Ana içeriğe geç
Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement
Neye ihtiyacın var
  1. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement, Unplug your refrigerator: adım 1, 1 resimden 1.
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement, Open the refrigerator doors: adım 2, 2 resimden 1. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement, Open the refrigerator doors: adım 2, 2 resimden 2.
    • Open both French doors for the refrigerator compartment.
  3. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement, Remove the shelves: adım 3, 2 resimden 1. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement, Remove the shelves: adım 3, 2 resimden 2.
    • Remove all the loose shelves and bins from the refrigerator compartment.
    • The bottom shelf is clipped in place. Follow the next step to remove it.
  4. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: adım 4, 3 resimden 1. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: adım 4, 3 resimden 2. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: adım 4, 3 resimden 3.
    • Two stiff plastic tabs (one on each side) secure the bottom shelf in place.
    • Press both plastic tabs firmly with your fingers and lift upward to unclip the bottom shelf.
    • If the shelf doesn't unclip, you can try using a flathead screwdriver to press each clip in.
    • Remove the bottom shelf.
  5. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement, Remove the refrigerator evaporator cover: adım 5, 3 resimden 1. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement, Remove the refrigerator evaporator cover: adım 5, 3 resimden 2. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement, Remove the refrigerator evaporator cover: adım 5, 3 resimden 3.
    • Use a flathead screwdriver to pry and remove the top screw cover on the evaporator cover.
  6. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: adım 6, 1 resimden 1.
    • Remove the screws securing the evaporator cover.
  7. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: adım 7, 3 resimden 1. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: adım 7, 3 resimden 2. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: adım 7, 3 resimden 3.
    • Grasp the right edge of the evaporator cover with your hands and swing it outwards toward you.
    • Don't try to fully remove the cover in this step, as it's connected by several wires.
  8. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: adım 8, 1 resimden 1.
    • Squeeze and disconnect all the wire connectors connecting the evaporator cover to the refrigerator.
  9. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: adım 9, 2 resimden 1. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: adım 9, 2 resimden 2.
    • Pull the evaporator cover towards you and remove it.
  10. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement, Remove the evaporator fan: adım 10, 1 resimden 1.
    • Remove the screws securing the fan bracket to the evaporator cover.
  11. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: adım 11, 2 resimden 1. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: adım 11, 2 resimden 2.
    • Remove the fan cable from the cover clips.
    • If you have trouble getting the cable out of the clips, squeeze the clips with pliers to create a wider gap.
  12. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: adım 12, 2 resimden 1. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: adım 12, 2 resimden 2.
    • Lift the loose edge of the fan bracket up.
  13. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: adım 13, 2 resimden 1. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: adım 13, 2 resimden 2.
    • The fan is pressure-fit in place with some foam insulation.
    • Use your fingers to press the fan out of its recess.
  14. Samsung Refrigerator Evaporator Fan (Refrigerator Compartment) Replacement: adım 14, 1 resimden 1.
    • Remove the fan.
    • During reassembly, be sure to install the fan in the right orientation: the side with the center label should face down, towards the evaporator cover.
Sonuç
Repair didn’t go as planned? Ask our Answers Community for help.
2 farklı kişi bu kılavuzu tamamladı.
nicO
15.945 İtibar
89 adet Kılavuz yazıldı
Ekip
Team Vulcan Team Vulcan üyesi
Staff
6 Üyeler
212 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 19
Son 30 gün: 144
Her zaman: 4,403
