display removal and during the removal procedure.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
  2. Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement, Screen removal information: adım 2, 3 resimden 1. Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement, Screen removal information: adım 2, 3 resimden 2. Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement, Screen removal information: adım 2, 3 resimden 3.
    • While you're waiting for the adhesive to loosen, note the following:
    • There's a long circuit board attached to the screen that sits parallel to the bottom edge.
    • Don't insert the pick more than 2 mm to avoid damaging the circuit board.
    • This image shows an example of the display separating from the glass panel.
    • Don't insert the pick more than 3 mm to avoid damaging the display.
  3. Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement, Insert an opening pick: adım 3, 3 resimden 1. Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement, Insert an opening pick: adım 3, 3 resimden 2. Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement, Insert an opening pick: adım 3, 3 resimden 3.
    • Once the screen is warm to touch, apply a suction handle to the bottom edge of the screen and as close to the edge as possible.
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction handle. If all else fails, you can superglue the suction cup to the screen.
    • Lift the screen with the suction handle to create a small gap between the screen and the frame.
    • Insert an opening pick into the gap between the frame and the screen.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  4. Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement, Separate the bottom adhesive: adım 4, 3 resimden 1. Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement, Separate the bottom adhesive: adım 4, 3 resimden 2. Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement, Separate the bottom adhesive: adım 4, 3 resimden 3.
    • Insert a new opening pick into the gap you created.
    • Slide the new pick along the bottom edge of the device towards the bottom-right corner.
  5. Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement, Heat the right edge: adım 5, 1 resimden 1.
    • Apply a heated iOpener to the right edge of the device to loosen the adhesive underneath.
  6. Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement, Separate the bottom-right corner adhesive: adım 6, 3 resimden 1. Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement, Separate the bottom-right corner adhesive: adım 6, 3 resimden 2. Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement, Separate the bottom-right corner adhesive: adım 6, 3 resimden 3.
    • Rotate the opening pick around the bottom-right corner of the device.
  7. Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement, Separate the right adhesive: adım 7, 3 resimden 1. Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement, Separate the right adhesive: adım 7, 3 resimden 2. Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement, Separate the right adhesive: adım 7, 3 resimden 3.
    • Don't insert the pick more than 3 mm to avoid damaging the components along the right edge.
    • Slide the new pick along the right edge of the device towards the top-right corner.
  8. Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement, Heat the top edge: adım 8, 1 resimden 1.
    • Apply a heated iOpener to the top edge of the device to loosen the adhesive underneath.
  9. Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement, Separate the top-right corner adhesive: adım 9, 3 resimden 1. Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement, Separate the top-right corner adhesive: adım 9, 3 resimden 2. Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement, Separate the top-right corner adhesive: adım 9, 3 resimden 3.
    • Rotate the opening pick around the top-right corner of the device.
  10. Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement, Separate the top adhesive: adım 10, 3 resimden 1. Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement, Separate the top adhesive: adım 10, 3 resimden 2. Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement, Separate the top adhesive: adım 10, 3 resimden 3.
    • Slide the new pick along the top edge of the device towards the top-left corner.
  11. Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement, Heat the left edge: adım 11, 1 resimden 1.
    • Apply a heated iOpener to the left edge of the device to loosen the adhesive underneath.
  12. Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement, Separate the top-left corner adhesive: adım 12, 3 resimden 1. Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement, Separate the top-left corner adhesive: adım 12, 3 resimden 2. Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement, Separate the top-left corner adhesive: adım 12, 3 resimden 3.
    • Rotate the opening pick around the top-left corner of the device.
  13. Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement, Separate the left adhesive: adım 13, 3 resimden 1. Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement, Separate the left adhesive: adım 13, 3 resimden 2. Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement, Separate the left adhesive: adım 13, 3 resimden 3.
    • Slide the new pick along the left edge of the device towards the bottom-left corner.
  14. Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement, Separate the bottom-left corner adhesive: adım 14, 3 resimden 1. Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement, Separate the bottom-left corner adhesive: adım 14, 3 resimden 2. Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement, Separate the bottom-left corner adhesive: adım 14, 3 resimden 3.
    • Rotate the opening pick around the bottom-left corner of the device.
    • At this point, the perimeter of the screen should be separated from the frame. If there's still resistance around the edges of the screen, use an opening pick to cut the adhesive again.
  15. Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement, Remove the screen: adım 15, 3 resimden 1. Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement, Remove the screen: adım 15, 3 resimden 2. Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement, Remove the screen: adım 15, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Don't try to remove the screen all the way yet; it's still connected to the frame by a flex cable.
    • With the top of the device facing you, pull the screen up and away from you like you're opening a book.
    • Rest the screen upside down and parallel to the frame before continuing.
    • Don't twist the screen or move it too far away from the frame to avoid damaging the flex cable.
    • During reassembly:
    • This is a good point to power on your tablet and test all functions before sealing it up. Be sure to power your tablet back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Use some high concentration (over 90%) isopropyl alcohol to wipe away any adhesive residue.
    • If you're using Samsung custom-cut adhesives, follow this guide. If you're using double-sided tape, follow this guide.
  16. Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement, Disconnect the display cable: adım 16, 2 resimden 1. Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement, Disconnect the display cable: adım 16, 2 resimden 2.
    • Use the flat end of a spudger to pry up and disconnect the display cable's press connector secured to the screen.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  17. Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement: adım 17, 2 resimden 1. Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement: adım 17, 2 resimden 2.
    • Use tweezers, or you fingers, to hold the display cable in place.
    • Use the flat end of a spudger to pry up and disconnect the fingerprint sensor's press connector attached to the display cable.
    • Take note of the display cable's position; you will need to bend it in the same way when connecting a new screen.
  18. Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement, Remove the screen: adım 18, 3 resimden 1. Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement, Remove the screen: adım 18, 3 resimden 2. Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement, Remove the screen: adım 18, 3 resimden 3.
    • Remove the screen from the frame.
  19. Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement, Unfasten the frame bracket: adım 19, 3 resimden 1. Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement, Unfasten the frame bracket: adım 19, 3 resimden 2. Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement, Unfasten the frame bracket: adım 19, 3 resimden 3.
    • Use a Phillips #00 screwdriver to remove the fifty 3 mm-long screws securing the frame bracket to the frame.
    • The third photo has the same screws marked by quadrant. Use this photo during reassembly to help account for all the screws:
    • Bottom-left = 9 screws
    • Bottom-right = 14 screws
    • Top-right = 12 screws
    • Top-left = 15 screws
    • If you're reassembling with the Samsung Self-Repair kit, be sure to replace the screws with new ones labeled #3229.
  20. Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement, Remove the frame bracket: adım 20, 3 resimden 1. Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement, Remove the frame bracket: adım 20, 3 resimden 2. Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement, Remove the frame bracket: adım 20, 3 resimden 3.
    • Lift the frame bracket away from the frame, making sure to thread the display cable through its socket.
  21. Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement, Disconnect the battery: adım 21, 2 resimden 1. Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement, Disconnect the battery: adım 21, 2 resimden 2.
    • Use the flat end of a spudger to pry up and disconnect the battery's press connector secured to the motherboard.
  22. Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement, Disconnect the daughterboard interconnect cable: adım 22, 2 resimden 1. Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement, Disconnect the daughterboard interconnect cable: adım 22, 2 resimden 2.
    • Use the flat end of a spudger to pry up and disconnect the daughterboard interconnect cable's press connector secured to the motherboard.
  23. Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement, Unfasten the charging daughterboard: adım 23, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the two 2 mm screws securing the charging daughterboard to the frame.
    • If you're reassembling with the Samsung Self-Repair kit, be sure to replace the screws with new ones labeled #3298.
  24. Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement, Remove the charging daughterboard: adım 24, 3 resimden 1. Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement, Remove the charging daughterboard: adım 24, 3 resimden 2. Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement, Remove the charging daughterboard: adım 24, 3 resimden 3.
    • Insert a spudger between the charging daughterboard and the frame.
    • Pry up with the spudger to release the clips securing the charging daughterboard.
    • Use your fingers to remove the charging daughterboard.
    • During reassembly, refasten the charging daughterboard screws first to properly align it into place, then reconnect the interconnect cable.
  25. Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement, Remove the interconnect cable: adım 25, 3 resimden 1. Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement, Remove the interconnect cable: adım 25, 3 resimden 2. Samsung Galaxy Tab S7 Plus USB-C Charging Port and Daughterboard Replacement, Remove the interconnect cable: adım 25, 3 resimden 3.
    Satın Al
    • Use the flat end of a spudger to pry up and disconnect the interconnect cable's press connector secured to the charging daughterboard.
    • Use tweezers, or your fingers, to remove the interconnect cable.
    • Set the cable aside. You'll reuse it during reassembly.
Sonuç
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
To reassemble your device, follow the instructions in reverse order and perform the opposite actions, e.g., "reattach" instead of "removing." Skip steps that use heating and prying, and pay close attention to the 📌 bullets as you work through the steps.
After you've completed the repair, download the Samsung Members App from the Galaxy Store or the Play Store, and follow the Samsung Self-Repair document (beginning page 9) to make sure your device is fully functional.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Samsung Galaxy Tab S7+ Answers community for help.
3 farklı kişi bu kılavuzu tamamladı.
Alex Diaz-Kokaisl
124.804 İtibar
582 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
136 Üyeler
17.324 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 22
Son 30 gün: 71
Her zaman: 2,395
