Ana içeriğe geç
Samsung Refrigerator Icemaker Assembly Replacement
Neye ihtiyacın var
  1. Samsung Refrigerator Icemaker Assembly Replacement, Unplug your refrigerator: adım 1, 1 resimden 1.
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
    FixBot'a Sor
    Yorum Ekle
  2. Samsung Refrigerator Icemaker Assembly Replacement, Open the refrigerator doors: adım 2, 2 resimden 1. Samsung Refrigerator Icemaker Assembly Replacement, Open the refrigerator doors: adım 2, 2 resimden 2.
    • Open both French doors for the refrigerator compartment.
    FixBot'a Sor
    Yorum Ekle
  3. Samsung Refrigerator Icemaker Assembly Replacement, Remove the ice bucket: adım 3, 1 resimden 1.
    • The ice bucket should be located in the upper left side of your refrigerator. It may have "Ice Master" or "Ice Max" on the outside.
    FixBot'a Sor
    Yorum Ekle
  4. Samsung Refrigerator Icemaker Assembly Replacement, Remove the ice bucket: adım 4, 3 resimden 1. Samsung Refrigerator Icemaker Assembly Replacement, Remove the ice bucket: adım 4, 3 resimden 2. Samsung Refrigerator Icemaker Assembly Replacement, Remove the ice bucket: adım 4, 3 resimden 3.
    FixBot'a Sor
    Yorum Ekle
  5. Samsung Refrigerator Icemaker Assembly Replacement, Check the ice bucket condition: adım 5, 1 resimden 1.
    • Check for cracks or fractures in the ice bucket and auger assembly. Replace the bucket as needed.
    • Check the gasket around the edge of the bucket. If the gasket's ripped, cracked, rolled or has become too rigid, the bucket won't seal properly and cause condensation to seep in and freeze.
    FixBot'a Sor
    Yorum Ekle
  6. Samsung Refrigerator Icemaker Assembly Replacement, Unfasten the cable cover panel: adım 6, 2 resimden 1. Samsung Refrigerator Icemaker Assembly Replacement, Unfasten the cable cover panel: adım 6, 2 resimden 2.
    • Remove the wire harness screw securing the cable cover panel.
    FixBot'a Sor
    Yorum Ekle
  7. Samsung Refrigerator Icemaker Assembly Replacement, Remove the cable cover panel: adım 7, 3 resimden 1. Samsung Refrigerator Icemaker Assembly Replacement, Remove the cable cover panel: adım 7, 3 resimden 2. Samsung Refrigerator Icemaker Assembly Replacement, Remove the cable cover panel: adım 7, 3 resimden 3.
    • Use your fingers to slide the cable cover panel towards the front of the refrigerator to unlatch it.
    • Remove the cable cover panel.
    • During reassembly, make sure this panel clips fully in place, or the ice tray won't slide in properly.
    FixBot'a Sor
    Yorum Ekle
  8. Samsung Refrigerator Icemaker Assembly Replacement, Disconnect the icemaker harness: adım 8, 2 resimden 1. Samsung Refrigerator Icemaker Assembly Replacement, Disconnect the icemaker harness: adım 8, 2 resimden 2.
    • The exact configuration of the connectors may vary on your refrigerator.
    • Disconnect the left-most yellow connector:
    • Squeeze the locking tab with your fingers.
    • Rock the connector gently side to side to disconnect it.
    • Use your fingers or a screwdriver to guide the wire harness out of the wall clips.
    FixBot'a Sor
    Yorum Ekle
  9. Samsung Refrigerator Icemaker Assembly Replacement, Unfasten the air tunnel: adım 9, 1 resimden 1.
    • Remove the ice maker screw securing the air tunnel flap.
    FixBot'a Sor
    Yorum Ekle
  10. Samsung Refrigerator Icemaker Assembly Replacement, Remove the icemaker assembly: adım 10, 3 resimden 1. Samsung Refrigerator Icemaker Assembly Replacement, Remove the icemaker assembly: adım 10, 3 resimden 2. Samsung Refrigerator Icemaker Assembly Replacement, Remove the icemaker assembly: adım 10, 3 resimden 3.
    • A plastic clip holds the air tunnel flap in place.
    • Use a flathead screwdriver to pry and loosen the air tunnel flap from the plastic clip.
    FixBot'a Sor
    Yorum Ekle
  11. Samsung Refrigerator Icemaker Assembly Replacement: adım 11, 2 resimden 1. Samsung Refrigerator Icemaker Assembly Replacement: adım 11, 2 resimden 2.
    • Use your fingers to pull the air tunnel flap down enough to access the internals.
    FixBot'a Sor
    Yorum Ekle
  12. Samsung Refrigerator Icemaker Assembly Replacement: adım 12, 2 resimden 1. Samsung Refrigerator Icemaker Assembly Replacement: adım 12, 2 resimden 2.
    • Use a flathead screwdriver to gently pry the refrigerant loop down by 1–1.5 cm.
    • During reassembly, use your fingers to push the refrigerant loop back up.
    FixBot'a Sor
    Yorum Ekle
  13. Samsung Refrigerator Icemaker Assembly Replacement: adım 13, 3 resimden 1. Samsung Refrigerator Icemaker Assembly Replacement: adım 13, 3 resimden 2. Samsung Refrigerator Icemaker Assembly Replacement: adım 13, 3 resimden 3.
    • A plastic clip holds the icemaker in place.
    • Use your fingers to press and release the plastic clip.
    • This clip is stiff and may require substantial force.
    FixBot'a Sor
    Yorum Ekle
  14. Samsung Refrigerator Icemaker Assembly Replacement: adım 14, 2 resimden 1. Samsung Refrigerator Icemaker Assembly Replacement: adım 14, 2 resimden 2.
    • Pull the front edge of the icemaker assembly down slightly to loosen it.
    • Be careful not to bend the refrigerant loop too much as you pull the front edge, or you'll damage the loop.
    • Carefully slide the icemaker assembly out of its housing.
    FixBot'a Sor
    Yorum Ekle
  15. Samsung Refrigerator Icemaker Assembly Replacement, Removing the Ice Maker: adım 15, 2 resimden 1. Samsung Refrigerator Icemaker Assembly Replacement, Removing the Ice Maker: adım 15, 2 resimden 2.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Be sure to dry any moisture that remains in the ice room before reassembly to prevent repair failure.
Repair didn’t go as planned? Ask our Answers Community for help.
3 farklı kişi bu kılavuzu tamamladı.
nicO
15.990 İtibar
89 adet Kılavuz yazıldı
Ekip
Team Vulcan Team Vulcan üyesi
Staff
6 Üyeler
306 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 53
Son 7 gün: 292
Son 30 gün: 1,200
Her zaman: 26,967
