Ana içeriğe geç
Samsung NX Mini Button Panel Replacement
Kelsea Weber
Kelsea Weber ve 3 diğer katkıda bulunanlar
En son May 7, 2024 tarihinde güncellendi
Tahmin yok
Orta
Is the button panel on your camera unresponsive? Are your buttons dirty, cracked or missing? This guide will show you how to access the button panel on your camera in order to make necessary repairs.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Samsung NX Mini Button Panel Replacement, Battery: adım 1, 3 resimden 1. Samsung NX Mini Button Panel Replacement, Battery: adım 1, 3 resimden 2. Samsung NX Mini Button Panel Replacement, Battery: adım 1, 3 resimden 3.
    • Orient the camera so the button panel and LCD are facing you.
    • Use a spudger or fingernail to open the battery compartment on the right side of the camera.
  2. Samsung NX Mini Button Panel Replacement: adım 2, 2 resimden 1. Samsung NX Mini Button Panel Replacement: adım 2, 2 resimden 2.
    • Push the blue trapdoor to the left to release the battery, and remove the battery.
    • There is no battery shown in this photo.
  3. Samsung NX Mini Button Panel Replacement, Front Case: adım 3, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the 4 mm screw inside the battery compartment.
  4. Samsung NX Mini Button Panel Replacement: adım 4, 1 resimden 1.
    • Remove the 4 mm Phillips #00 screw hiding in the external flash port.
  5. Samsung NX Mini Button Panel Replacement: adım 5, 1 resimden 1.
    • Remove the four 5 mm Phillips #00 screws from the lens assembly.
  6. Samsung NX Mini Button Panel Replacement: adım 6, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Remove the metal lens mount by hand or with tweezers.
    • Be careful not to touch the sensor in the center of the lens assembly.
  7. Samsung NX Mini Button Panel Replacement: adım 7, 1 resimden 1.
    • Use tweezers to remove the inner metal ring.
  8. Samsung NX Mini Button Panel Replacement: adım 8, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the three 4 mm screws from the bottom of the case.
  9. Samsung NX Mini Button Panel Replacement: adım 9, 2 resimden 1. Samsung NX Mini Button Panel Replacement: adım 9, 2 resimden 2.
    • Use your hands to slowly pull the front casing away from the camera.
    • The case is attached with multiple clips that may make a cracking noise as you pull it away from the camera.
  10. Samsung NX Mini Button Panel Replacement, Sensor: adım 10, 3 resimden 1. Samsung NX Mini Button Panel Replacement, Sensor: adım 10, 3 resimden 2. Samsung NX Mini Button Panel Replacement, Sensor: adım 10, 3 resimden 3.
    • Gently flip the sensor cover back to expose the screw attaching the sensor cover to the ribbon cable.
    • Use a Phillips #00 screwdriver to remove the 3 mm screw from the sensor cover.
    • Use tweezers to remove the metal contact cover. Be sure to carefully remove the cover so the gold contacts remain in place.
    • The gold lens contacts lying beneath the ribbon cable become loose when the screw and contact cover are removed.
  11. Samsung NX Mini Button Panel Replacement: adım 11, 2 resimden 1. Samsung NX Mini Button Panel Replacement: adım 11, 2 resimden 2.
    • Remove the four 4 mm Phillips #00 screws holding the sensor mount in place.
  12. Samsung NX Mini Button Panel Replacement: adım 12, 3 resimden 1. Samsung NX Mini Button Panel Replacement: adım 12, 3 resimden 2. Samsung NX Mini Button Panel Replacement: adım 12, 3 resimden 3.
    • Remove the four 4 mm Phillips #00 screws securing the battery compartment to the mother board.
    • Remove the battery compartment.
  13. Samsung NX Mini Button Panel Replacement: adım 13, 2 resimden 1. Samsung NX Mini Button Panel Replacement: adım 13, 2 resimden 2.
    • Use a spudger to disconnect the ribbon cable connecting the image sensor to the motherboard.
  14. Samsung NX Mini Button Panel Replacement: adım 14, 1 resimden 1.
    • Gently remove the sensor mount from the camera case.
  15. Samsung NX Mini Button Panel Replacement, Motherboard: adım 15, 2 resimden 1. Samsung NX Mini Button Panel Replacement, Motherboard: adım 15, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the 3 mm screw located below the wifi antenna.
  16. Samsung NX Mini Button Panel Replacement: adım 16, 2 resimden 1. Samsung NX Mini Button Panel Replacement: adım 16, 2 resimden 2.
    • Use tweezers to disconnect the wifi antenna from the motherboard.
  17. Samsung NX Mini Button Panel Replacement: adım 17, 3 resimden 1. Samsung NX Mini Button Panel Replacement: adım 17, 3 resimden 2. Samsung NX Mini Button Panel Replacement: adım 17, 3 resimden 3.
    • Use a spudger to disconnect the LCD ribbon cable by prying it straight up from the motherboard.
  18. Samsung NX Mini Button Panel Replacement: adım 18, 3 resimden 1. Samsung NX Mini Button Panel Replacement: adım 18, 3 resimden 2. Samsung NX Mini Button Panel Replacement: adım 18, 3 resimden 3.
    • Use a spudger to unlock the topmost ZIF connector by flipping open the black flap.
  19. Samsung NX Mini Button Panel Replacement: adım 19, 2 resimden 1. Samsung NX Mini Button Panel Replacement: adım 19, 2 resimden 2.
    • Insert the pointed end of a spudger into the hole in the middle of the ribbon cable.
    • Gently pull the spudger back to slide the ribbon cable out of its connector.
  20. Samsung NX Mini Button Panel Replacement: adım 20, 3 resimden 1. Samsung NX Mini Button Panel Replacement: adım 20, 3 resimden 2. Samsung NX Mini Button Panel Replacement: adım 20, 3 resimden 3.
    • Disconnect the blue ribbon cable from the motherboard.
    • Insert the pointed end of a spudger into the hole in the top of the ribbon.
    • Gently pull the ribbon from the connector.
  21. Samsung NX Mini Button Panel Replacement: adım 21, 1 resimden 1.
    • Remove the motherboard from the camera.
  22. Samsung NX Mini Button Panel Replacement, Button Panel: adım 22, 1 resimden 1.
    • Remove the three 4 mm Phillips #00 screws securing the button panel to the camera case.
  23. Samsung NX Mini Button Panel Replacement: adım 23, 1 resimden 1.
    • Use tweezers to lift the button panel cover away from the case.
Sonuç
Kelsea Weber
20.619 İtibar
32 adet Kılavuz yazıldı
Ekip
iFixit, Team S1-G1, Weber Summer 2018 iFixit, Team S1-G1, Weber Summer 2018 üyesi
FIX-WEBER-SU18S1G1
5 Üyeler
43 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 16
Her zaman: 496
