Ana içeriğe geç
Samsung Galaxy Watch Active2 Screen Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Watch Active2 Screen Replacement, Turn off the watch: adım 1, 2 resimden 1. Samsung Galaxy Watch Active2 Screen Replacement, Turn off the watch: adım 1, 2 resimden 2.
    • Turn off the Galaxy Watch Active2 by pushing and holding the bottom button for approximately 3 seconds. You should feel a short vibration.
    • When the "Power off" symbol appears, tap the center of the screen to make it shut down. You should feel a longer vibration for confirmation.
  2. Samsung Galaxy Watch Active2 Screen Replacement, Remove the rear screws: adım 2, 1 resimden 1.
    • Use a Tri-point Y00 screwdriver to remove the four 4 mm-long screws on the back of the watch.
    Y1.5 works just as good
    BRIAN MIRANDA - Yanıt
    Bekomme ich nicht auf … Schrauben zu fest
    Tino Wehner - Yanıt
    The screws are attached to the cover. So you just need to loose them, not remove them.
    Yonic Surny - Yanıt
    Any tips for a too tight screw ?
    Daisy Doune - Yanıt
  3. Samsung Galaxy Watch Active2 Screen Replacement, Separate the back cover from the housing: adım 3, 3 resimden 1. Samsung Galaxy Watch Active2 Screen Replacement, Separate the back cover from the housing: adım 3, 3 resimden 2. Samsung Galaxy Watch Active2 Screen Replacement, Separate the back cover from the housing: adım 3, 3 resimden 3.
    • Use an opening pick and place it between the plastic back cover and the metal housing near the buttons.
    • Push the opening pick into the gap to separate the back cover from the housing.
    • Don’t remove the back cover all the way yet. There is a cable connecting it to the motherboard.
    There is a glue-ish gasket keeping it closed. I used an exacto knife to start it opening.
    This was super helpful thank you! Perfect timing
    this is trash -
    Waarmee kan ik de achterste oplaadplaat weer vast lijmen op de achterste behuizing
    Ilona Smit - Yanıt
  4. Samsung Galaxy Watch Active2 Screen Replacement, Disconnect the sensor array: adım 4, 2 resimden 1. Samsung Galaxy Watch Active2 Screen Replacement, Disconnect the sensor array: adım 4, 2 resimden 2.
    • Carefully lift the back cover to access the sensor array connector.
    • Use a spudger to disconnect the sensor array from the motherboard.
    Ou je peu me procurer le tourne vis tri point 000
    grenierlulu - Yanıt
  5. Samsung Galaxy Watch Active2 Screen Replacement, Remove the back cover: adım 5, 1 resimden 1.
    • Remove the back cover.
    Where would you recommend buying a new back panel/charger?
    Nathan Williams - Yanıt
    Una pregunta. y para poner el reemplazo sería necesario algún tipo de sellador o silicón?porque pues usualmente este tipo de tapas vienen sellados de fabrica para evitar cualquier posibilidad de que le pudiera entrar agua
    Jesus Frias - Yanıt
  6. Samsung Galaxy Watch Active2 Screen Replacement, Disconnect the display and speaker: adım 6, 3 resimden 1. Samsung Galaxy Watch Active2 Screen Replacement, Disconnect the display and speaker: adım 6, 3 resimden 2. Samsung Galaxy Watch Active2 Screen Replacement, Disconnect the display and speaker: adım 6, 3 resimden 3.
    • Use a spudger to disconnect the display assembly and the speaker.
  7. Samsung Galaxy Watch Active2 Screen Replacement, Disconnect the barometric sensor, buttons, and mic: adım 7, 3 resimden 1. Samsung Galaxy Watch Active2 Screen Replacement, Disconnect the barometric sensor, buttons, and mic: adım 7, 3 resimden 2. Samsung Galaxy Watch Active2 Screen Replacement, Disconnect the barometric sensor, buttons, and mic: adım 7, 3 resimden 3.
    • Use a spudger to disconnect the barometric sensor, the buttons, and the microphone.
  8. Samsung Galaxy Watch Active2 Screen Replacement, Lift the core assembly: adım 8, 2 resimden 1. Samsung Galaxy Watch Active2 Screen Replacement, Lift the core assembly: adım 8, 2 resimden 2.
    • Place a spudger underneath the motherboard at the top right next to the display connector.
    • Slightly twist and lever the spudger to loosen the core assembly.
    • It might help to also check the comments below this and the next step if you’re having difficulties.
    I would not suggest to do so. There are components underneath the motherboard as well. There are none in this specific corner, but the core assembly does not come out that easily and people might try other corners and positions. Rather unscrew the motherboard and remove the battery from the core assembly directly.
    Nicola Tambascia - Yanıt
    Yes! I was unable to remove the motherboard as pictured unless the screw was removed (Step 12). I suggest a re-ordering of steps in this guide.
    Jerry Rattanong -
    You have to sort of wiggle it up from all sides and gradually lift out the corner/sides adjacent to the spludger as shown. I took a few minutes doing it carefully, it's fairly snug. Avoid pulling the motherboard out from only one side if you must at your risk.
    Future Zen - Yanıt
  9. Samsung Galaxy Watch Active2 Screen Replacement, Remove the core assembly: adım 9, 3 resimden 1. Samsung Galaxy Watch Active2 Screen Replacement, Remove the core assembly: adım 9, 3 resimden 2. Samsung Galaxy Watch Active2 Screen Replacement, Remove the core assembly: adım 9, 3 resimden 3.
    • Grab the core assembly and carefully slide it out from under the cables.
    • Remove the core assembly.
    I had to remove that screw on the core assembly using a Phillips 000. When I initially tried lifting, the core assembly started to bend. Mine also has a connector under the core assembly near the thumb in the picture. The connector goes from the underside of the core assembly to the screen/body. It prevents me from removing the core assembly as I'm not sure how it should be removed examining it
    Louis Finney - Yanıt
    This step is really difficult, and I'm still not sure it was necessary. The core assembly is really packed in there, and it took me several attempts, lifting from various corners. Don't pull by the circuit board. It will bend if you're not careful. You've got to get under the core assembly. I had the most luck starting next to the display connector at the top, then moving to the sensor on the other end of the board (barometric sensor), then moving to the speakers on the left, and finally lifting from multiple points once it was out far enough. In really hoping I didn't damage anything.
    Karl Arp - Yanıt
    I think the comments here should be added to the step before.
    I would be very careful following Louis Finney's advice above. They are describing detaching the motherboard from the core assembly which also includes the battery and internal frame. Removing the motherboard from the rest of the core assembly exposes a very delicate looking ribbon cable that I nearly tore by trying to remove the screw holding the motherboard in place.
    As Karl Arp notes, trying to pry the core assembly up by the motherboard feels like it puts a lot of strain on the circuit board, so it might be necessary to go at it from multiple angles.
    Removing the whole core assembly was very difficult, and required a lot more force than I was expecting, and I had the luxury of being able to approach it from both sides, as the screen had already detached from the device (hence the need to repair), and still found it very challenging.
    I would advise, at a minimum applying mild heat to the metal outer frame to hopefully cause it to expand and give some additional clearance.
    Philip Hickey - Yanıt
    Goede middag hier bij stap 10 is het fout gegaan bij mij,
    De knop waar je hem mee aan uit zet is afgebroken snik snik.
    Nu lig ik eruit.
    Maar de uitleg die je geeft is prefect kan niet beter.
    Vraag is er nog hoop voor mij..
    B.v.D.
    Wim Roks - Yanıt
  10. Samsung Galaxy Watch Active2 Screen Replacement, Loosen the display: adım 10, 3 resimden 1. Samsung Galaxy Watch Active2 Screen Replacement, Loosen the display: adım 10, 3 resimden 2. Samsung Galaxy Watch Active2 Screen Replacement, Loosen the display: adım 10, 3 resimden 3.
    • Place the edge of an opening tool under the speaker unit.
    • Lever the opening tool down to separate the display from the frame.
    This was super simple to do after putting a bit of heat to the screen first. the adhesive peeled right up. Just be careful not to put too much heat to it or you can damage the screen.
    Mick - Yanıt
  11. Samsung Galaxy Watch Active2 Screen Replacement, Remove the frame: adım 11, 2 resimden 1. Samsung Galaxy Watch Active2 Screen Replacement, Remove the frame: adım 11, 2 resimden 2.
    • Remove the frame from the display.
    • Make sure to remove any remaining adhesive from the frame with isopropyl alcohol (>90%) before applying the adhesive or installing the new display.
    Bonjour, mon écran c'est d'écolé mais fonctionne toujours. Comment je peux le recoller ou avec quoi ?
    Yannick Babin - Yanıt
Sonuç
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%). You may need to remove adhesive backings from the new part before installing.
29 farklı kişi bu kılavuzu tamamladı.
Tobias Isakeit
124.495 İtibar
189 adet Kılavuz yazıldı
Ekip
17Kılavuz Yorumları
Does anyone know where to buy the replacement screen for Active 2? Or what keywords should I search for (SKU or model)?
Angelo Sembrano - Yanıt
SM-R830 for the 40mm version, SM-R820 for the 44mm one. People on ebay resell them but they cost upwards of $100. I’d look into broken watches of the same type that maybe the battery is dead and they’re selling it for cheap, then do a swap job on the (hopefully) working screen.
Justin Collins -
Seconding the question on where to buy a replacement screen
Arjun Ramakrishnan - Yanıt
You could be lucky on rounded.com
Tobias Isakeit - Yanıt
What adhesive would be best to use?
Kelsey Crank - Yanıt
This E600 adhesive could work for you if carefully applied not spilling it over the back of the display.
Tobias Isakeit -
I broke my 40mm Active1 screen, anyone know if I can put in a 40mm Watch 4 screen in and get the better resolution?
Kevin Vågen - Yanıt
Is there a way to test the existing display? I made mistake of swimming in watch and it went into a continual reboot loop before it quit doing anything. I've got a replacement battery and installed it pretty easily but even when everything is put together except the back screws, nothing happened on the display when I put it on a known to be working charger. When I compare the appearance of the display connector and the slot on the motherboard to the pictures in the tutorial it looks like there is some corrosion or the likes there that I am working on removing with Deoxit DN5. But I am trying to sort out if the display itself is damaged or if the bit of corrosion there is keeping it from powering up. I have a voltmeter and the battery seems to be putting out the power that it should be.
ehcasey70 - Yanıt
I just took mine apart due to water damage and it charges fully but no display. I also have some type of corrosion on the display connectors, so it sounds very similar.
Richard Welch -
ma montre ne charge plus, si le problème ne vient pas du socle il vient donc de la montre, si j'achète toute la coque arrière, la charge marchera t elle ?
Wiwi Bobo - Yanıt
brilliant ! easy and nice to follow thank you
Tómas - Yanıt
<h1>I DONT CARE LOL LLLLL STUPID WATCH APPLE WATCH BETTER</h1>
fref43wq - Yanıt
Mi reloj se queda en reboot y no pasa de ahí, alguien sabe como repararlo?
Karen Granados - Yanıt
I actually used a Tri-point Y0 screwdriver instead of the Y00 to remove the back screws. They both fit, but the Y00 was just too small to get a secure grip and started stripping one of the screws. After I switched to the Y0 I was able to remove the stripped screw and just continued to use that one without switching back.
D Contelmo - Yanıt
Where can we buy the screen GLUE only? My screen is fine, the adhesive has just worn off.
JacobD - Yanıt
After I followed the full procedure and the watch looks brand new, how can I be sure that the watch is still IP6X dustproof and IPX8 waterproof? Do these parameters change after I have fixed it?
Hav3funDJ - Yanıt
l'intervention est facile mais il faut les bons outils. Le tuto est parfait, merci.
laurent - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 28
Son 7 gün: 171
Son 30 gün: 892
Her zaman: 95,400
