Ana içeriğe geç
Samsung NX Mini Flash Assembly Replacement
Neye ihtiyacın var
  1. Samsung NX Mini Flash Assembly Replacement, Battery: adım 1, 3 resimden 1. Samsung NX Mini Flash Assembly Replacement, Battery: adım 1, 3 resimden 2. Samsung NX Mini Flash Assembly Replacement, Battery: adım 1, 3 resimden 3.
    • Orient the camera so the button panel and LCD are facing you.
    • Use a spudger or fingernail to open the battery compartment on the right side of the camera.
  2. Samsung NX Mini Flash Assembly Replacement: adım 2, 2 resimden 1. Samsung NX Mini Flash Assembly Replacement: adım 2, 2 resimden 2.
    • Push the blue trapdoor to the left to release the battery, and remove the battery.
    • There is no battery shown in this photo.
  3. Samsung NX Mini Flash Assembly Replacement, Front Case: adım 3, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the 4 mm screw inside the battery compartment.
  4. Samsung NX Mini Flash Assembly Replacement: adım 4, 1 resimden 1.
    • Remove the 4 mm Phillips #00 screw hiding in the external flash port.
  5. Samsung NX Mini Flash Assembly Replacement: adım 5, 1 resimden 1.
    • Remove the four 5 mm Phillips #00 screws from the lens assembly.
  6. Samsung NX Mini Flash Assembly Replacement: adım 6, 1 resimden 1.
    • Remove the metal lens mount by hand or with tweezers.
    • Be careful not to touch the sensor in the center of the lens assembly.
  7. Samsung NX Mini Flash Assembly Replacement: adım 7, 1 resimden 1.
    • Use tweezers to remove the inner metal ring.
  8. Samsung NX Mini Flash Assembly Replacement: adım 8, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the three 4 mm screws from the bottom of the case.
  9. Samsung NX Mini Flash Assembly Replacement: adım 9, 2 resimden 1. Samsung NX Mini Flash Assembly Replacement: adım 9, 2 resimden 2.
    • Use your hands to slowly pull the front casing away from the camera.
    • The case is attached with multiple clips that may make a cracking noise as you pull it away from the camera.
  10. Samsung NX Mini Flash Assembly Replacement, Sensor: adım 10, 3 resimden 1. Samsung NX Mini Flash Assembly Replacement, Sensor: adım 10, 3 resimden 2. Samsung NX Mini Flash Assembly Replacement, Sensor: adım 10, 3 resimden 3.
    • Gently flip the sensor cover back to expose the screw attaching the sensor cover to the ribbon cable.
    • Use a Phillips #00 screwdriver to remove the 3 mm screw from the sensor cover.
    • Use tweezers to remove the metal contact cover. Be sure to carefully remove the cover so the gold contacts remain in place.
    • The gold lens contacts lying beneath the ribbon cable become loose when the screw and contact cover are removed.
  11. Samsung NX Mini Flash Assembly Replacement: adım 11, 2 resimden 1. Samsung NX Mini Flash Assembly Replacement: adım 11, 2 resimden 2.
    • Remove the four 4 mm Phillips #00 screws holding the sensor mount in place.
  12. Samsung NX Mini Flash Assembly Replacement: adım 12, 3 resimden 1. Samsung NX Mini Flash Assembly Replacement: adım 12, 3 resimden 2. Samsung NX Mini Flash Assembly Replacement: adım 12, 3 resimden 3.
    • Remove the four 4 mm Phillips #00 screws securing the battery compartment to the mother board.
    • Remove the battery compartment.
  13. Samsung NX Mini Flash Assembly Replacement: adım 13, 2 resimden 1. Samsung NX Mini Flash Assembly Replacement: adım 13, 2 resimden 2.
    • Use a spudger to disconnect the ribbon cable connecting the image sensor to the motherboard.
  14. Samsung NX Mini Flash Assembly Replacement: adım 14, 1 resimden 1.
    • Gently remove the sensor mount from the camera case.
  15. Samsung NX Mini Flash Assembly Replacement, Motherboard: adım 15, 2 resimden 1. Samsung NX Mini Flash Assembly Replacement, Motherboard: adım 15, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the 3 mm screw located below the wifi antenna.
  16. Samsung NX Mini Flash Assembly Replacement: adım 16, 2 resimden 1. Samsung NX Mini Flash Assembly Replacement: adım 16, 2 resimden 2.
    • Use tweezers to disconnect the wifi antenna from the motherboard.
  17. Samsung NX Mini Flash Assembly Replacement: adım 17, 3 resimden 1. Samsung NX Mini Flash Assembly Replacement: adım 17, 3 resimden 2. Samsung NX Mini Flash Assembly Replacement: adım 17, 3 resimden 3.
    • Use a spudger to disconnect the LCD ribbon cable by prying it straight up from the motherboard.
  18. Samsung NX Mini Flash Assembly Replacement: adım 18, 3 resimden 1. Samsung NX Mini Flash Assembly Replacement: adım 18, 3 resimden 2. Samsung NX Mini Flash Assembly Replacement: adım 18, 3 resimden 3.
    • Use a spudger to unlock the topmost ZIF connector by flipping open the black flap.
  19. Samsung NX Mini Flash Assembly Replacement: adım 19, 2 resimden 1. Samsung NX Mini Flash Assembly Replacement: adım 19, 2 resimden 2.
    • Insert the pointed end of a spudger into the hole in the middle of the ribbon cable.
    • Gently pull the spudger back to slide the ribbon cable out of its connector.
  20. Samsung NX Mini Flash Assembly Replacement: adım 20, 3 resimden 1. Samsung NX Mini Flash Assembly Replacement: adım 20, 3 resimden 2. Samsung NX Mini Flash Assembly Replacement: adım 20, 3 resimden 3.
    • Disconnect the blue ribbon cable from the motherboard.
    • Insert the pointed end of a spudger into the hole in the top of the ribbon.
    • Gently pull the ribbon from the connector.
  21. Samsung NX Mini Flash Assembly Replacement: adım 21, 1 resimden 1.
    • Remove the motherboard from the camera.
  22. Samsung NX Mini Flash Assembly Replacement, Flash Assembly: adım 22, 3 resimden 1. Samsung NX Mini Flash Assembly Replacement, Flash Assembly: adım 22, 3 resimden 2. Samsung NX Mini Flash Assembly Replacement, Flash Assembly: adım 22, 3 resimden 3.
    • Use a Phillips #00 screwdriver to remove the two 5 mm screws holding the flash assembly to the camera case.
  23. Samsung NX Mini Flash Assembly Replacement: adım 23, 2 resimden 1. Samsung NX Mini Flash Assembly Replacement: adım 23, 2 resimden 2.
    • Remove the flash assembly by gently pulling it away from the case.
    • You may need to use a spudger to release some of the clips holding the assembly in place.
    • Avoid touching the ends of the capacitor (the large black cylinder on the right). Capacitors that haven't been discharged may cause electric shock. Learn how to discharge a capacitor here.
Sonuç
Kelsea Weber
19.877 İtibar
32 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
135 Üyeler
17.198 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 14
Her zaman: 585
