Ana içeriğe geç
Samsung Galaxy TabPro S Screen Replacement
Mitchell Caister
Mitchell Caister ve 3 diğer katkıda bulunanlar
En son June 8, 2022 tarihinde güncellendi
2 saat
Zor
Daha İyi Resimler Gerekli
Daha iyi giriş
For the Samsung Galaxy TabPro S, model SM-W700NZKAXAR, this procedure is necessary so that there are no safety concerns with a cracked or strained screen. Also, the quality of the screen should be upheld in a high standard. Thus, knowledge in repairing of the screen is advantageous.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Samsung Galaxy TabPro S Screen Replacement, Screen: adım 1, 1 resimden 1.
    • Apply heat around the screen to loosen the glue holding in the screen. A heat gun would be preferable as it needs to get relatively warm.
  2. Samsung Galaxy TabPro S Screen Replacement: adım 2, 1 resimden 1.
    • Attach the small suction cup near the edge of the screen.
    • Pry in between the screen and the frame with a plastic spudger.
    • Pull up with the suction cup while prying and the screen should begin gently disconnecting.
    • Use the spudger on all edges of the tablet between the screen and the frame.
    • The screen should release.
  3. Samsung Galaxy TabPro S Screen Replacement: adım 3, 1 resimden 1.
    • Disconnect the thick cable from the motherboard
    • Disconnect the golden cable from the motherboard
Sonuç
Bir başkası bu kılavuzu tamamladı.
Mitchell Caister
328 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team 3-4, Harley Spring 2022 IUPUI, Team 3-4, Harley Spring 2022 üyesi
IUPUI-HARLEY-S22S3G4
3 Üyeler
1Rehber Yorum
Where to find a replacement screen for a 2017 Samsung tab S pro 12 inch ?!?!?
ori gosi - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 26
Her zaman: 994
