Ana içeriğe geç
Samsung Galaxy Watch4 Motherboard Replacement
Neye ihtiyacın var
  1. Samsung Galaxy Watch4  Motherboard Replacement, Power down your Galaxy Watch4: adım 1, 1 resimden 1.
    • Before starting repairs, take your watch off the charger and power it down.
    • Remove the watch band.
  2. Samsung Galaxy Watch4  Motherboard Replacement, Unscrew the back cover: adım 2, 1 resimden 1.
    • Use a Tri-point Y00 screwdriver to remove the four 4.0 mm-long screws.
  3. Samsung Galaxy Watch4  Motherboard Replacement, Wedge open the back cover: adım 3, 2 resimden 1. Samsung Galaxy Watch4  Motherboard Replacement, Wedge open the back cover: adım 3, 2 resimden 2.
    • Insert an opening tool into the seam between the back cover and the metal housing.
    • Twist the opening tool to create a gap.
    • Don't try to remove the back cover all the way yet. The sensor flex cable is still connected to the motherboard.
  4. Samsung Galaxy Watch4  Motherboard Replacement, Disconnect the sensor flex cable: adım 4, 2 resimden 1. Samsung Galaxy Watch4  Motherboard Replacement, Disconnect the sensor flex cable: adım 4, 2 resimden 2.
    • Lay the watch face down.
    • Carefully swing open the back cover by folding the back cover to the opposite site of the created gap.
    • Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the motherboard.
  5. Samsung Galaxy Watch4  Motherboard Replacement, Remove the back cover: adım 5, 1 resimden 1.
    • Remove the back cover.
    • Make sure the rubber gasket is undamaged. If damaged, replace it with a new one during reassembly to maintain proper water resistance.
  6. Samsung Galaxy Watch4  Motherboard Replacement, Unscrew the motherboard: adım 6, 1 resimden 1.
    • Use a Phillips screwdriver to remove the 4.4 mm-long screw securing the motherboard.
  7. Samsung Galaxy Watch4  Motherboard Replacement, Disconnect the display flex cable: adım 7, 2 resimden 1. Samsung Galaxy Watch4  Motherboard Replacement, Disconnect the display flex cable: adım 7, 2 resimden 2.
    • Use the flat end of a spudger to disconnect the display flex cable.
  8. Samsung Galaxy Watch4  Motherboard Replacement, Disconnect the side buttons: adım 8, 2 resimden 1. Samsung Galaxy Watch4  Motherboard Replacement, Disconnect the side buttons: adım 8, 2 resimden 2.
    • Use a spudger to disconnect the flex cable of the crown buttons.
  9. Samsung Galaxy Watch4  Motherboard Replacement, Remove the motherboard: adım 9, 2 resimden 1. Samsung Galaxy Watch4  Motherboard Replacement, Remove the motherboard: adım 9, 2 resimden 2.
    • Use your fingers to lift the motherboard out from the watch assembly towards the bottom of the watch.
Sonuç
If possible, turn on your device and test your repair before resealing.
Bir başkası bu kılavuzu tamamladı.
Adriana Zwink
64.011 İtibar
167 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
124 Üyeler
24.168 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 74
Her zaman: 3,281
