Giriş
Use this guide to replace the motherboard on your Samsung Galaxy Watch4.
Neye ihtiyacın var
Before starting repairs, take your watch off the charger and power it down.
Remove the watch band.
Use a Tri-point Y00 screwdriver to remove the four 4.0 mm-long screws.
Insert an opening tool into the seam between the back cover and the metal housing.
Twist the opening tool to create a gap.
Lay the watch face down.
Carefully swing open the back cover by folding the back cover to the opposite site of the created gap.
Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the motherboard.
Use a Phillips screwdriver to remove the 4.4 mm-long screw securing the motherboard.
Use the flat end of a spudger to disconnect the display flex cable.
Use a spudger to disconnect the flex cable of the crown buttons.
Use your fingers to lift the motherboard out from the watch assembly towards the bottom of the watch.
If possible, turn on your device and test your repair before resealing.
Bir başkası bu kılavuzu tamamladı.
