Ana içeriğe geç
Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker)
Neye ihtiyacın var
  1. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Unplug your refrigerator: adım 1, 1 resimden 1.
    • Unplug your refrigerator before you begin your repair.
    FixBot'a Sor
    Yorum Ekle
  2. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Open the freezer drawer: adım 2, 2 resimden 1. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Open the freezer drawer: adım 2, 2 resimden 2.
    • Slide the freezer drawer fully open.
    FixBot'a Sor
    Yorum Ekle
  3. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Remove the freezer bins: adım 3, 3 resimden 1. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Remove the freezer bins: adım 3, 3 resimden 2. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Remove the freezer bins: adım 3, 3 resimden 3.
    • Lift and remove all the freezer bins from the drawer.
    • You may need to open the refrigerator doors in order to remove the large bin.
    FixBot'a Sor
    Yorum Ekle
  4. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Remove the freezer door: adım 4, 3 resimden 1. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Remove the freezer door: adım 4, 3 resimden 2. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Remove the freezer door: adım 4, 3 resimden 3.
    • A plastic tab locks each drawer rail in place.
    • Use a flathead screwdriver or your fingers to press in the plastic tab near the inner end of the drawer rail.
    • As you press the plastic tab, grasp the rail with your free hand and slide it towards you slightly to unlock the rail.
    FixBot'a Sor
    Yorum Ekle
  5. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker): adım 5, 2 resimden 1. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker): adım 5, 2 resimden 2.
    • Repeat the rail unlock procedure on the other drawer rail.
    • Once both rails are unlocked, firmly pull both rails to slide them out of the refrigerator wall guides.
    • Remove the freezer drawer.
    • To install the freezer drawer:
    • Push the geared torsion bar until it rests at the very end of the rails.
    • Align the drawer rails to the refrigerator wall guides.
    • Close the freezer drawer until the rails lock back in place.
    • If you don't hear a click, visually check if the plastic tabs have locked in place. You may need to push the rails in a little further with your fingers to set the tabs.
    FixBot'a Sor
    Yorum Ekle
  6. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Unfasten the icemaker assembly: adım 6, 2 resimden 1. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Unfasten the icemaker assembly: adım 6, 2 resimden 2.
    • Use a Phillips screwdriver to remove the screws securing the icemaker assembly to the freezer ceiling.
    FixBot'a Sor
    Yorum Ekle
  7. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Disconnect the icemaker assembly: adım 7, 2 resimden 1. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Disconnect the icemaker assembly: adım 7, 2 resimden 2.
    • Grasp the front edge of the icemaker assembly and tilt it downwards.
    • Don't try to remove the icemaker yet, as it's still connected by a few wires.
    FixBot'a Sor
    Yorum Ekle
  8. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker): adım 8, 2 resimden 1. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker): adım 8, 2 resimden 2.
    • Use your fingers to guide the wire harness out of the icemaker assembly.
    FixBot'a Sor
    Yorum Ekle
  9. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker): adım 9, 3 resimden 1. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker): adım 9, 3 resimden 2. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker): adım 9, 3 resimden 3.
    • Squeeze the icemaker cable connector and pull to disconnect it.
    FixBot'a Sor
    Yorum Ekle
  10. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker): adım 10, 1 resimden 1.
    • Remove the icemaker assembly.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Repair didn’t go as planned? Ask our Answers community for help.
2 farklı kişi bu kılavuzu tamamladı.
Arthur Shi
344.141 İtibar
915 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
31.622 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 31
Son 30 gün: 147
Her zaman: 2,180
