Ana içeriğe geç
Samsung WB150F Memory Card Replacement
Keith Albergaria
Keith Albergaria ve 7 diğer katkıda bulunanlar
En son December 15, 2023 tarihinde güncellendi
3 dakika
Çok kolay
This is a streamlined guide on how to replace Samsung WB150F Memory Card. There are no tools needed for this replacement. There are many parts at risk of being damaged, ensure that you follow the procedure with care. The time needed to complete this procedure is approximately 1 to 2 minutes.
  1. Samsung WB150F Memory Card Replacement, Memory Card: adım 1, 1 resimden 1.
    • Flip the camera upside-down so that the compartment with the battery and memory card is facing you.
  2. Samsung WB150F Memory Card Replacement: adım 2, 2 resimden 1. Samsung WB150F Memory Card Replacement: adım 2, 2 resimden 2.
    • Using your finger, slide the plastic lock-tab to the left.
    • The compartment should swing open.
  3. Samsung WB150F Memory Card Replacement: adım 3, 1 resimden 1.
    • The larger cavity is for the battery.
    • The small thin cavity is where the memory card goes.
    • Press lightly on the memory card to eject it from the camera.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Keith Albergaria
202 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-4, Vijaybhaskar Spring 2015 UMass Dartmouth, Team 4-4, Vijaybhaskar Spring 2015 üyesi
UMASSD-VIJAYBHASKAR-S15S4G4
3 Üyeler
6 adet Kılavuz yazıldı
2Kılavuz Yorumları
Will a micro cd n an adapter fit n the camera?
Maria Elena Will - Yanıt
I was looking for max size compatability. Most folks already know how to remove and install it.
bob kavanaugh - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 21
Her zaman: 1,043
