Ana içeriğe geç
Samsung Watch Active Battery Replacement
Neye ihtiyacın var
  1. Samsung Watch Active Battery Replacement, Turn off the watch: adım 1, 2 resimden 1. Samsung Watch Active Battery Replacement, Turn off the watch: adım 1, 2 resimden 2.
    • Turn off the Galaxy Watch Active by pushing and holding the bottom button for approximately 3 seconds. You should feel a short vibration.
    • When the "Power off" symbol appears tap the center of the screen to make it shut down. You should feel a longer vibration for confirmation.
    FixBot'a Sor
    Yorum Ekle
  2. Samsung Watch Active Battery Replacement, Remove the rear screws: adım 2, 1 resimden 1.
    • Use a Tri-point Y00 screwdriver to remove the four 4 mm-long screws on the back of the watch.
    FixBot'a Sor
    Yorum Ekle
  3. Samsung Watch Active Battery Replacement, Separate the back cover from the housing: adım 3, 3 resimden 1. Samsung Watch Active Battery Replacement, Separate the back cover from the housing: adım 3, 3 resimden 2. Samsung Watch Active Battery Replacement, Separate the back cover from the housing: adım 3, 3 resimden 3.
    • Use an opening tool and place it between the plastic back cover and the metal housing near the buttons.
    • Push the tip of the opening tool into the gap to separate the back cover from the housing.
    • Don’t remove the back cover all the way yet. There is a cable connecting it to the motherboard.
    FixBot'a Sor
    Yorum Ekle
  4. Samsung Watch Active Battery Replacement, Disconnect the sensor array: adım 4, 2 resimden 1. Samsung Watch Active Battery Replacement, Disconnect the sensor array: adım 4, 2 resimden 2.
    • Carefully lift the back cover approximately 2 cm to access the sensor array connector near the two buttons.
    • Use a spudger to disconnect the sensor array from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  5. Samsung Watch Active Battery Replacement, Remove the back cover: adım 5, 1 resimden 1.
    • Remove the back cover.
    FixBot'a Sor
    Yorum Ekle
  6. Samsung Watch Active Battery Replacement, Disconnect the motherboard: adım 6, 3 resimden 1. Samsung Watch Active Battery Replacement, Disconnect the motherboard: adım 6, 3 resimden 2. Samsung Watch Active Battery Replacement, Disconnect the motherboard: adım 6, 3 resimden 3.
    • Use the flat end of a spudger to disconnect the display assembly, the microphone and pressure sensor array, and side button.
    FixBot'a Sor
    Yorum Ekle
  7. Samsung Watch Active Battery Replacement, Undo the mic tape: adım 7, 3 resimden 1. Samsung Watch Active Battery Replacement, Undo the mic tape: adım 7, 3 resimden 2. Samsung Watch Active Battery Replacement, Undo the mic tape: adım 7, 3 resimden 3.
    • Use an opening pick to peel back the thin tape belonging to the microphone array.
    • When re-assembling make sure this tape properly sticks to the motherboard by pressing it down with the flat end of a spudger.
    FixBot'a Sor
    Yorum Ekle
  8. Samsung Watch Active Battery Replacement, Remove the motherboard screw: adım 8, 1 resimden 1.
    • Use a Phillips screwdriver to remove the 4.4 mm-long screw holding the motherboard in place.
    FixBot'a Sor
    Yorum Ekle
  9. Samsung Watch Active Battery Replacement, Loosen the motherboard: adım 9, 3 resimden 1. Samsung Watch Active Battery Replacement, Loosen the motherboard: adım 9, 3 resimden 2. Samsung Watch Active Battery Replacement, Loosen the motherboard: adım 9, 3 resimden 3.
    • Use an opening pick to loosen the motherboard from the core assembly.
    • The plastic tab holding the motherboard in place is fragile, so don't lift the motherboard up until it has cleared the tab.
    FixBot'a Sor
    Yorum Ekle
  10. Samsung Watch Active Battery Replacement, Remove the motherboard: adım 10, 3 resimden 1. Samsung Watch Active Battery Replacement, Remove the motherboard: adım 10, 3 resimden 2. Samsung Watch Active Battery Replacement, Remove the motherboard: adım 10, 3 resimden 3.
    • Slide the motherboard out from under the plastic tab to remove it.
    FixBot'a Sor
    Yorum Ekle
  11. Samsung Watch Active Battery Replacement, Lift the battery: adım 11, 3 resimden 1. Samsung Watch Active Battery Replacement, Lift the battery: adım 11, 3 resimden 2. Samsung Watch Active Battery Replacement, Lift the battery: adım 11, 3 resimden 3.
    • Insert the flat end of a spudger between the bottom of the battery and the core frame.
    • The battery is secured with some mild adhesive.
    • Use the spudger to lever up the battery.
    FixBot'a Sor
    Yorum Ekle
  12. Samsung Watch Active Battery Replacement, Remove the battery: adım 12, 3 resimden 1. Samsung Watch Active Battery Replacement, Remove the battery: adım 12, 3 resimden 2. Samsung Watch Active Battery Replacement, Remove the battery: adım 12, 3 resimden 3.
    • Remove the battery from the core assembly.
    • The battery connector is fixed with mild adhesive.
    • When installing a new battery make sure the tiny hole on the battery connector aligns with the pin on the core frame.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. Press the new battery firmly into place.
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 1 more hour. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
19 farklı kişi bu kılavuzu tamamladı.
Tobias Isakeit
134.382 İtibar
189 adet Kılavuz yazıldı
Ekip
1Rehber Yorum
Good guide! With a few modifications, usable for the Samsung Active Watch 2. The only pitfall with the Active watch 2 is the small solder ribbon cable on the underside of the motherboard that could tear if you try to remove the board completely
anghofus - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 27
Son 30 gün: 118
Her zaman: 12,874
