Ana içeriğe geç
Samsung Watch Active Screen Assembly Replacement
Tobias Isakeit
Tobias Isakeit
En son July 15, 2024 tarihinde güncellendi
25 - 55 dakika
Orta
Öne Çıkan Kılavuzlar
Use this guide to replace a cracked or broken screen assembly on your Samsung Galaxy Watch Active.
Note: Some replacement screens come as screen-only without a new frame. That's a different procedure from what's shown in this guide. If you're replacing the screen only, follow this guide instead.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Samsung Watch Active Screen Assembly Replacement, Turn off the watch: adım 1, 2 resimden 1. Samsung Watch Active Screen Assembly Replacement, Turn off the watch: adım 1, 2 resimden 2.
    • Turn off the Galaxy Watch Active by pushing and holding the bottom button for approximately 3 seconds. You should feel a short vibration.
    • When the "Power off" symbol appears tap the center of the screen to make it shut down. You should feel a longer vibration for confirmation.
  2. Samsung Watch Active Screen Assembly Replacement, Remove the rear screws: adım 2, 1 resimden 1.
    • Use a Tri-point Y00 screwdriver to remove the four 4 mm-long screws on the back of the watch.
  3. Samsung Watch Active Screen Assembly Replacement, Separate the back cover from the housing: adım 3, 3 resimden 1. Samsung Watch Active Screen Assembly Replacement, Separate the back cover from the housing: adım 3, 3 resimden 2. Samsung Watch Active Screen Assembly Replacement, Separate the back cover from the housing: adım 3, 3 resimden 3.
    • Use an opening tool and place it between the plastic back cover and the metal housing near the buttons.
    • Push the tip of the opening tool into the gap to separate the back cover from the housing.
    • Don’t remove the back cover all the way yet. There is a cable connecting it to the motherboard.
    Do i need heat for this? i can't get a pry tool in
    23william90 - Yanıt
    EDIT: use a Rasor knife in the corner nest to the screw holes and it's a lot easier and less damaging to take off.
    23william90 -
    In my case there was quite a bit of glue on the edge of the back cover, and a knife was indeed the only way to pry it open. No way to get the first gap with a plastic tool.
    Marcus Groeber - Yanıt
  4. Samsung Watch Active Screen Assembly Replacement, Disconnect the sensor array: adım 4, 2 resimden 1. Samsung Watch Active Screen Assembly Replacement, Disconnect the sensor array: adım 4, 2 resimden 2.
    • Carefully lift the back cover approximately 2 cm to access the sensor array connector near the two buttons.
    • Use a spudger to disconnect the sensor array from the motherboard.
  5. Samsung Watch Active Screen Assembly Replacement, Remove the back cover: adım 5, 1 resimden 1.
    • Remove the back cover.
    Thank you very much. Nice job!
    Alvaro Grites - Yanıt
  6. Samsung Watch Active Screen Assembly Replacement, Disconnect the display and the mic array: adım 6, 3 resimden 1. Samsung Watch Active Screen Assembly Replacement, Disconnect the display and the mic array: adım 6, 3 resimden 2. Samsung Watch Active Screen Assembly Replacement, Disconnect the display and the mic array: adım 6, 3 resimden 3.
    • Use a spudger to disconnect the display assembly and the microphone and pressure sensor array.
  7. Samsung Watch Active Screen Assembly Replacement, Undo the mic tape: adım 7, 3 resimden 1. Samsung Watch Active Screen Assembly Replacement, Undo the mic tape: adım 7, 3 resimden 2. Samsung Watch Active Screen Assembly Replacement, Undo the mic tape: adım 7, 3 resimden 3.
    • Use an opening pick to peel back the thin tape belonging to the microphone array.
    • When re-assembling make sure this tape properly sticks to the motherboard by pressing it down with the flat end of a spudger.
    What can I use if the glue no longer holds?
    Dominik Dittrich - Yanıt
    Just make sure it lays flat and the counterpart on the back cover (the white thing at the bottom in the image of step 5) will press it down and hold it in place.
    Tobias Isakeit -
    What can I use to make it lay flat?
    Every time I press it down it just pops up again.
    Rosalie E. Morgan -
  8. Samsung Watch Active Screen Assembly Replacement, Lift the core assembly: adım 8, 2 resimden 1. Samsung Watch Active Screen Assembly Replacement, Lift the core assembly: adım 8, 2 resimden 2.
    • Insert an opening pick at the bottom right between the motherboard and the frame to lift up the core assembly.
  9. Samsung Watch Active Screen Assembly Replacement, Remove the core assembly: adım 9, 3 resimden 1. Samsung Watch Active Screen Assembly Replacement, Remove the core assembly: adım 9, 3 resimden 2. Samsung Watch Active Screen Assembly Replacement, Remove the core assembly: adım 9, 3 resimden 3.
    • Lift out and remove the core assembly.
  10. Samsung Watch Active Screen Assembly Replacement, Loosen the mic: adım 10, 2 resimden 1. Samsung Watch Active Screen Assembly Replacement, Loosen the mic: adım 10, 2 resimden 2.
    • Use a spudger to loosen the microphone which is fixed to the frame with mild adhesive.
    What can I use to stick this back on during reassembly?
    The leftover adhesive is not strong enough to hold it in place.
    Rosalie E. Morgan - Yanıt
  11. Samsung Watch Active Screen Assembly Replacement, Free the barometric sensor: adım 11, 2 resimden 1. Samsung Watch Active Screen Assembly Replacement, Free the barometric sensor: adım 11, 2 resimden 2.
    • Use a spudger to lift the pressure sensor up and out of its recess in the frame.
  12. Samsung Watch Active Screen Assembly Replacement, Remove the mic array: adım 12, 1 resimden 1.
    • Carefully remove the microphone and barometric sensor array from the frame.
  13. Samsung Watch Active Screen Assembly Replacement, Screen Assembly: adım 13, 1 resimden 1.
    • You’re left with the screen assembly.
    • Make sure to compare the new screen assembly to the old one for any parts that need to be transferred.
    This looks like a great guide but you stopped short of removing the face and reattaching it. Isn't there some adhesive needed?
    Susan E Hammer - Yanıt
    It says the guide is for removing and replacing the screen but it stops seemingly one step before
    Heather Lee - Yanıt
    Anyone know where I can find the last steps or video covering roving the face and replacing it?
    Doug Apr 19,2023
    Doug Scott - Yanıt
Sonuç
15 farklı kişi bu kılavuzu tamamladı.
Tobias Isakeit
124.417 İtibar
189 adet Kılavuz yazıldı
Ekip
12Kılavuz Yorumları
These instructions look very good! My screen has several cracks and I want to replace the front module. Do you have any idea where I can order one?
Jantine Stulp - Yanıt
My screen was black or showing static. I disassembled and reassembled and now it's back to normal. Might have been a bad internal connection.
Benjamin Franzmayr - Yanıt
Think I have the same issue may have to try opening it. Do you still have it? Is it still good?
Simon Hall -
this is a rather silly question, but which model is that diode on the LCD panel? I couldn't find the schematics for the screen
Thomas Jungblut - Yanıt
Hello my screen crack/charger not working can you refer.
Christopher Moss - Yanıt
I've ordered a screen on aliexpress which came with two adhesives, and I'm glad they did, because I messed up with the first one.
I had trouble following the step three, there was nowhere to put the opening tool. I had to use a metal tool instead of the plastic one between the two buttons (put on gloves to avoid injuries). It did slightly scratch the plastic side, but I was able to pop it open and follow the rest of the tutorial.
The mic tape is a mess to put back properly, and I gave up, maybe I needed some tape or glue to put it back on ? Anyway I never use the watch's mic, but I always need a screen :D
Jérémy VIGNELLES - Yanıt
Update : the adhesive provided with the spare screen lasted only 2 weeks, and I got the screen glued instead. It' still sticking for now.
Jérémy VIGNELLES -
I would like it to be fixed and I will need to buy a bumper case for it
Vearnet Varner - Yanıt
Screen can be odered at e.g. Alibaba
Needed additional glue for microfone.
Ingolf - Yanıt
For removing backcover use a metal Blade, that worked very well for me.
Ingolf - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 20
Son 30 gün: 162
Her zaman: 15,923
