Ana içeriğe geç
Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement
Neye ihtiyacın var
  1. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement, Unplug your refrigerator: adım 1, 1 resimden 1.
    • Unplug your refrigerator before you begin your repair.
  2. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement, Open the freezer drawer: adım 2, 1 resimden 1.
    • Slide the freezer drawer fully open.
  3. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement, Remove the freezer bins: adım 3, 1 resimden 1.
    • Lift and remove all the freezer bins from the drawer.
    • You should be left with a freezer door attached by two rails.
  4. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement, Remove the freezer door: adım 4, 3 resimden 1. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement, Remove the freezer door: adım 4, 3 resimden 2. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement, Remove the freezer door: adım 4, 3 resimden 3.
    • A plastic tab locks each drawer rail in place.
    • Use a flathead screwdriver to press in the plastic tab near the inner end of the drawer rail.
    • As you press the plastic tab, grasp the rail with your free hand and slide it towards you slightly to unlock the rail.
  5. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: adım 5, 2 resimden 1. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: adım 5, 2 resimden 2.
    • Repeat the rail unlock procedure on the other drawer rail.
    • Once both rails are unlocked, firmly pull both rails to slide them out of the refrigerator wall guides.
    • Remove the freezer drawer.
    • To install the freezer drawer:
    • Push the geared torsion bar until it rests at the very end of the rails.
    • Align the drawer rails to the refrigerator wall guides.
    • Close the freezer drawer until the rails lock back in place.
    • If you don't hear a click, visually check if the plastic tabs have locked in place. You may need to push the rails in a little further with your fingers to set the tabs.
  6. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement, Remove the freezer compartment evaporator cover: adım 6, 1 resimden 1.
    • Remove the screws securing the freezer evaporator cover.
  7. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: adım 7, 3 resimden 1. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: adım 7, 3 resimden 2. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: adım 7, 3 resimden 3.
    • Don't try to fully remove the evaporator cover yet, as it's connected to the refrigerator by a few wires in the top right corner.
    • Use your hands to lift the bottom edge of the evaporator cover up to release the lower plastic tabs.
    • Swing the evaporator cover upwards to access the connected wires behind it.
  8. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: adım 8, 2 resimden 1. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: adım 8, 2 resimden 2.
    • Use your fingers to squeeze and disconnect the fan cable connector from the back wall of the freezer.
  9. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: adım 9, 1 resimden 1.
    • Remove the evaporator cover.
  10. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement, Remove the freezer evaporator fan: adım 10, 3 resimden 1. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement, Remove the freezer evaporator fan: adım 10, 3 resimden 2. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement, Remove the freezer evaporator fan: adım 10, 3 resimden 3.
    • Guide the fan cable from the evaporator cover clips.
    • If you have trouble getting the cable out of the clips, squeeze the clips with pliers to create a wider gap.
  11. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: adım 11, 1 resimden 1.
    • Remove the screws securing the back panel to the evaporator cover.
  12. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: adım 12, 3 resimden 1. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: adım 12, 3 resimden 2. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: adım 12, 3 resimden 3.
    • Use your fingers to pry and release the clips along the short edge of the evaporator cover.
    • If the perimeter foam insulation prevents you from releasing the clips, cut the foam with scissors.
  13. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: adım 13, 3 resimden 1. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: adım 13, 3 resimden 2. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: adım 13, 3 resimden 3.
    • Lift and separate the back panel from the evaporator cover.
  14. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: adım 14, 1 resimden 1.
    • Remove the screws securing the fan to the evaporator cover.
  15. Samsung Refrigerator Evaporator Fan (Freezer Compartment) Replacement: adım 15, 1 resimden 1.
    • Lift and remove the evaporator fan.
    • During reassembly, be sure to install the fan in the right orientation: the side with the center label should face down towards the evaporator cover.
Sonuç
Repair didn’t go as planned? Ask our Answers Community for help.
nicO
15.927 İtibar
88 adet Kılavuz yazıldı
Ekip
Global Fixers Global Fixers üyesi
Community
33 Üyeler
574 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 15
Son 7 gün: 58
Son 30 gün: 227
Her zaman: 1,926
