Ana içeriğe geç
Samsung Gear S3 Battery Replacement
Neye ihtiyacın var
Videoya Genel Bakış
Öne Çıkan Belge
  1. Samsung Gear S3 Battery Replacement, Removing Wrist Straps: adım 1, 2 resimden 1. Samsung Gear S3 Battery Replacement, Removing Wrist Straps: adım 1, 2 resimden 2.
    • Locate the small push tabs on the back of the wrist straps, pushing them in to release the wrist strap.
    • Remove any casing or housing on the watch, and clean any dust/debris.
    • (Black lines are used for privacy)
  2. Samsung Gear S3 Battery Replacement, Removing Back Plate & Lifting Out: adım 2, 3 resimden 1. Samsung Gear S3 Battery Replacement, Removing Back Plate & Lifting Out: adım 2, 3 resimden 2. Samsung Gear S3 Battery Replacement, Removing Back Plate & Lifting Out: adım 2, 3 resimden 3.
    • Using a Tri-point screwdriver, unscrew the four (4) back screws. Note: The case screws may remain in their place.
    • Using a metal jimmy, and a little bit of force, push down then lever it up to pop out the case.
  3. Samsung Gear S3 Battery Replacement, Detaching Ribbons: adım 3, 3 resimden 1. Samsung Gear S3 Battery Replacement, Detaching Ribbons: adım 3, 3 resimden 2. Samsung Gear S3 Battery Replacement, Detaching Ribbons: adım 3, 3 resimden 3.
    • Detatch the three (3) ribbons carefully with a plastic spudger. The ribbons to detach is black, yellow, & blue. You should feel a little click when re-attaching later. Note: These parts are very delicate so exercise caution!
  4. Samsung Gear S3 Battery Replacement, Removing Motherboard: adım 4, 3 resimden 1. Samsung Gear S3 Battery Replacement, Removing Motherboard: adım 4, 3 resimden 2. Samsung Gear S3 Battery Replacement, Removing Motherboard: adım 4, 3 resimden 3.
    • Remove two Phillips head screws circled in red before the next step
    • Prying up from the corner with the red arrow, lift the motherboard and maneuver the ribbons out of the opening making sure not to tug or rip them.
    This is not to be critical of the author as this is a well done guide. This is only a CAUTION to make sure that individuals do see this prior to prying the motherboard apart. A portion of the step that is not stated or pointed out here are the two Phillips head screws that MUST be removed from the motherboard as the picture in Step 5 will show that those screws have been removed. You must remove them or you will break your motherboard. Thanks for the great guide!
    TechMan22 - Yanıt
    Thanks for the heads up! Looks like I missed including that step. I made sure to add it in.
    Mister HD -
  5. Samsung Gear S3 Battery Replacement, Splitting Motherboard from Battery Compartment: adım 5, 3 resimden 1. Samsung Gear S3 Battery Replacement, Splitting Motherboard from Battery Compartment: adım 5, 3 resimden 2. Samsung Gear S3 Battery Replacement, Splitting Motherboard from Battery Compartment: adım 5, 3 resimden 3.
    • Make sure to have the two Phillips head screws completely removed before attempting the following steps.
    • Pressing on the small black plastic area will give you leverage to pull off the motherboard gently.
    • Do NOT flip the motherboard without first detaching the battery's ribbon. The motherboard will still be connected by a ribbon. Only the battery's ribbon will be detached (Marked by the red arrow in the second photo). Using a flat tool to get underneath the ribbon will lift it up allowing you to flip the motherboard over.
    • The original battery will most likely be attached to the motherboard. A spudger will be needed to detach the battery from the motherboard. Note: Use caution, gently inserting and lifting as it allows. Use of any sharp or pointed tools can rupture the battery and will cause it to burst.
  6. Samsung Gear S3 Battery Replacement, Replace Battery: adım 6, 1 resimden 1.
    • Insert the new battery and test for power.
    • Remember to recycle your used batteries!
Sonuç
13 farklı kişi bu kılavuzu tamamladı.
Mister HD
553 İtibar
1 Kılavuz yazıldı
6Kılavuz Yorumları
Not a comment but a question: What happens with the waterproofing of the watch with this?
Arthur Mize - Yanıt
Of course with a take apart of any device the waterproofing will be gone unfortunately.
Mister HD -
Id heavily consider rewriting step 4. I almost pried the board off with the screws still attached because I read from left to right on the pictures. Device is okay but I was assuming an entire unit attached with screws was coming out of a shell. Good guide otherwise, thanks
Mike Duffy - Yanıt
Question - Is this the same procedure for the Frontier model of the S3?
Michael Maxson - Yanıt
A bit of a challenge for someone at the age of 63. But it worked out. Screws should be off before lifting the mainboard (step 4).
Jens Hektor - Yanıt
Is this similar to model number SM-R765T
Gear S3 Frontier.
Ruben Medina - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 13
Son 7 gün: 159
Son 30 gün: 702
Her zaman: 31,963
